Layouts and layout building
Benchwork, scenery, track, and more. If you're building a scale model train layout, this is where to go. If you're new here, please read our forum policies.
Rate:
Sort Posts:
salt water cowboy
Joined on
02-21-2007
Hershey, Pa.
Good day all! Does anyone know how long a container of enviro-tex lite will last once opened. I have a box that I used a small amount out of to pour a small pond on an old layout about 5 years ago. It has been closed up tightly ever since, but I don't want to use it if it yields unsatisfactory results once opened and sat around for so long. Thanks! Matt
Weighmaster
Joined on
03-10-2007
Shakopee, MN
Mix up a small amount (if you can find the catalyst; don't ask ) and pour into something disposable. Good luck and please advise...Gary
MisterBeasley
Joined on
12-02-2004
Bedford, MA, USA
I agree. Your best bet is to make a small test pour.
I have some that's been open for well over a year, but kept tightly sealed. Since Envirotex is a two-part resin, the interesting stuff doesn't happen until you mix the components. Still, 5 years is a long time.
So, give it a try and let us know, OK?
Is this Envirotex or Envirotex Lite? The "Lite" stuff seems to be a newer formulation. I recall reading somewhere that the new stuff doesn't smell as bad when it's curing. If you've got the older formula, use it in a well-ventilated space only.
salt water cowboy
Joined on
02-21-2007
Hershey, Pa.
OK. I'll give it a shot tomorrow. (It's the Lite stuff btw and I had no issue with fumes although it was used for a very small pond. There will be a river and a bay side scene on my layout this time around.) Matt
cacole
Joined on
07-23-2003
Sierra Vista, Arizona
Make absolutely sure the areas you're going to pour into are leakproof or the Envirotex will just disappear.
Allegheny2-6-6-6
Joined on
03-24-2007
Envirotex appears to have a one year shelf life after opening any time longer it's a crap shoot as to how it's going to look but of more concern last.
Capt. Grimek
Joined on
03-19-2008
Seattle Area
Being chemically sensitive (migraines, wife's respiratory issues) I'd like to hear from similar folks (people who'll only use acrylic paints and other low odor materials) if the "lite" version of enviro-tex is truly "almost" odor free. I have no windows in my train room and can blow scents out the doorway with a box fan, but not for a whole/two day period for each pour. Been considering "magic water" brand for this reason, but still a long way's off. Thanks for any additional "fumes/sensitivity" feedback anyone can provide. I often open bottles in the store and sniff but don't know how enviro-tex is packaged. Thank you.
Allegheny2-6-6-6
Joined on
03-24-2007
Thats the one super advantage of Envirotex lite it's virtually odor free if it were the old stuff then you would need to evacuate your wife, kids pets etc. that stuff was NASTY
saronaterry
Joined on
01-01-2008
I only use the Lite. Since I normally model in the colder Wisconsin winters, an oderless mix was a must. The CFO won't even let me paint clouds or track in the winter. No problems with odor. I have had open (used) containers of the Lite. As long as I've resealed the containers I have had NO problems reusing the product the next modeling season. My experience, anyway!
Hope it helps!!
Terry
MisterBeasley
Joined on
12-02-2004
Bedford, MA, USA
I don't react badly to chemicals, but I can smell them pretty well even if they don't bother me much. (I love bicycling around dinner time and smelling what my neighbors are grilling.) I haven't picked up any particular odor from Envirotex Lite, either.
I prefer not to have a lot of open windows when pouring my "water." This circulates dust and pollen, which will stick permanently to the surface. I try to put a sheet of cardboard a few inches above the surface to catch any stray particles, in any case.
Capt. Grimek
Joined on
03-19-2008
Seattle Area
Thanks guys!! I'll put it on my list of "friendly" chemical agents/products, then.
salt water cowboy
Joined on
02-21-2007
Hershey, Pa.
OK folks: Took your advice and did a test pour onto a scrap piece of masonite yesterday morning. Used 5 milliliters of each part. Just checked on it this morning and it is probably 90% cured and looking beautiful. No cloudiness, murkiness or sloppiness. Perfecto. So, five years didn't affect it a bit. Matt
saronaterry
Joined on
01-01-2008
Matt, when I mix and pour the stuff I follow the directions,with this exception: I pour an amount of one of the bottles into a plastic beer glass, mark the bottle and pour in the same amount from the other bottle.I've found if you try to measure it in a container, then pour it into a mixing container it just doesn't work so well.
Terry
salt water cowboy
Joined on
02-21-2007
Hershey, Pa.
saronaterry:Matt, when I mix and pour the stuff I follow the directions,with this exception: I pour an amount of one of the bottles into a plastic beer glass, mark the bottle and pour in the same amount from the other bottle.I've found if you try to measure it in a container, then pour it into a mixing container it just doesn't work so well.
Terry Well, I hope you drank the beer first! Actually not a bad idea. On my test pour I measured each part using a child's medicine cup and transferred it into a small plastic cup to mix. I held the medicine cup in the air for a long time waiting for all the drips to finally get out. Thanks for the tip! Matt
