General Discussion (Classic Trains)
Like Classic Trains magazine itself, this forum celebrates the "golden years of railroading." Covering the railroad scene from the late 1920s to the late 1970s, this forum section is everything from giant steam locomotives and colorful streamliners, to the dieselization-era. Share your recollections here! If you're new here, please read our forum policies.
Last post 01-02-2010 11:18 AM by Deggesty. 16 replies.
Rate:
Sort Posts:
Page 1 of 2 (17 items) 1 2 Next >
11-16-2009 7:47 AM
Offline Redwards
Not Ranked
Joined on 07-14-2006
Matawan, NJ
Posts 43
Slumbercoach (Sleepercoach) vs. Pullman Duplex Roomette
I'm trying to ascertain the similarities/differences betwen these two types of sleeping car arrangements.  They seem to be similar in terms of the room size 'footprint' and the offset up and down arrangement.  I believe they also both had in room toilets and sinks.
Were the Pullman run duplex roomette cars more "luxurious" than the railroad run slumbercoach spaces?  Did the Pullmans have slighly more space or perhaps better mattresses than a slumbercoach room?
--Reed
11-16-2009 7:56 AM In reply to
Offline passengerfan
Top 150 Contributor
Joined on 03-23-2004
Central Valley California
Posts 2,790
Re: Slumbercoach (Sleepercoach) vs. Pullman Duplex Roomette
The slumbercoach room was smaller than the duplex roomette although not by much. The mattress was a standard pullman mattress in the duplex roomette where the slumbercoach mattress was somewhat thinner. Both had toilets and sinks. The major difference was you had all of the Pullman amenities in a duplex roomette not found in the slumbercoach, such as access to the first class section of the train, shoes shined etc. There was not much difference in price between a Roomette and Duplex Roomette but quite a difference between that and the Slumbercoach room. First no first class upgrade for slumbercoach and in most trains the Slumbercoach was next to the coaches if not ahead of the coaches.
Al - in - Stockton
11-16-2009 9:44 AM In reply to
Offline aricat
Not Ranked
Joined on 07-31-2004
Posts 234
I don't wish to make a dogmatic statement,but I don't believe that the Pullman Company ever operated a Slumbercoach. CB&Q,NYC, NP and B&O were the only lines to operate Slumbercoaches to my knowledge. NYC began using them after they took over operations of sleeping cars.On CB&Q and  B&O train conductors not Pullman conductors picked up tickets in the slumbercoaches. The Blackhawk was the only CB&Q train to carry a slumbercoach, both the Capitol Limited and the National Limited carried slumbercoaches on the B&O. The NP operated slumbercoahes on both the North Coast Limited and the Mainstreeter.Slumbercoahes I think were used by Amtrak for a while.
I think that slumbercoaches compared favorably to the current Amtrak economy sleepers, slumbercoaches were  more comfortable.
I am surprised that ACL and SAL did not purchase slumbercoahes, considering the Florida trains that they ran ?
11-16-2009 10:22 AM In reply to
Offline Deggesty
Top 200 Contributor
Joined on 08-22-2005
Near the Crossroads of the West
Posts 1,941
aricat:
A note or two--the slumbercoaches used on the NCL also were operated on the Denver Zephyr, running Chicago-Colorado Springs. If the NCL came into Chicago in time, the slumbercoach would be turned and sent to Colorado Springs the same day, and the car that came in from Colorado Springs would be turned and sent out to Seattle the same day.
The ACL did operate a sort of slumbercoach, using B&O Duplex roomette-bedroom sleepers between New York and Miami. The operation was continued into the early days of Amtrak--I rode in a lower level duplex roomette from Jacksonville to Washington (it was nice to pull the berth part way out and rest my feet on it) in July of '71. Eventually, Amtrak began operating slumbercoaches New York-Miami, and continued the practice into '89, at least.
Johnny
11-16-2009 1:57 PM In reply to
Offline KCSfan
Top 500 Contributor
Joined on 07-13-2006
Posts 1,271
I rode in NYC slumbercoaches a couple of times. Once on the 20th Century and IIRC the other time on the Ohio State Ltd. I remember the matress being a thin sponge rubber affair and no where near as comfortable as a Pullman matress. I was not overly impressed with accomodations but they did beat trying to sleep all night in a reclining coach seat.
Mark
11-16-2009 2:24 PM In reply to
Offline RoyPBower
Not Ranked
Joined on 06-01-2007
Rocky Mount, North Carolina
Posts 36
I had a roomette traveling Miami to Washington DC about 1992 or so and remember catching a glimpse of the slumbercoaches. They were SMALL and made my humble heritage roomette look large. I remember them being staggered in that one door would be higher than the other as you moved through the car. This was done to allow room for the bed which was perched on a ledge,or under a ledge depending on the location of the door. If there was a toilet, it had to have been under the passenger's seat.
Roy
11-16-2009 5:11 PM In reply to
Offline Deggesty
Top 200 Contributor
Posts 1,941
RoyPBower:
Roy
Well, Roy, the toilet facilities (including the basin) were by the aisle wall, so it was not necessary to unmake your berth if you had to get up in the night. They were not quite as cramped as the similar facilties in an Amtrak Viewliner "roomette." The slumberroom seat and berth were not as wide as the Viewliner "roomette." I have had experiences with slumberrooms, both Amtrak styles of "roomette," and real roomettes (in which you had to put your berth up into the wall if you needed to make use of the facilities in the night). I have slept in every kind of Pullman accomodation except the Master Room and single rooms. A drawing room is wonderful. I never slept in a heavyweight, though.
