Good Morning!
I located the Tam Valley website and checked out the "frog juicer". I then went to a couple of internet stores (including Walthers) and could not find it for sale. It sounds great, but at $70 each, I would need two of them. And, as I picked up 5 of the Snap Relays yesterday evening, it looks like I will stick with them. This was my first knowledge of Tam Valley or the Frog Juicer, and I wish I had known about them (and my need for them) earlier on.
Anyway, my layout will have 4 double crossovers, with a break in power districts between each set. It looks like I can use one Atlas turnout controller for each set, but will probably need two snap relays for each set. Note that I am using the Atlas switch machines (either above or below the "table").
Assuming I go this route, the question is, "Will I need two snap relays for each crossover or can one be wired for both turnouts?"
Mobilman44
