Hi,
I've been playing with trains since the '50s (Ho since early '60s) so I guess I could be called an MR veteran. Anyway, I am in the process of building an HO 11x15 two level DCC (my first venture) layout. Sooo, our layouts are reasonably comparable, even though I model the transition period. My comments are - for what they are worth:
Your 86 ft cars may (??) handle 24 inch curves, but will look very unrealistic. I have several 80 ft (or so) passenger cars with most curves 28-30 inch. They do well on these, but frankly don't look as good as they would on 36 inch or larger curves.
I did a lot of research before going into DCC, reading books and asking lots of question on the DCC forum here, and elsewhere. It came down to either Digitrax or NCE, and I chose Digitrax (but all my decoders so far are NCE). I got the Super Chief 5 amp wired system (radio is too big of a jump for me now), and a Super Empire Builder set. Getting that second set allowed me to have a second booster and DT400 controller and some other parts - cheaper than buying them separately. Also, I picked up two Digital Specialties PSX4s. This allowed a total of 8 separate districts. For power supplies, I got two of the Digitrax 5 amp pieces. So far, all is working out extremely well, and I am very pleased.
This new layout is essentially a replacement for one built in the early '90s - which gave me 15 years of "experience" with what works for me. Thankfully, Atlas came out with code 100 # 8 turnouts (I use all Atlas code 100 flex track & turnouts), and these are used on the double main lines or anywhere else fast passenger trains will travel. "Sub-main trackage uses # 6 turnouts, and # 4s are used only in the freight yard and some industrial sidings. For those non-main turnouts located close at hand, I use Caboose Hobbies SPRUNG ground throws, and all others are automated.
Your use of code 83 and 70 trackage is fine, and they can really look good. My use of code 100 is primarily because I have a lot of it, and these 65 year old hands and eyes can still handle them.
I have 6 BLI locos with sound - the first I have ever had. WOW, that Northern sure sounds good! However, to put sound in all your locos is a huge expense, and frankly the wonderful sounds can often be "noise" with too many going on at the same time. I would suggest trying it out, and taking it one step at a time.
Hey, hope all goes well!!!
Mobilman44
