Thanks, Mike. Judging from pictures, I'm guessing the height would be about 4-4.5 also?? Unit is already on a 12" x 12" .100 styrene base, which can be extended (i.e., patched onto). Once building configuration and size is figured, I'll be constructing the foundation (.125 styrene) and the roof. Base to rail top in dump cylinder is about 1", so the base will end up below grade, Project follows no prototype and is crude enough that it MUST be totally enclosed. That's what I get for working without plans and engineering on the run. The only documentation on paper is the wiring schematic. It is all powered, with top car clamp, operating door, and rotating drum sequencing in that order. Once it's all done, the next step will be to get started on the layout it will end up on...
Thanks again for the info...Gary
