General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 11-07-2009 9:21 PM by Great Western Rwy fan. 7 replies.
Rate:
Sort Posts:
Page 1 of 1 (8 items)
11-07-2009 7:21 AM
Offline solzrules
Top 500 Contributor
Joined on 01-21-2006
SE Wisconsin
Posts 1,200
Stripping factory paint off old blue box shells
Hey guys -
I've got a collection of Athearn blue blox locos from the 80's that I just can't bring myself to part with.  I've seen some guys do some amazing things with these kits, but the first issue is the factory paint job.  Is there a way to strip off the old paint from the factory and get the kit down to the original plastic?  Thanks in advance.
11-07-2009 7:32 AM In reply to
Offline jeffrey-wimberly
Top 10 Contributor
Joined on 06-21-2004
Sundown, Louisiana
Posts 12,578
Re: Stripping factory paint off old blue box shells
 Soak it in 91% rubbing alcohol. It'll take some time so put the alcohol in a container that can be sealed with the shell inside. An old toothbrush will be required.
Online Driline
Top 200 Contributor
Joined on 07-04-2006
Bettendorf Iowa
Posts 1,871
 Completely submerge it in a pool of power steering fluid. Takes about 30 minutes. Use a toothbrush to remove paint from stubborn areas. Don't leave it in there too long or the plastic will become soft.
I wouldn't use alcohol like the "spray can rembrandt" above. It takes too long IMHO.
11-07-2009 7:56 AM In reply to
Offline dehusman
Top 50 Contributor
Joined on 09-20-2003
Omaha, NE
Posts 5,078
Hardware store alcohol and a stiff brush like a tooth brush.  Get a shallow pan (aluminum foil bread pan) and pour an inch or so of alcohol over the model, let it soak a little and then start scrubbing.  Might want to wear rubber gloves.
11-07-2009 8:06 AM In reply to
Offline Silver Pilot
Not Ranked
Joined on 05-15-2009
Posts 122
While 91% isopropyl can work as "The Spray Can Rembrandt" suggests, it can take days or soaking to get the bits of paint out of the crevices and details so I would steer clear of that method unless you want to wait a while.  The other downside to 91% isopropyl is that it immediately begins to absorb moisture from the air and dilutes the concentration making less and less effective as the model sits in it.
I recommend either Easy-off oven cleaner or a citris based cleaner like from Zep.  Get it in the gallon jug and after you done stripping it can be filtered and stored for future use.  It has no negative effect on any of the plastics I used it on.  It hasn't softened or made them brittle
11-07-2009 11:33 AM In reply to
Offline barrok
Not Ranked
Joined on 07-23-2007
Posts 72
I use ScaleCoat II  Wash Away -- this stuff is amazing!  I pour it into a two liter bottle cut lengthwise and then submerge the car body in it so the entire car is soaking.  I let it sit for about 20 minutes or so.  The paint will literally come off in sheets.  Use a toothbrush to scrub detail areas like ladders etc. and the paint comes off.  If any paint is being stubborn, resoak for a few minutes and it will come clean.  Wash the plastic in warm soapy water to get rid of any residue, and viola!  Ready for priming.  Here is the best part.  Pour the Scale Coat II back into the original bottle and re-use it!  I strain out any paint bits, but the rest is good to reuse.  I have had a bottle for over two or three years now and have stripped quite a few models with it.  Another great use -- let's say you want to just remove some lettering.  No problem.  Use a brush to "paint" a little scale coat II onto the lettering, and then gently wipe off with a wet cloth.  The lettering will come off easily, leaving the paint intact.  You have to experiment with how long to let it set before wiping.  Be careful!  it doesn't take long!
Chuck
11-07-2009 7:33 PM In reply to
Offline solzrules
Top 500 Contributor
SE Wisconsin
Posts 1,200
Thanks for all of the ideas, everyone!  I actually had heard of the rubbing alcohol, but you've given me a few things to try.  Thanks again!
11-07-2009 9:21 PM In reply to
Offline Great Western Rwy fan
Not Ranked
Joined on 07-31-2006
Londonderry New Hampshire
Posts 353
I've used DOT Brake Fluid with great results
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
