Toy train operating and collecting
Interested in O gauge, S gauge, and Standard gauge toy trains? Are you a fan of Lionel, MTH, American Flyer, and other brands of toy trains made today and in the past? If so, the Classic Toy Trains Toy train operating and collecting forum is just for you. If you're new here, please read our forum policies.
Last post 11-09-2009 3:53 PM by lionelsoni. 40 replies.
Rate:
Sort Posts:
Page 2 of 3 (41 items) < Previous 1 2 3 Next >
11-04-2009 7:35 AM In reply to
Offline fifedog
Top 100 Contributor
Joined on 04-06-2006
Posts 3,191
Re: Seeking help with R-O-W 4040 signals
lionelsoni - "Spot Relay" was Right-Of-Way's term on the packaging schematic.
Here is what is printed on the other side of the relay: (in white lettering)
Potter & Brumfield
KHAU-17A11-12
12V 50/60Hz
1/10HP, 3A, 120VAC
3A, 28VDC, RES.
MADE IN MEXICO
9612
Hope this unlocks some mysteries...
11-04-2009 8:17 AM In reply to
Offline green97probe
Top 500 Contributor
Joined on 01-03-2003
PA
Posts 1,099
Fife,
         I ran the info, and here is what I found. Hope this helps.
http://relays.tycoelectronics.com/datasheets/KHA_DS.pdf
11-04-2009 8:25 AM In reply to
Offline fifedog
Top 100 Contributor
Posts 3,191
Yup, that appears to be the critter.  Now I just need to know how to wire the bugger...
11-04-2009 8:43 AM In reply to
Top 500 Contributor
PA
Posts 1,099
Fife,
       You need to use a rectifier between the power supply and the relay
 1. Connect pin 13 to the positive terminal of the rectifier.
2. Connect pin 14 to the insulated rail through the negative terminal of the rectifier. The uninsulated rail must have a common ground with the negative terminal of the power supply.
3. Connect the black wire from the signal to the negative terminal of the power supply.
4. Connect pin 9 to the positive terminal of the power supply.
5. Connect the green wire from the signal to pin 1.
6. Connect the red wire from the signal to pin 5.
11-04-2009 11:13 AM In reply to
Offline fifedog
Top 100 Contributor
Posts 3,191
probe - what type of rectifier did you have in mind (think small, think Radio Shack)?  Can I use just one, or do I need a rectifier wired to each signal?  Keep in mind, that when I had these same signals hooked up before, I didn't wire in a rectifier...was I just lucky?
11-04-2009 11:21 AM In reply to
Top 500 Contributor
PA
Posts 1,099
Fife,
          I usually go to Radio Shack to get the full wave bridge rectifiers. I use ones that are rated at 4 amps to be safe. You could connect several relays to one rectifier.  If you powered that relay without a rectifier, the relay might be dead now. If it still works, go play the lottery.
11-04-2009 11:24 AM In reply to
Top 500 Contributor
PA
Posts 1,099
Fife,
        I just read the datasheet again, and it says AC voltage can be used to power the coil, so the rectifier isn't absolutely necessary. Sorry about that.
11-04-2009 11:30 AM In reply to
Offline fifedog
Top 100 Contributor
Posts 3,191
I'm below a novice when it comes to electronics, so no apologies needed.  I appreciate your time and your guidance.  Let's hope this works.
11-04-2009 4:05 PM In reply to
Offline lionelsoni
Top 25 Contributor
Joined on 12-27-2001
Austin, TX
Posts 6,363
Here's how I would wire it:
outside rails----transformer common
accessory transformer 12 V or center rail----relay coil 13 (or 14)
relay coil 14 (or 13, respectively)----control rail
accessory transformer 12 V or center rail----relay C terminal 12
relay NO terminal 8----signal red wire
relay NC terminal 4----signal green wire
signal black wire----transformer common or outside rails.
11-04-2009 8:52 PM In reply to
Offline 8ntruck
Not Ranked
Joined on 01-02-2009
Posts 301
I enlarged the picture of the signal,  There is indeed a yellow light.  Looks like the signal itself may have some hidden features too.
What I had described was assuming an AC relay, and two lights.  After seeing a picture of the other side of the relay, my suggested wiring scheme will not work - I guessed wrong for the common terminal.  Sorry.
11-05-2009 8:27 AM In reply to
Offline fifedog
Top 100 Contributor
Posts 3,191
lionelsoni - Your last suggestion puts us back at square one.  That is the schematic that the signals came with, and yet, as soon as you connect 13 to the control rail, the signal stays on red, and won't change.  Yes, the rail is insulated on both ends.
We're just missing a step somewhere.
11-05-2009 10:01 AM In reply to
Offline fifedog
Top 100 Contributor
Posts 3,191
probe - Tried your idea of useing the odd posts (1, 5, 9, 13, 14 to insulated), which netted the same results, just on the other side of the relay.
Back to the drawing board...
11-05-2009 10:41 AM In reply to
Top 500 Contributor
PA
Posts 1,099
Fife,
       I am starting to think that the relay is defective.
11-05-2009 10:53 AM In reply to
Offline fifedog
Top 100 Contributor
Posts 3,191
If it were just one, I'd agree.  However, I have 4 currently on the layout, and they are all responding the same.
Perhaps use a separate power source than the Z4000...?
11-05-2009 3:37 PM In reply to
Offline lionelsoni
Top 25 Contributor
Austin, TX
Posts 6,363
It's got to be the control rail.  With no train present, the control rail is just a piece of metal (supposedly) not connected to anything electrically.  Is it perhaps crimped into a metal tie?  If so, is the insulator good?
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
Subscriber and Member Login
E-mail Address:
Password:
Remember me
Free Newsletter
Get our free monthly newsletter delivered to your inbox
My Profile
Screenname: (get your screenname)
Search Community
in
