Locomotives
The power that moves the nation’s freight and passenger trains every day. Find out about new locomotives, the fate of old favorites, and ask experts about locomotive performance. If you're new here, please read our forum policies.
Last post 11-18-2009 10:20 PM by erikem. 28 replies.
Rate:
Sort Posts:
Page 1 of 2 (29 items) 1 2 Next >
11-02-2009 8:22 PM
Offline wholeman
Not Ranked
Joined on 08-30-2008
Southeast Kansas
Posts 497
Two Cycle Diesel Locomotive
Someone told me that the older diesel prime movers were two stroke (mixing oil and gas).  Is this true?  If so, when did they switch to four stroke prime movers?
11-02-2009 8:33 PM In reply to
Offline tomikawaTT
Top 25 Contributor
Joined on 02-12-2005
Southwest US
Posts 7,248
Re: Two Cycle Diesel Locomotive
Fairbanks-Morse locomotives had opposed-piston prime movers (2 pistons in each cylinder, gear-connected crankshafts top and bottom, no cylinder heads, no valve train - the pistons uncovered ports in the cylinder walls at the bottom of their 'away' strokes.)
F-M never switched.  They just got out of the locomotive business.
Chuck
11-02-2009 9:17 PM In reply to
Offline JamesP
Not Ranked
Joined on 02-16-2007
Northview, Missouri
Posts 69
Not only were Fairbanks Morse Opposed Pistons two-cycle, but EMD is known for their two-cycle prime movers, notably the 567 and 645 series engines.  A two stroke EMD or Detroit diesel isn't like a weed trimmer engine, they don't use the crankcase for aspiration.  The engines have poppet valves in the head for exhaust just like a four-cycle and ports in the side of the cylinder for fresh air intake like any other two cycle.  However, the ports are connected to a manifold that is pressurized by a supercharger (and sometimes use an overrunning clutch setup so an exhaust turbocharger can spin the supercharger faster than the crankshaft can).  The crankcase has oil like a four-cycle.  The engine has a camshafts driven at crankshaft speed to open the exhaust valves every revolution.
 - James
11-02-2009 9:36 PM In reply to
Offline JamesP
Not Ranked
Northview, Missouri
Posts 69
To answer the other part of your question, I believe that EMD still offers the 2-cycle 710 prime mover in addition to its H Series 4-cycle prime mover, depending on what locomotive is ordered.  Hopefully, somebody more knowledgeable in current EMD products will shed some light on which prime mover is in what locomotive model...
 - James
11-02-2009 9:54 PM In reply to
Offline creepycrank
Not Ranked
Joined on 01-13-2009
Poulsbo, WA
Posts 113
wholeman:
By "gas" I assume you mean gasoline which is never used in the diesel cycle. EMD's have been and are two stoke uniflow diesels since 1934. Number 2 diesel fuel is very like home heating oil and is what all railroads are runing on. Some times its called "gasoil". The EMD's have run on everything from FP5 navy fuel up to bunker C heavy oil. The diesel engine requires that the air charge is compressed enough that the heat generated is hot enough so that the fuel will ignite when its sprayed in. Diesels are also referred as compression ignition engines-no spark plugs. All the other locomotive builders except Fairanks Morse, lacked the imagination to build anuthing but 4 stroke engines.
11-02-2009 11:07 PM In reply to
Offline MJChittick
Not Ranked
Joined on 07-16-2006
Central New York
Posts 211
JamesP:
The only prime mover EMD currently offers is the two-cycle 710.  The 265H-II four-cycle prime mover was offered in the SD90MAC but that model is no longer in production.  However, it is being built under license in China for that market.
11-03-2009 7:19 AM In reply to
Offline tdmidget
Not Ranked
Joined on 12-04-2004
Posts 129
While I don't doubt that there have been experiments and attempts to use low grade fuels like Bunker C ( also known as  no.6 fuel oil) I am sure that no one has been successful. This "oil" is solid at room temperature or nearly so and very abrasive due to a high solids content. IF you could heat it enough to pass through an injector it would rapidly wear it out. It is a senseless exercise since you would have to flush the fuel system with no 2 or other liquid fuel before shutdown, spend a fortune on apparatus to heat and filter the fuel, and deal with accelerated wear and maintainance IF it worked. To top it off there would be little economic bebefit since modern refining produces very little of it and there not such a price difference as in steam days when it was competitive with coal.