In an upper single slumberroom, the middle part of the berth was folded in over the seat of the room in front; in a lower room, the middle part was folded in under the seat of the room in front. In both cases, the back of the seat, when folded down, became the head of the bed, and you put your feet into the opening from which you unfolded the middle part. I do not recall just what the arrangement at the front of the car was, though.
Johnny
11-16-2009 6:27 PM In reply to
Offline Redwards
Not Ranked
Matawan, NJ
Posts 43
Thanks very much for all the great information.
--Reed
11-17-2009 5:20 AM In reply to
Offline daveklepper
Top 75 Contributor
Joined on 06-18-2002
Posts 4,115
Amtrak operated Slumbercoaches on the Broadway Limited from Amtrak's start, and this continued until either the Broadway or the slumbercoach operations were discontinued.   Rode it.
I believe the CB&Q and NP were exceptions in that their Slumbercoaches, shared between them, were operated by Pullman.   Also, regarding the CB&Q operated Slumbercoach each way on the Blackhawk, chicago - Twin cities:   Porter in charge, since only one car.   This is what my memory says.
11-17-2009 6:19 AM In reply to
Offline Redwards
Not Ranked
Matawan, NJ
Posts 43
There seems to be a decent amount of information out on the web regarding slumbercoaches - does anyone have a rough idea how many duplex roomette cars were produced and in what configurations?
--Reed
11-17-2009 11:18 AM In reply to
Offline Deggesty
Top 200 Contributor
Posts 1,941
Redwards:
--Reed
The book, From Zephyr to Amtrak, lists the following cars built with duplex roomettes:
SFé: 12 ea 24 Dup Rm. B&O: 11 ea 16 Dup Rm, 4 BR. MILW: 4 ea 16 Dup Rm, 4 BR, 10 ea 8 Dup Rm, 6 Rmt, 4BD. RI: 5 ea 8 Dup Rm, 6 Rmt, 4BD. GN: 10 ea 16 Dup Rm, 4 BD, 12 ea 8 Dup Rm, 4 BD, 4 Sec, 8 ea 7 Dup Rm, 4 Sec, 3 Bd, 1 C. NP: 18 ea 8 Dup Rm, 6 Rmt, 4BD. CN: 52 ea 8 Dup Rm, 4 BD, 4 Sec. CP: 29 ea 8 Dup Rm, 1 DR, 3 BD, 4 Sec.
Of all of these, only the cars built for the CP are still in use. The Sfé cars were rebuilt to the 12 BD configuration. Some of the cars listed under GN and NP were actually built for the CB&Q or SP&S, but were operated on GN or NP trains.
Johnny
11-17-2009 6:19 PM In reply to
Offline Redwards
Not Ranked
Matawan, NJ
Posts 43
Thanks Johnny - much appreciated!
 --Reed
12-03-2009 3:17 PM In reply to
Offline Nebraskafan
Not Ranked
Joined on 06-18-2009
Posts 4
 The other postings have accurately described the differences between Slumbercoaches and duplex roomettes. As-built Slumbercoaches were more spartan than standard sleeping cars, although two roomette sleepers were used as Slumbercoaches on UP's City of Denver for a time around 1957. The Burlington initially used them on the Denver Zephyr, expanding the pool with Northern Pacific cars for the North Coast Limited. Toward the end a Slumbercoach replaced the sleeping car on the American Royal Zephyr between Chicago and Kansas City, although that train later went coach only, and one was used on the Black Hawk between Chicago and Minneapolis. The singles were the best travel bargain around, a private room at coach fare plus a space charge. I wish we still had them. The double rooms were rather "cozy" for two travelers. Baltimore & Ohio and Missouri Pacific had through Slumbercoach service between Baltimore-Washington and Texas. I think New York Central's were called Sleepercoaches and the concept was originally referred to by Budd as "Siesta Coach."
Nebraskafan
12-03-2009 4:56 PM In reply to
Offline Deggesty
Top 200 Contributor
Posts 1,941
Nebraskafan:
You're right, When Budd began building them, Budd called them "Siesta Coaches." Perhaps the B&O thought that a full night's sleeper was better than an afternoon nap so they called them "Slumbercoaches."
I have slept in both the NYC converted cars and the cars built for this service--and I have slept in a duplex roomette, in 1971, Jacksonville to Washington, that was sold for this kind of service. Except for my last two trips, I always a had a single room (the upper rooms were more spacious); in 1984, I had a double room (at the single room price) from Montreal to Wilmington, and, again, from Atlanta to Trenton. The double room was not bad for one passenger.
I have had three experiences in duplex roomettes. The first was from Minneapolis to Milwaukee, in 1968, and the room was sold as a duplex roomette. The second is mentioned above, and the third was from Boston to Philadelphia 30th Street, in 1974; the room was sold as a roomette.
In 1989, when Amtrak was still operating them NYC-Fla., my wife and I had a bedroom, in former SP 10-6, from NYC to Sebring. We ate dinner with a lady who had been unable to obtain Pullman space, and she was unhappy with her accomodation. I would say that Amtrak did not do a good job of explaining the difference between the two types of car. I do not know how easy it would be for the traveler who is not as familiar with the various types of sleeping accomodations as many of the contributors to these forums are to be able to comprehend the differences. Other than this, I wish that Amtrak had seen fit to maintain and continue to use the cars.
Johnny
12-17-2009 9:30 AM In reply to
Offline daveklepper
Top 75 Contributor
Posts 4,115
Impossibility of installing retention toilets without complete rebuilding the car was the reason for Slumbercoach phase-out.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
Subscriber Login
E-mail Address:
Password:
Remember me
My Profile
Screenname: (get your screenname)
Search Community
in
