Have you considered one of the heavy-duty transformers designed for low-voltage outdoor lighting circuits? They are about 100 or 120 VA output at 12Vac. To convert the output to DC, all you need is a high-power bridge rectifier.
Rather than a single humongutransformer, I power the several zones of my double garage filler with smaller power supplies, including toy train transformers and somewhat more powerful supplies based on 12.6V 3A center-tapped filament transformers. The latter are especially useful for low-voltage lighting, since they have effectively two separate 6.3V 3A circuits. Since there is no valid reason for scenic lighting to be powered from a layout-wide bus, I don't.
