Scratchbuilding and kitbashing
Post ideas and links to garden train projects you've built. Please also share those "unlikely treasures" you've found here! If you're new here, please read our forum policies.
Last post 11-04-2009 12:03 PM by dwbeckett. 7 replies.
Rate:
Sort Posts:
Page 1 of 1 (8 items)
10-15-2009 7:40 PM
Offline IRB Souther Engineer
Not Ranked
Joined on 09-20-2009
Florida
Posts 75
What is the best train car for a beginner to scratchbuild?
What is the best train car for a beginner to scratchbuild? And where can I get the plans?
10-16-2009 2:13 AM In reply to
Offline cabbage
Not Ranked
Joined on 02-27-2005
Peak District UK
Posts 702
Re: What is the best train car for a beginner to scratchbuild?
 Well....
First of all we need some basic information(!)
What sort of railway is it that you are planning to build?
What are the Scale and Gauge of the rolling stock that you want to build?
regards
ralph
10-16-2009 3:26 AM In reply to
Offline altterrain
Top 500 Contributor
Joined on 10-04-2006
silver spring, md
Posts 1,259
 Yes, we need to know your interests. Plastic is typically used to replicate steel and wood is used for wood.  GR has offered many narrow gauge car plans typically made of wood over the years. Large scale narrow gauge runs from 1/13.7 scale for 2 foot narrow gauge and 1:20.3 (the correct scale), 1:22.5 and 1:24 scales for 3 foot narrow gauge.
More modern steel standard gauge car plans have been offered over the years by MR, other mags and online resources. These are typically made in 1/29 (most popular) or 1/32 (correct) scale in large scale.
In either case - simple gondola cars are a good car to start with.
-Brian
10-16-2009 4:21 AM In reply to
Offline gbbari
Not Ranked
Joined on 09-24-2006
Sykesville MD
Posts 142
I agree with Brian - gondola or even a simple flatcar might be the easiest. There are downloadable plans right here on this website - go up to the menu under the picture of the train. Click on "How To & Videos", then "Downloadable Pullout Plans". No gondolas or flatcars but there are two boxcars that should not be too difficult.
AL
10-16-2009 3:42 PM In reply to
Not Ranked
Florida
Posts 75
I have seen that boxbar... it seems hard rather to build.
On this website I also found work cabose plans which seem easier, (you can get to them by clicking "How To & Videos" then construction and Landscaping and finally June 2006 in the archive).
11-04-2009 3:22 AM In reply to
Offline phishplatephan
Not Ranked
Joined on 09-04-2007
Posts 2
Hi, I'm just building my first scratch build cars, a 60 foot Gondola and a 60 foot box car. I wanted some modern looking wagons so I bought two 'HO' cars from my local shop here in the UK and with a set of digital calipers times everything by 3.
I used 8mm perspex to form the frame to give the car strength and so far so good, the measurements were 610mm by 98mm so that when you add the sides using 2mm styrene and then the ribbing it works out at about 110mm which matches the Aristo 53' Evans car.
I drew out an actual size drawing first to plan where the ribs should go and then started from there. I'm using 6.3mm OD brass tube (27mm in length) glued into the perspex to for the truck king pin as this is a perfect fit for the USA trains modern truck. An M5 35mm machine screw soldered in forms the fixing that secures the truck to the frame with a 9mm spacer. So far I'm pleased with how far I've got...... and very surprised I've managed what I've achieved with my clumsy fingers!
11-04-2009 7:26 AM In reply to
Offline smcgill
Not Ranked
Joined on 07-11-2003
S.Easton , Mass.
Posts 427
You also need to learn to photograph!!! WEEEEE all want pics!!!!!! This is the learning curve! Then you need to learn how to post those pics! Then we will all give you our 2 cents weather you want it or not. Most will be encouraging and help full ! Oh Ya Welcome!!! Sean
11-04-2009 12:03 PM In reply to
Offline dwbeckett
Top 500 Contributor
Joined on 06-13-2006
Oakley Ca
Posts 917
smcgill:
First to the fourm and I agree with the above comments,
Dave
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
SUBSCRIBER AND MEMBER LOGIN
E-mail Address:
Password:
Remember me
My Profile
Screenname: (get your screenname)
Search Community
in
