Toy train operating and collecting
Interested in O gauge, S gauge, and Standard gauge toy trains? Are you a fan of Lionel, MTH, American Flyer, and other brands of toy trains made today and in the past? If so, the Classic Toy Trains Toy train operating and collecting forum is just for you. If you're new here, please read our forum policies.
Last post 10-26-2009 9:19 PM by LL675. 7 replies.
Rate:
Sort Posts:
Page 1 of 1 (8 items)
10-25-2009 3:29 PM
Offline Civil War
Not Ranked
Joined on 01-05-2009
Posts 177
736 Berkshire on O27 layout
 I would love to add a 736 Berkshire to my layout, but I have mostly 027 track except for my passenger line that has 042 curves and no switches. Can I run this engine on my 027 section with 1122 switches? I notice the two center driving wheels have no flanges. Will this allow it to navagate 027 track? I suspect the problem will be the switches.
 Thanks
10-25-2009 3:52 PM In reply to
Offline green97probe
Top 500 Contributor
Joined on 01-03-2003
PA
Posts 1,308
Re: 736 Berkshire on O27 layout
Terry,
          I think that the long wheelbase of the 736 will make operation on 027 curves difficult if it is even possible. I've never tried running my 736 on anything other than 031, so I can't be 100% sure.
10-25-2009 5:02 PM In reply to
Offline kehoesj
Not Ranked
Joined on 02-25-2001
MP53 - CNW Pennisula 400
Posts 104
I have the 726 Berk and it does run on my O27 layout satisfactorily.  Care needs to be observed as it travels through switches -  speed restricted zone is enforced to avoid any derailments.  The 726 is probably one of my favorites of my collection.  1947 vintage is matched up with a 1997 Railsounds diecast tender, so there is a bit of weight going thru those O27 curves...
10-25-2009 6:15 PM In reply to
Offline alank
Not Ranked
Joined on 08-02-2003
Posts 75
I have a 726 engine that I use on 027 track with 1122 switches with no problem.  I don't see why a 736 shouldn't negotiate the switches.
10-25-2009 7:42 PM In reply to
Offline alank
Not Ranked
Posts 75
As I stated in my previous reply, I have a 726 which I use on an 027 layout and using 1122 switches with no problem.   The 736 however has magnetraction, and it got me thinking of the cintered drivers.  Using my Greenbergs's Repair Manual, I tried to see if I could determine what difference there may be between a 2035/2046 cintered driver and a 736 cintered driver with regards to flange.   I couldn't.   However reading the section on 736/746, it is under the 746 that it says the motor on the 736 is identical to the 746 motor.   Later it says the size of the locomotive makes it unsuitable for use on 027 layouts, as the collector rollers will short the frog rail to the swivel rail when negotiating curved switch branches.   I haven't experienced this with my 726, but before taking my thoughts based on my 726 experience, I would want to hear from someone who has experience of a 736 using 027 and 1122 switches.
10-25-2009 10:28 PM In reply to
Offline ADCX Rob
Top 500 Contributor
Joined on 12-27-2005
Hopewell, NY
Posts 1,194
alank:
...before taking my thoughts based on my 726 experience, I would want to hear from someone who has experience of a 736 using 027 and 1122 switches.
I've been doing it since at least 1972, no problems with 1122E switches, sometimes the running gear will bop a housing on an 1122 switch.  No damage, though.
Rob
10-25-2009 10:47 PM In reply to
Offline lionelsoni
Top 25 Contributor
Joined on 12-27-2001
Austin, TX
Posts 6,885
Generally, steam locomotives have an easy time with the switch machines on 1022 turnouts and 5121-5122 turnouts with the flag removed.  The bottom inch or so is all wheels, which tend to stay with the track.  I run a Big Boy through O27 turnouts with no problem.
The 736's pickup rollers are unfortunately not between the flanged drivers, which is the ideal location for them because it keeps them right at the center of the track, no matter what the curve is.  They are each a little forward of the drivers; so the wander away from the center rail somewhat on curves.  This can cause trouble on O27 turnouts; but I don't know how serious it might be with this locomotive.
10-26-2009 9:19 PM In reply to
Offline LL675
Not Ranked
Joined on 06-04-2002
Ohio Valley
Posts 281
my 736 (and all my Postwar steamers) run fine on my O27 tube track and 1121,1122,1024, and manual Marx switches.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
Subscriber and Member Login
E-mail Address:
Password:
Remember me
Free Newsletter
Get our free monthly newsletter delivered to your inbox
My Profile
Screenname: (get your screenname)
Search Community
in
