Layouts and layout building
Benchwork, scenery, track, and more. If you're building a scale model train layout, this is where to go. If you're new here, please read our forum policies.
Last post 11-09-2009 12:57 PM by doctorwayne. 9 replies.
Rate:
Sort Posts:
Page 1 of 1 (10 items)
11-07-2009 11:10 AM
Offline BNENGR
Not Ranked
Joined on 11-13-2007
Northern Michigan
Posts 100
Super Elevated Curves
Hello Group,
I am just starting to lay track on my newest layout. I'm in HO scale. I use flextrack.
Is it necessary for me to super elevate the curves? If so, how should I do it?
Should I use easements into the curves?
This is my third layout and I never did the above before and did'nt seem to have any problems.
Thank you and have a great weekend.
Paulie
11-07-2009 11:38 AM In reply to
Offline selector
Top 10 Contributor
Joined on 02-07-2005
Vancouver Island, BC
Posts 15,503
Re: Super Elevated Curves
Hi.  In "Search Community" at right, you can do a search and find all sorts of threads on this subject...it is well covered.
Here are some examples:
http://cs.trains.com/trccs/forums/p/135563/1520660.aspx#1520660
http://cs.trains.com/trccs/forums/p/58350/728885.aspx#728885
http://cs.trains.com/trccs/forums/p/120219/1369794.aspx#1369794
http://cs.trains.com/trccs/forums/p/126347/1424944.aspx#1424944
It is strictly a personal choice.  It looks good for most of us, providing you don't overdo it.  A 3-5 degree tilt is about optimal, but your models won't need it...it'll just look realistic in head-on images.
-Crandell
11-07-2009 11:58 AM In reply to
Offline IRONROOSTER
Top 50 Contributor
Joined on 06-08-2003
Northern Viriginia
Posts 4,901
 While super elevation is for appearance, easements are useful especially with our overly sharp curves.  The easiest way to do easements is with a template.  This page here on Kalmbach's site http://www.trains.com/mrr/default.aspx?c=a&id=290 has them along with instructions.
Enjoy
Paul
11-07-2009 12:59 PM In reply to
Offline j1love
Not Ranked
Joined on 04-11-2003
Philadelphia PA
Posts 75
I wanted to answer your question, but the other two posters beat me to it    Still, I will add this opinion; I perfer using the template for easements along with the super-elevation using the tape method to create ramps from level track to super-elevated track.  I saw it somewhere on the forums (probably in one of the short cuts listed above ).  It is simple; you apply slim strips of tape to the roadbed under the outside rail at predetermined lengths along the area of the easement into the curve......I use 5-6 strips of tape.  the super-elevation "ramp" starts at the begining of the easement going into the curve and coming out of the curve.  If you use the template mentioned earler, you have a length to divide by 5 or 6 to make your ramp constant through your easements.  You do not "need" this super elevation, but it looks great and is easy to put in.  I love the look.  Good luck with your project!
11-07-2009 1:51 PM In reply to
Offline BATMAN
Not Ranked
Joined on 07-14-2006
Surrey B.C. Canada
Posts 750
 On my spline I used a rasp and built it in to the spline. Elsewhere like on the foam I used a variety of methods such as tape, thin cardboard and even spackle.  I wanted to experiment with different methods. It's just the way I am and it drives my wife crazy sometimes. I just tell her variety is the spice of life.
The best thing I did was get a small 2" long bubble level and put a mark on the glass as to where the maximum tilt should be. This made for good consistency in bank and I could tell how smooth the transitions in and out of the curves were. I would just slide the level along and observed how smoothly the bubble would move. Just my .
        Brent
11-07-2009 6:34 PM In reply to
Offline larak
Top 500 Contributor
Joined on 10-03-2005
Ulster Co. NY
Posts 1,253
BATMAN:
... it drives my wife crazy sometimes. I just tell her variety is the spice of life.
When I told MY wife that she kicked me. Of course the context was not trains.
11-08-2009 5:47 PM In reply to
Offline Metro Red Line
Not Ranked
Joined on 10-25-2006
Under The Streets of Los Angeles
Posts 694
 I do it with a mix of tape and strips of Evergreen styrene. I do N scale, so for you, you should use a max of .040" thick strips of styrene and have stepped-up strips 50 scale feet in length going up to that thickness.
For instance, when your track starts to curve, a .010", then a .020", then a .030" then the .040".
 Here's how I installed it on my N scale layout blog:
http://www.trainboard.com/grapevine/blog.php?b=1894
11-09-2009 8:26 AM In reply to
Offline dknelson
Top 50 Contributor
Joined on 03-20-2002
Milwaukee WI (Fox Point)
Posts 4,817
In HO, Precision Scale (PSC) makes a line of flex track where the ties are built up at one end so it is super-elevated.  Two observations 1) first make sure you bend it the right way so the super elevation is not exactly wrong and 2) it is by no means easy track to bend.  Maybe bendable rather than flex is the better word for it.  And you still have to do a transition to flat, which I did by snipping off the nubs at one end of a piece.
It does look neat to see cars and locomotive lean into the curve.  But I agree with the above poster that spiral easements (as opposed to tangent track meeting a fixed radius curve a la snap track or tinplate track) also have visitual appeal AND actually are useful.  John Armstrong tested things out and showed how easement curves can allow equipment to run on an 18" radius curve that would otherwise need 24" radius if that 24" fixed radius met the tangent w/o an easement.
Dave Nelson
11-09-2009 10:13 AM In reply to
Offline johncolley
Top 500 Contributor
Joined on 02-14-2002
PtTownsendWA
Posts 1,411
For information purposes here's what I do in HO: I lay out the centerline using the bent stick method for easements, then I lay the cork roadbed with caulking. I mark it out to the outer end of the ties and mark the two ends of the easement, ie: the tangent and full radius points. I then glue down a 3/32" square balsa or basswood strip along the inside of the end-of-tie line the full length of curve plus easements. Using the curve ends of the easements I lightly sand the strip to a taper the full length of the easement. I then lay the track in place with caulking and hold it in place overnight with cans of food and bottles of water. I wait until after making all my power wiring feeder drops to do the ballasting, which hides the superelevation strips and wiring connections. One can paint the rails and tie plates either before or after ballasting. Enjoy the learning curve. John
11-09-2009 12:57 PM In reply to
Offline doctorwayne
Top 200 Contributor
Joined on 01-04-2004
Posts 2,222
There are some more ideas HERE.
If you're using L-girder or open grid benchwork, with either plywood or spline sub-roadbed, I've detailed an easy and effective way of accomplishing superelevation, as shown within that linked thread.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
