Electronics and DCC
The place to discuss wiring for DC and DCC controlled model train layouts. If you're new here, please read our forum policies.
Last post 11-04-2009 7:28 PM by larak. 8 replies.
Rate:
Sort Posts:
Page 1 of 1 (9 items)
11-02-2009 10:06 PM
Offline trnj
Not Ranked
Joined on 05-26-2005
North Carolina
Posts 136
RRampmeter readings
I recently installed a RRampmeter and noticed that my DCC-powered engines draw only between .02 and .04 amps, according to the meter.  Am I correct in assuming this is correct?  (Engines: Walthers H10-44, Stewart VO-1000 w/ ESU decoder, BLI SW-7, and Bachman 44 tonner with ESU decoder.)
TRNJ
11-03-2009 6:52 AM In reply to
Offline davidmbedard
Top 50 Contributor
Joined on 03-26-2004
Calgary, Alberta, Canada
Posts 5,528
Re: RRampmeter readings
 Absolutely correct.  The RRampmeter is designed with DCC in mind (although it will work with DC) and the readings you get are spot on.
David B
11-03-2009 6:58 AM In reply to
Offline rrinker
Top 25 Contributor
Joined on 02-14-2002
Reading, PA
Posts 8,237
 Sounds about right, especially for the Stewart, Now put a decent size train behind them and check again - it will be higher, but not that much. Sorta confirms my overkill theory - no you do NOT need an 8 amp booster to run 4 HO or N scale trains. You don't even need a 5 amp booster.
                              --Randy
11-03-2009 12:17 PM In reply to
Offline fwright
Top 150 Contributor
Joined on 11-30-2002
Colorado
Posts 2,499
trnj:
TRNJ
I could be wrong, but I suspect the decimal point is a typo/misread.  I would expect readings from 0.2 to 0.4 amps for most modern HO locomotives.  If the 0.02 and 0.04 amp readings are correct, then there is an error somewhere.
just my experiences
Fred W
11-03-2009 2:41 PM In reply to
Top 50 Contributor
Posts 5,528
Fred, you are wrong in this case, I am afraid.   The decimal is not in the wrong place as the meter reads to the 100th of an amp.
I have been a user of this product from it's inception.  You will see that Kato and Atlas units draw next to nothing, while Athearns will pull .2-.3 amps free and more under load.
There is a misconception about what a loco draws.  People tend to round up to the nearest tenth of an amp to err on the high side.  The fact is that modern locos with modern drives pull very little power.
David B
11-04-2009 10:15 AM In reply to
Offline fwright
Top 150 Contributor
Colorado
Posts 2,499
David
After doing some checking, I have concluded you are right and I was wrong.  I did not believe that newer drives had gotten below the 100ma threshold under normal conditions.  Doesn't matter whether on DC or DCC, the average current draw of the motor should be the same.  This analysis assumes decoder current is negligible in comparison, which should be correct for a non-sound decoder.  If decoder current was significant, decoder overheating would be an issue.
In checking, I noticed that Model Railroader reviews no longer include DC current draws while running - just slip and stall.  I had to go back to my '90s issues to find reviews that included current draws while running light.  And lo and behold, I came across several examples of reviews of locomotives drawing 20-40ma while running light.
my apologies
Fred W
11-04-2009 12:57 PM In reply to
Top 50 Contributor
Posts 5,528
 No problem.
Please note that a sound system doesnt add anything measurable to the current draw of the locomotive.  The only real factor is the motor and the number of lights.
David B
11-04-2009 1:15 PM In reply to
Offline mreagant
Not Ranked
Joined on 01-09-2008
Posts 342
Very interesting information.  How, exactly, would I measure amp draw on a locomotive using a standard mulit-meter?
11-04-2009 7:28 PM In reply to
Offline larak
Top 500 Contributor
Joined on 10-03-2005
Ulster Co. NY
Posts 1,253
Put it in series with one rail and use AC mode. The values will not be precise due to the waveform but are OK for relative indications. You might want to borrow a DCC meter for comparison and create a conversion chart for your meter.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
