Electronics and DCC
The place to discuss wiring for DC and DCC controlled model train layouts. If you're new here, please read our forum policies.
Last post 11-20-2009 12:15 AM by dcs077. 22 replies.
Rate:
Sort Posts:
Page 1 of 2 (23 items) 1 2 Next >
11-17-2009 4:48 AM
Offline dcs077
Not Ranked
Joined on 11-17-2009
Posts 12
consist issue
    i am running an nce dcc system and i am having problems consisting 2 locomotives with 2 different brand decoders. the decoders in question is a digitrax  decoder and a soundtraxx tsunami tsu 1000. my tsunami equipped loco will start moving at speed step 1 but the digitrax loco will not move untill at least speed step 12. i have tried modifying cv 2 6 and 5 as well as the speed tables but it does not help. i am happy with the response from the soundtraxx decoder but is there a way to get the digitrax decoder to start moving the loco on speed step 1. changing to 128 speed steps only compounds the issue. any help would be appreciated
Dan
11-17-2009 6:51 AM In reply to
Offline davidmbedard
Top 50 Contributor
Joined on 03-26-2004
Calgary, Alberta, Canada
Posts 5,539
Re: consist issue
Does the Digitrax equipped loco start moving at speed step 1 when you are running it alone?
Which Digitrax decoder is it?
If so, there is a BEMF CV (Cant think of it right now) that comes into play when you are using advanced consisting.
Which type of consisting are you using?  Advanced or (as I think NCE calls it) Universal?
David B
11-17-2009 7:13 AM In reply to
Offline retsignalmtr
Top 500 Contributor
Joined on 02-05-2002
Westchester NY
Posts 824
Re: consist issue
I have a couple of Athearn loco's that i added Digitrax decoders to. I found that I had to set CV2 to a value of over 100 to get them to crawl at step 1 on my DT400 ( CV values 0-255 ). Remember you cannot set CV 6 to a value lower than CV2 and CV5 to a value lower than CV6.
11-17-2009 7:55 AM In reply to
Offline BIG JERR
Not Ranked
Joined on 10-12-2008
high desert so cal
Posts 201
Re: consist issue
good question as I ve had the same problem ,got two matching atlas rs3 one with psunami at1000 other w/dh165 thought Id run em together same address but Ive never got them perfect so on some speeds I here wheels of one slipping a bit .... Id love to learn to consist em but Im still in learning mode so I will follow along ...J.W.
11-17-2009 9:30 AM In reply to
Offline cacole
Top 10 Contributor
Joined on 07-23-2003
Sierra Vista, Arizona
Posts 9,338
Re: consist issue
 After struggling with several Digitrax decoders that couldn't be speed matched and consisted with an NCE ProCab system, I ripped them out and put in NCE DA13SR or TCS T-1 decoders.  Consisted and speed matched on the first try.
IMHO, Digitrax makes great DCC systems, but their decoders don't play well when mixed with other brands.
11-17-2009 1:41 PM In reply to
Offline cmarchan
Not Ranked
Joined on 01-07-2004
Tampa, FL
Posts 292
Re: consist issue
cacole:
Can you describe the issues you were having? I may be able to help. I have many Digitrax decoders in locos and have successfully consisted them using an NCE system(ProCab Wireless with three boosters).
What version of the NCE firmware are you using?
Which command station/booster do you have?
Which consist method (universal or advanced)?
11-17-2009 1:48 PM In reply to
Offline cmarchan
Not Ranked
Tampa, FL
Posts 292
Re: consist issue
dcs077:
Dan
What are the brand and model of each loco?  Ditto on DavidBedard's questions
11-17-2009 8:49 PM In reply to
Offline dcs077
Not Ranked
Posts 12
Re: consist issue
 the decoder is a digitrax dh 123 and it is installed in an athearn genisis sd 70. the tsunami is installed in a ready to roll athearn sd 38. i have tried the digitrax decoder in 3 different locos and the result is the same regardless of mechanism. the loco will not start moving until speed step 12-15 on its own out of a consist as well. i am using the advanced consist but i have also tried the other method nce recommends in the manual which yielded the same result.the back emf is not set up on the decoder as i returned it to default. i did set it up but made no difference. the powercab is just the base model one no booster and unsure of firmware version.
11-17-2009 10:20 PM In reply to
Offline cacole
Top 10 Contributor
Posts 9,338
Re: consist issue
cmarchan:
I have the latest NCE firmware because I just replaced the EPROM in both my home and club systems; ProCab Radio throttles with 5 Amp PowerPro Command Station; Advanced consisting.  I was trying the Digitrax DH123 decoders.  Changed to NCE or TCS decoders and threw the Digitrax into the round file.
11-17-2009 11:35 PM In reply to
Offline pastorbob
Top 500 Contributor
Joined on 12-03-2002
Posts 859
Re: consist issue
You may have been premature tossing the Digitrax.  I have run NCE on a three deck railroad, using 4 boosters since 1999-2000, have the latest upgrades and have consists running with Digitrax and NCE and TCE in the same consists with no problem.  I just keep tinkering.  My consists for the most part remain together from session to session, so once I have them set, I don't reinvent the wheel.
Bob
11-18-2009 3:21 AM In reply to
Offline dcs077
Not Ranked
Posts 12
Re: consist issue
i would like to keep the digitraxx decoder but does anyone have any ideas how to get it to move the loco on speed step 1
i think that this is the main part of the problem. has anyone heard of any other decoders with the same issue?
11-18-2009 3:40 AM In reply to
Offline mfm37
Not Ranked
Joined on 07-04-2008
Posts 520
Re: consist issue
 Best advice is to reset the decoder to defaults. CV8 = 8. Then start making changes to  CV2 to get engine to start at speed step 1.
After that, changes to CV5 and Cv6 can be made to speed match if desired. DH123 does not have BEMF so any changes to those CV numbers won't have an effect. Torque Compensation is not BEMF.
Programming a 28 step speed table is another option. The speed table would need to be enabled in CV29 for it to work. Enabling speed tables turns off CV 2, 5, and 6.
11-18-2009 9:22 AM In reply to
Top 50 Contributor
Posts 5,539
Re: consist issue
dcs077:
You need to adjust CV2 until it will move at speed step one.  I have seen Athearn values from 20-80 for CV2.
David B
11-18-2009 5:51 PM In reply to
Offline rrinker
Top 25 Contributor
Joined on 02-14-2002
Reading, PA
Posts 8,254
Re: consist issue
 You can get it to move at speed step 1 by adjusting CV2, but with a DH123 series decoder you'll never get the ultimate in slow speed eprformance, the DH123 does not have back-EMF. CHeck your value in CV54, it should be either 0 or 1 to turn on torque compensation, which helps but is not as good as BEMF, nor is it adjustable, it's either on or off. Getting a non-BEMF loco to run perfectly well with a BEMF decoder (the Tsunami has pretty good BEMF) is near impossible.
 For a much lower price, the NCE D13SRJ offers adjustable 'dither' to help customize slow speed running (still no BEMF). For the same price as the DH123 you can get the TCS T1 which does have BEMF. If you want to use Digitrax decoders, you need the DH163/DH165 series, those have BEMF.
                                        --Randy
11-18-2009 11:34 PM In reply to
Offline dcs077
Not Ranked
Posts 12
Re: consist issue
 thanks for all the info will try tonight and let you all know how it goes
Dan
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
