MrMick,
A quick note to those who do not have one of these. They have class/direction lights and are extremely realistic. I have two CNJ FM units and a CNJ ex B&O FM and am extremely pleased with the ATLAS decoder on these and these lights. The problem is that from the factory they mapped these lights to F2. This is a non latching relay that is set up for a horn not lights. To keep the class/direction lights on you need to keep the F2 pressed. Remapping this function to F3 eliminates this.
Just pulled out my index card on CV's for this locomotive. A good idea I learned on this forum. Just because these are all standard they still all end up different.
I set CV 54 equal to 4.
This setting remaps the class/direction lights away from F2 to F3. F3 is a latching relay. Stays closed until pressed again.
Look on ATLAS web site or if you have the manual at home. Page 3 says you can do it and page 9 shows the value.
The Prodigy Advance reads a CV but does not tell you what it is. So you will go to "programming" on the main, with no other loco's on the main, or go to "program track". Begin scrolling through the configuration variables as you did to change the road number.
You will come to CV 54, enter, fill in the number 4. Continue on until the end as you did when you changed the road number. Don't forget you need to select your loco with the new road number but I think you know that. F3 will now control the class/direction lights manually.
In addition you will note in operation that you need to manually change the class/direction lights when the loco changes direction. When first applying power to tracks the lights will be yellow. Press F3 until you see green in the direction you are traveling. Red is to the rear. When changing direction you will need to manually change the green to the forward direction. The class/direction lights will go out press again they will change to green in forward direction. I have not been able to figure out how to change these automatically.
I chose F3 because it might not be used when using a sound decoder. F1 is for Bell, F2 is Horn, F4 is dynamic brake on a soundtraxx, etc. As discussed above I use a Soundtraxx FM low cost for sound only retaining the neat class/direction lights that are on the ATLAS decoder. When you have the room the Soundtraxx low cost is the best sound only decoder you can buy.
Hope this is helpful, Chris
