Electronics and DCC
The place to discuss wiring for DC and DCC controlled model train layouts. If you're new here, please read our forum policies.
Last post 11-04-2009 4:22 PM by chinapig. 10 replies.
Rate:
Sort Posts:
Page 1 of 1 (11 items)
10-24-2009 7:39 AM
Offline chinapig
Not Ranked
Joined on 03-07-2009
Posts 21
Zimo MX620
  Normal 0
Hi Folks,
I purchased a N Scale Con-Cor 2-10-2 on eBay with a Zimo decoder fitted.  After a bit of investigation I’ve deduced it’s a MX620.  I can’t find much documentation on the web but I’m lucky in that I’m using a Digitrax PR3 and JMRI to help program it.  It has got some fields for BEMF but the trouble is I just can’t understand them.  At the moment the loco runs away downhill and slows right down going uphill.  Is there anyone out who has cracked this, please?
Ted
10-24-2009 9:20 AM In reply to
Offline tstage
Top 10 Contributor
Joined on 06-11-2003
Northeast OH
Posts 8,721
Re: Zimo MX620
10-24-2009 10:41 AM In reply to
Offline chinapig
Not Ranked
Posts 21
Re: Zimo MX620
 Thanks Tom.  Both sites look really useful, especially the first.  The second site just rubs in the fact that my four years at German night-school were pretty much a waste of time!  No, it's alright, I've just found the English translation.
Cheers, Ted
10-24-2009 5:24 PM In reply to
Offline blrrfan
Not Ranked
Joined on 07-24-2007
Posts 28
Re: Zimo MX620
10-25-2009 5:29 AM In reply to
Offline chinapig
Not Ranked
Posts 21
Re: Zimo MX620
Many thanks for that link, birrfan.  The problem is that none of the documents are a "Zimo for Dummies".  I mean they start talking about Mantissas.  My son has a Batchelors Degree in Maths and he had't come across them!  I guess it will come down to trial and error, but at least I know what CVs to put on trial.
Many thanks, Ted
10-25-2009 8:00 AM In reply to
Offline blrrfan
Not Ranked
Posts 28
Re: Zimo MX620
That part ("mantissa") is for CV9 and follows the wording from the NMRA RP 9.2.2
see http://www.nmra.org/standards/DCC/standards_rps/rp922.html and scroll to the explanation for "Configuration Variable 9"
NMRA R.P. 9.2.2 (extracted part for CV9):
The value of CV#9 sets the nominal PWM period at the decoder output and therefore the frequency is proportional to the reciprocal of the value. The recommend formula for PWM period should be: PWM period (uS) = (131 + MANTISSA x 4)x 2 EXP ,Where MANTISSA is in bits 0-4 bits of CV#9 (low order) and EXP is bits 5-7 for CV#9. If the value programmed into CV-9 falls outside a decoder's capability, it is suggested (but not required) that the decoder "adjust" the value to the appropriate highest or lowest setting supported by the decoder.
10-25-2009 10:57 AM In reply to
Offline rrinker
Top 25 Contributor
Joined on 02-14-2002
Reading, PA
Posts 7,590
Re: Zimo MX620
 The mantissa is the decimal part of a logarithm - surprised a math major would not know that. However, there is an alternate use in science and computer science which means the significant part of a floating point number. Some scientific calculators have a mantissa button which sets the number of significant digits in results. Yes there is a conflict here with the mathematics definition of the word.
 Based on the expression given in the NMRA RP, they are using the latter definition. SO if the number is 1.53 x 10^-3, the mantissa would be 1.53 and the exp would be -3
 BEMF on Zimo decoders is probably the best there is - however they explain the settings in very scientific terms, and don't reveal the exact equation being used (as this is proprietary information). To truly understand the ideal values for the various BEMF CVs in a Zimo decoder, you need to understand exactly how BEMF calculations are made.
 Or, you can wing it and start plugging in numbers until it runs the way you want. You're not going to burn out the motor with incorrect BEMF settings, it will just run lousy - huge jumps between speed steps, slowing on hills (if the range of settings allows it - maybe even slowing going DOWN hill!) - but the motor won't get excessive voltage or anything, so it's safe to play around. Record the default values if the decoder does not have a reset so you can get back to a known point if you go too far.
                                                   --Randy
10-26-2009 8:26 AM In reply to
Offline chinapig
Not Ranked
Posts 21
Re: Zimo MX620
Randy,
Thanks for that information.  I'm learning more each day but don't think i'm going to delve any deeper!  I'm going to be winging it from here by plugging in values on a trial and error basis.
It's amazing what this hobby of ours exposes us to.
Cheers, Ted
10-26-2009 9:15 AM In reply to
Offline rrinker
Top 25 Contributor
Reading, PA
Posts 7,590
Re: Zimo MX620
This is how I do it, and I even have a degree in electrical engineering (granted, I never took any DC motor courses). Even knowing the equation, the math is nearly beyond me, as I have no used any of that calculus I took oh so many years ago.
I don't have the link handy, but somewhere there is a comparision of the 3 values to a spring, which helps make it make some sense. It's also in the Digitrax documentation except Digitrax decoders only give you control over 2 factors in the equation - they do compare it to a spring, but I know I've seen or read somewhere else how each of the three variables that Zimo allows you to adjust to a spring.
                                   --Randy
11-03-2009 5:22 PM In reply to
Offline aluesch
Not Ranked
Joined on 05-10-2003
CA
Posts 107
Re: Zimo MX620
Hi Ted.
You may have the newer MX620 or an older MX62. The latter can be recoginzed on the ceramic board.
Most people here are talking about BEMF compensation settings (for smooth motor control), which are done automatically on the MX620 but can also be played around with manually using CV #9 and CV #56.
In your case however, I assume you are more concerned with turning  BEMF action ON/OFF or a setting in between. This is done in CV #58 and is quite simple. A value of 0 equals no BEMF and a value of 255 full BEMF function. If you prefer your trains to slow down a bit going uphill, set this CV to a value between 100 and 180.
CV #10 and #113 can also be used to reduce BEMF action above a specific speed. If you don't want/need this function, leave the values at 0.
You can download a MX620 manual here: http://www.mrsonline.net/html/manuals.html
or here: http://www.zimo.at/web2007/content/handbuch.htm
The older MX62 manual can be downloaded from the ZIMO web site, just scroll down to "obsolete Decoders".
Hope that helps!
Art
ZIMO Agency of North America
www.mrsonline.net
11-04-2009 4:22 PM In reply to
Offline chinapig
Not Ranked
Posts 21
Re: Zimo MX620
Thanks for all the help, folks.  I’ve solved my problem.  After tweaking of all the CVs to no affect, I gave up and set them back to the default.  I then adjusted CV5 down to around 100 as the loco had reached its top speed at about half throttle (for some strange reason this loco’s top speed is pretty slow but as it’s a 2-10-2 I’m happy with it).  Low and behold, going down the helix it didn’t speed up.
I guess it was trying to reach its true top speed as set by the throttle – I can’t really explain it technically.
Now that’s solved I can track down and nail some other problems!
Thanks again, Ted
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
