Locomotives
The power that moves the nation’s freight and passenger trains every day. Find out about new locomotives, the fate of old favorites, and ask experts about locomotive performance. If you're new here, please read our forum policies.
Last post 11-16-2009 10:44 PM by monon99. 20 replies.
Rate:
Sort Posts:
Page 2 of 2 (21 items) < Previous 1 2
11-02-2009 3:17 PM In reply to
Offline BNSFwatcher
Not Ranked
Joined on 05-27-2009
Posts 290
Re: when to use 4 axles or 6
With the downturn in business, a lot of older EMD 4-axle units have been 'mothballed'.  Our Sweetgrass and Great Falls Div. branches, out of Shelby, MT (on the High Line) now sport a lot of Dash 9-44CW, etc., where the GP-38 once reigned.  These are not "132# gorilla" branches, but the loco count is down.  We even have some (Yuck!) SD-70Ms, etc., coming up on coal trains, heading west, much to the chagrin of the MRL.  The dedicated 'switchers' are history, being replaced by GP-38s.  This is DP territory, with locos being dropped off or added to the unit trains.  Wish we had a "Dedicated Hostler" who really knew how to set up DP units!  Guess "Mechanical", in Fort Worth does, too!!!
11-02-2009 10:11 PM In reply to
Offline GP40-2
Not Ranked
Joined on 07-11-2004
Posts 494
Just use 6 axle AC power on everything like CSX does. That way you never have to worry about outdated 4 or 6 axle DC locomotive issues. LOL.
11-03-2009 9:57 AM In reply to
Offline tree68
Top 25 Contributor
Joined on 12-25-2001
Northern New York
Posts 8,655
GP40-2:
That may be true on the mains, but there's still some '38's working on CSX.
11-03-2009 1:51 PM In reply to
Offline joesap1
Not Ranked
Joined on 11-16-2003
Tulsa, OK
Posts 109
On the railroad where I 'm employed we use 4 axle power on tracks which have worn rail and ties. Six axle power is much harder on rail and ties, especially on curves.
11-04-2009 10:23 AM In reply to
Offline CSSHEGEWISCH
Top 50 Contributor
Joined on 12-21-2001
Burbank IL (near Clearing)
Posts 5,197
joesap1:
Sounds like what happened on D&RGW's Monarch branch.  It was standard-gauged in the mid-1950's and the original plan was to use SD7's because of the grades (up to 4%).  However, the long wheelbase caused derailments on some of the curves so GP9's became the standard power on the branch.
11-16-2009 10:44 PM In reply to
Offline monon99
Not Ranked
Joined on 12-30-2008
Posts 12
 There's a rickety iron bridge in Indy that was too weak to haul fully loaded covered hoppers over,so they were partly unloaded and the excess trucked around,of course we had 4 axle locomotives which had greater loading per axle than those hoppers! We would pray before we crossed. Some clever railroads would put a spacer car between the engines and run long jumper cables across a flat car or through a coach to spread the weight out across the bridge. Of course proper bridge maintenance would solve this issue!
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
Subscriber and Member Login
E-mail Address:
Password:
Remember me
My Profile
Screenname: (get your screenname)
Search Community
in
