Layouts and layout building
Benchwork, scenery, track, and more. If you're building a scale model train layout, this is where to go. If you're new here, please read our forum policies.
Last post 11-10-2009 4:46 PM by willy6. 8 replies.
Rate:
Sort Posts:
Page 1 of 1 (9 items)
11-09-2009 7:05 PM
Offline dougedw4
Not Ranked
Joined on 12-05-2005
Posts 32
control panel, lighted switch control
Friends:
I want my control panel to show the direction my switch machines are in.  Currently I am using red and green contact switches. However, I would like to have lights that remain constant (red or green open and closed) how do I accomplish this?  Do I have to use something other than contact switches? Is there a commercial system that does this?
Thank you in advance.
Doug Edwards
11-09-2009 9:08 PM In reply to
Offline larak
Top 500 Contributor
Joined on 10-03-2005
Ulster Co. NY
Posts 1,253
Re: control panel, lighted switch control
Doug, if you are using tortoise switch machines (or any stall motor type) simply put a 2 lead bipolar LED in series with the power to the tortoise. You can even use two in series. I have one on the control panel and another as a ground indicator near the turnout itself.If the colors are reversed just switch the leads on the LED.
If you're using some kind of Atlas type snap controller then you will probably need to add a "snap relay" for each TO.
Edit, you don't need the relay. It gains you nothing just use a switch with an extra double throw pole and wire the LED through it.
Karl
11-09-2009 10:34 PM In reply to
Offline Bob grech
Not Ranked
Joined on 04-19-2006
Fountain Valley, Ca.
Posts 672
 I use Tortoise switch machines which are wired in series using LEDs. I make my own turnout control panels using 1/8 inch plexiglass to mount the LEDs. These are positioned around the layout where needed.
11-10-2009 8:44 AM In reply to
Offline JSperan
Not Ranked
Joined on 05-23-2009
Posts 207
 Doug,
If you are using stall motor switch machines like the Tortoise, follow the advice already given.  If you are using coil switch machines that require momentary power, use The Electronic Turnout Switch.
11-10-2009 9:56 AM In reply to
Offline tomikawaTT
Top 25 Contributor
Joined on 02-13-2005
Southwest US
Posts 7,713
I respectfully beg to differ with those who just wire turnout position indicators to the panel switch - unless the switch motor is a tortoise and the UNIdirectional LEDs are used to set machine power polarity.
Unless the indicators are wired through contacts on twin-coil machines, they will ONLY tell the direction the toggle (or slide) switch is thrown, not what the machine actually did.
My indicators are set up as a cascade circuit, one in each track line of the hidden yard.  Five indicators, four twin-coil machines, positive data about which track has been selected.  As a result, I can use the least expensive switch power arrangement - probe and stud.  Since the indicators take a close approximation of no power, I can (and do) use salvaged communications cable wire, about #24, to connect machine contacts to panel.
By using an AC power source and diode-dividers at both studs and switch machines, I cut the wiring for switch machine power to a single wire from panel to machine.  All it takes is four twelve for a dollar diodes, and the saving in heavier-gauge wire more than covers that AND the indicator circuit.
11-10-2009 1:51 PM In reply to
Offline dougedw4
Not Ranked
Posts 32
Thanks for your help.  I am using Atlas switch machines therfore I'll try your recommendation.
Doug
11-10-2009 1:53 PM In reply to
Offline dougedw4
Not Ranked
Posts 32
Thanks for your advice.  I think I get the picture.
 Doug
11-10-2009 1:57 PM In reply to
Offline dougedw4
Not Ranked
Posts 32
Thanks for the help.  I'm going to call the Electronic Switch people.
Doug
11-10-2009 4:46 PM In reply to
Offline willy6
Not Ranked
Joined on 01-27-2003
Ridgeville,South Carolina
Posts 702
I got some good ideas for control panels from Google. I googled images of "model railroad control panels".
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