I do know that Alco marine engines fully warmed up and heating the fuel have used oils as heavy as no 3 and 4 but only under ideal conditions.
11-03-2009 11:57 AM In reply to
Offline silicon212
Not Ranked
Joined on 12-16-2004
Mesa, AZ
Posts 680
wholeman:
 Wholeman,
The EMD two stroke engine is of a uniflow scavenge design.  This means that, unlike your gasoline two stroke, the crankcase is not involved in the induction/scavenging aspects of the engine's running.  This allows the engine to be lubricated under pressure, like the engine in your car.  Therefore, there is no need to mix oil with fuel.  I'm not going to go into the technical details of either design, but the uniflow design allows charged air entering through ports at the bottom of the cylinder (uncovered by the piston) to push the spent fuel (exhaust) up and out through 4 camshaft operated poppet valves in the cylinder head.
 Unlike the crossflow two stroke (your chainsaw, dirt bike etc), the uniflow engine isn't necessarily a simpler design than a 4 stroke, it just allows the engine to make more power with less use of space than a comparably powerful 4 stroke.
11-04-2009 10:17 AM In reply to
Offline CSSHEGEWISCH
Top 50 Contributor
Joined on 12-21-2001
Burbank IL (near Clearing)
Posts 5,197
Some of the very large marine diesels  http://people.bath.ac.uk/ccsshb/12cyl/  use a lower grade of fuel oil that's closer to Bunker C than No. 2 diesel oil.
11-04-2009 11:05 AM In reply to
Offline Paul_D_North_Jr
Top 150 Contributor
Joined on 10-11-2006
Allentown, PA
Posts 2,627
Let's review and list the functions/ events that occur during each stroke as follows, as I understand it:
For a 4-stroke:
Up 1 = Compress to ignite
Down 1 = Power by expanding
Up 2 = Exhaust push out
Down 2 = Intake fresh air
REPEAT . . .
For a 2-stroke:
Up = Exhaust push out - valves close - Compress to ignite
Down = Power by expanding - valves open - Intake fresh air
REPEAT . . .
Any additions/ corrections/ clarifications ?
- Paul North.
11-04-2009 3:16 PM In reply to
Offline The Butler
Not Ranked
Joined on 07-03-2008
Southeast Missouri
Posts 127
wholeman:
Thanks for asking that question!  I always assumed "two-stroke" meant fuel/oil mixture and wondered how EMD pull that off.
11-04-2009 5:14 PM In reply to
Offline wholeman
Not Ranked
Southeast Kansas
Posts 497
I also found this information.  http://science.howstuffworks.com/diesel-locomotive4.htm  It could use some clarification to avoid confusing the general public.
11-04-2009 6:09 PM In reply to
Offline tleary01
Not Ranked
Joined on 02-23-2009
Papillion (Omaha) NE
Posts 36
I agree with wholeman It could use some (a lot of) clarification to avoid confusing the general public.  The statement that a 4 stroke cycle engine of the same size as the EMD 2 stroke cycle engine cannot produce comparible power is dead wrong. The General Motors (actually Winton)originated 2 stroke cycle engine has a long history of excellent performance in locomotive service but it is not the only show in town.  A Fairbanks Morse engine though of the opposed piston type is also a 2 stroke cycle port scavengd engine.  And in particular the GE 7 FDL 4 stroke cycle engines since the 1980's have proven their performance is equally as good with higher HP ratings compared to competitve EMD engines.
11-04-2009 7:01 PM In reply to
Offline silicon212
Not Ranked
Mesa, AZ
Posts 680
tleary01:
 The 7FDL is 15.7 liters / cylinder while the 710 is 11.7 liters / cyl.  Not the same size.  Another thing to consider is that top speed of the 710 is 900 RPM, top speed of the 7FDL is 1050 RPM.
11-04-2009 7:09 PM In reply to
Offline tleary01
Not Ranked
Posts 36
But also consider that a 2 stroke cycle engine produces a power stroke each revolution whereas the 4 stroke cycle produces a power stroke every 2 revolutions.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
Subscriber and Member Login
E-mail Address:
Password:
Remember me
My Profile
Screenname: (get your screenname)
Search Community
in
