Layouts and layout building
Benchwork, scenery, track, and more. If you're building a scale model train layout, this is where to go. If you're new here, please read our forum policies.
Last post 10-31-2009 12:41 AM by willy6. 10 replies.
Rate:
Sort Posts:
Page 1 of 1 (11 items)
10-30-2009 4:07 AM
Offline rjake4454
Not Ranked
Joined on 03-10-2009
Posts 562
Cat litter for ballast?
I actually noticed today that cat litter up close looks far more realistic than WS ballast. Has anybody ever used cat litter for their layout? I want to use it for mine, it looks great, but I'm a little embarrased about it, plus it smells like baby powder..
But so far, I'm really impressed with the rocky appearance.
10-30-2009 5:57 AM In reply to
Offline HHPATH56
Not Ranked
Joined on 03-04-2007
Posts 565
Re: Cat litter for ballast?
I put it a coffee bean grinder to reduce the size of the pellets. Be sure that it is well glued in place, and well vacuumed, before running a loco over it. Yes, it is a good cheap way to pour ballast, if it is well "wetted" before applying the glue. Bob hahn
10-30-2009 8:17 AM In reply to
Offline pastorbob
Top 500 Contributor
Joined on 12-03-2002
Posts 859
Might want to make sure no cat has access to your railroad room.
Bob
10-30-2009 8:31 AM In reply to
Offline jwhitten
Top 500 Contributor
Joined on 04-18-2008
Northern VA
Posts 1,195
rjake4454:
Yeah I tried it. Now I have a new industry on my layout.... kitty litter in, loads out....
10-30-2009 9:57 AM In reply to
Offline rjake4454
Not Ranked
Posts 562
pastorbob:
10-30-2009 10:02 AM In reply to
Offline rjake4454
Not Ranked
Posts 562
jwhitten:
10-30-2009 10:30 AM In reply to
Offline chatanuga
Not Ranked
Joined on 01-02-2002
Hilliard, Ohio
Posts 494
Being a cat owner, here are two things to watch out for if you're using kitty litter as ballast.
1.  A lot of kitty litter has blue or white deodorizing crystals mixed in with the litter.
2.  Do not use clumping kitty litter since it goes into a mushy state before it dries into a solid blob.
Kevin
10-30-2009 10:46 AM In reply to
Offline cacole
Top 10 Contributor
Joined on 07-23-2003
Sierra Vista, Arizona
Posts 9,337
 Only one brand of cat litter is suitable for use as ballast -- Cat's Pride, because it is ground up kaolin clay that does not clump or swell up when wet.  Other brands will just turn into a messy glob.
It's also great for absorbing oil spills in your garage or carport because it's made by Oil-Dri Corporation, whose specialty is actually the cleanup of oil spills and not cat litter.  The litter is just a sideline for them.
10-30-2009 2:48 PM In reply to
Offline WP&P
Not Ranked
Joined on 08-31-2007
Ohio
Posts 59
 I've long been using clumping litter (the kind you're being encouraged to avoid) for another purpose - as a component of my Cell-U-Clay-based ground goop.  It imparts a limestone color and texture, allowing me to craft rock faces "carved" in place.  Actually, it's more like sculpting in place; I use a plastic spoon to both hold the material and to trowel it on, working in strata lines with the edge.  The conbination of Cell-U-Clay's lumpiness and the litter's grittiness and tendency to crack results in good-looking stone surfaces with relatively little effort.  Of course, one can fine tune later on just by carving when dry, or by re-wetting and working it additionally; this must be done with large cracks (that do develop) to close them up, but the reworking just makes it look better still.
As a ballast material, one might consider using clumping litter as an admixture to other non-dissolving ballast, since the clumping litter will soak in the glue and will itself act as a glue for the rest. Mixing litter with other materials will dilute the smell, and give you better control over color & texture, while extending the amount of coverage you get out of the more expensive ballast.
10-30-2009 8:22 PM In reply to
Offline jeffrey-wimberly
Top 10 Contributor
Joined on 06-21-2004
Sundown, Louisiana
Posts 13,327
cacole:
 Only one brand of cat litter is suitable for use as ballast -- Cat's Pride, because it is ground up kaolin clay that does not clump or swell up when wet.  I ground up the litter between to cement blocks. Just put some on one block, place the other block on top and move it back and forth a few times. Other brands will just turn into a messy glob.
Ditto! Cat's Pride worked well for me many years ago. I've tried some other brands but many of the just broke up after they were wetted and before the glue was even applied.
10-31-2009 12:41 AM In reply to
Offline willy6
Not Ranked
Joined on 01-27-2003
Ridgeville,South Carolina
Posts 703
I would be watchful if your running a "Chessie" themed layout especially if the locomotive stops and starts scratching the roadbed.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
