General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 11-05-2009 5:10 PM by GregS. 14 replies.
Rate:
Sort Posts:
Page 1 of 1 (15 items)
10-30-2009 9:58 AM
Offline GregS
Not Ranked
Joined on 10-21-2009
Hawthorn Woods, IL
Posts 6
Brass Engine and Foam Inserts
 I have had some brass that I purchased new back in the 60's and 70's. I had big plans back then. These engines were packaged in their original boxes about 20 years ago and put in storage. I have opened them up recently and found that some of the foam has deteriorated and stuck to the brass. I have been able to brush most of it off, but the brass is a bit discolored where the foam stuck to it. Is there any way to remove that discoloration? Also, one of the engines has some greenish blue crystals forming on the boiler front. Does anyone know what kind of reaction took place and what solvent to use to remove the crystals? Thank you for any help you can offer.
10-30-2009 10:26 AM In reply to
Offline 7j43k
Not Ranked
Joined on 05-28-2004
Posts 578
Re: Brass Engine and Foam Inserts
This subject (foam + brass) has been kicked around over the years on the forums. You might do a search on this one and/or the Atlas one. My general impression is that if/when you want to paint them, you wash off the foam bits with an appropriate solvent. If you want shiny brass instead, it's strip off any clear paint, polish, and re-paint (might as well just paint the critters in color).
Now, those blue crystals, that's new. I think. The color sounds like there's a copper salt there, probably from the brass. I would guess that someone didn't clean some flux off properly. My guess would be to mechanically clean it off, and then apply the appropriate solvent. Which one? Don't know. I figure it'll either wash off with detergent and water, or it'll take a "strong" solvent like xylene or acetone.
Ed
10-30-2009 4:50 PM In reply to
Offline GregS
Not Ranked
Hawthorn Woods, IL
Posts 6
 Thanks Ed. The foam came off with a dry paintbrush. Those crystals are right around a solder joint, so maybe it is from the flux. I was just a little afraid to use anything stronger than alcohol at first. The engines are unpainted, so the darkened areas should be covered anyway.
10-30-2009 4:56 PM In reply to
Offline Darth Santa Fe
Top 150 Contributor
Joined on 06-21-2005
Posts 2,275
Is the metal itself discolored? Or is there a clear lacquer coat over the whole thing? If it's a clear coat that's been discolored, it can simply be stripped off with something like lacquer thinner, and then a new coat can be added if you want to maintain the brass color.
10-30-2009 7:35 PM In reply to
Offline tatans
Top 100 Contributor
Joined on 05-07-2004
Posts 3,082
I would think the value of the brass locomotive just dropped considerably after being stuffed away in a non-protected container for that length of time, you and many others are in for a big surprise when these dinosaurs actually see daylight covered in green kryptonite and large chunks of foam welded to the brass, good luck.
10-30-2009 7:50 PM In reply to
Offline 8500HPGASTURBINE
Top 500 Contributor
Joined on 11-08-2003
PA
Posts 1,420
tatans:
I don't think so. Almost 70% of the brass that's sold on Ebay has some sort of tarnish from old foam. It doesn't hurt the value to me at all. In fact most real MRR'S don't run unpainted brass models on there layout, it looks stupid. So with a painting in order after buying it I wouldn't care of glue was stuck to the brass engine. It has to be cleaned anyhow, primed and painted. So anything like tarnish will be covered over.
Mike
10-30-2009 9:54 PM In reply to
Offline CB&Q Modeler
Not Ranked
Joined on 01-20-2009
Posts 84
Running unpainted brass looks stupid! Now thats just a bit harsh wouldn't ya say....
I've run one or two of my brass (unpainted) and never recieved a dorogatory response from viewers and as the old saying goes.......There's a prototype for just about anything bub.
10-31-2009 5:29 AM In reply to
Top 500 Contributor
PA
Posts 1,420
CB&Q Modeler:
Didn't mean it to come across like that . But most unpainted brass doesn't see a lot of time on a home or club layouts
Mike
11-02-2009 4:46 PM In reply to
Offline GregS
Not Ranked
Hawthorn Woods, IL
Posts 6
Thank you to everyone who offered constructive advice. Ed, I already thanked. Darth, I think you are right. It is the lacquer that is discolored, not really the brass. Mike, you echo'd my feeling that if it is going to be painted, it really doesn't matter. CB&Q, LOL, Thanks for making me smile. And Tatans, the first two have already sold for more than you can afford. But thanks for your opinion.
11-02-2009 6:19 PM In reply to
Top 500 Contributor
PA
Posts 1,420
Greg,
  At least you don't have to strip it. Just etch it, prime it, & paint it. If you need some ideas just send me an email. I have painted MANY MANY brass engines.
Mike
UPGASTURBINE@AOL.COM
11-02-2009 9:32 PM In reply to
Offline maxman
Top 500 Contributor
Joined on 02-15-2008
Posts 868
CB&Q Modeler:
Yes, but is not the engine in this picture actually painted and lettered?  :)
11-03-2009 2:58 PM In reply to
Offline GregS
Not Ranked
Hawthorn Woods, IL
Posts 6
Thanks Mike, but I am getting out of the "large railroad" hobby. I will just keep a few things that can be used on a traction railroad that I may build. The rest will be sold.
11-03-2009 8:34 PM In reply to
Offline twhite
Top 50 Contributor
Joined on 07-07-2004
Carmichael, CA
Posts 6,339
maxman:
CB&Q Modeler:
Nah, it's just got the largest set of decals that MicroScale ever produced, LOL!
11-04-2009 12:44 PM In reply to
Offline ALCOS4EVER
Not Ranked
Joined on 09-04-2008
Posts 36
There is a company in Massachuesetts I believe called Reboxx. They make replacement boxes with non reactive foam inserts just for brass locomotives. They may be able to offer some suggestions on removing stuck on foam and staining.
11-05-2009 5:10 PM In reply to
Offline GregS
Not Ranked
Hawthorn Woods, IL
Posts 6
 Alco, I am amazed that anyone even does this! You get the Award for "Most Unexpected Help From a Model Railroader"
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
