General Discussion
The place to discuss railroad industry trends, information about freight railroads, train watching, comments on recent trips, and other railroad topics. If you're new here, please read our forum policies.
Last post 10-11-2009 5:47 PM by cp456. 9 replies.
Rate:
Sort Posts:
Page 1 of 1 (10 items)
09-10-2009 6:56 AM
Offline cp456
Not Ranked
Joined on 09-06-2009
Posts 17
US Steel Canada Dimensional Move
 Does anyone know when the planned US Steel Dimensional train that will run from Nanticoke, ON to it's Hamilton, ON operations will operate?  Apparently it is to consist of two bottle cars and 2 ex Stelco SW 900 yard engines along with several loaded grain hoppers as idlers.  Rail America (SORR) will build the train and make the move along the Hagersville Sub and CN"s Dundas Sub.
Tags:
09-10-2009 9:59 AM In reply to
Offline TH&B
Top 500 Contributor
Joined on 07-10-2003
Posts 965
Re: US Steel Canada Dimensional Move
Is this supposed to be a one time move, or a regular train ?
09-10-2009 10:23 AM In reply to
Offline CSSHEGEWISCH
Top 50 Contributor
Joined on 12-21-2001
Burbank IL (near Clearing)
Posts 5,397
This operation sounds a lot like the bottle train operated for Interlake Steel since at least the mid-1960's and still in operation serving Mittal Steel's Riverdale facility.  I would assume that this will probably be a regular operation.
09-10-2009 1:24 PM In reply to
Offline cp456
Not Ranked
Posts 17
 This is definitely a one time move.  US Steel in Nanticoke, Ontario is currently shutdown due to a labor dispute, while US Steel's plant in Hamilton, Ontario has just resumed to full production.  Of course when the Lake Erie Work's in Nanticoke resumes production, we could see a similar move back that way.
Tags:
09-10-2009 3:44 PM In reply to
Offline igoldberg
Not Ranked
Joined on 06-06-2004
Gettysburg, PA
Posts 555
I am totally amazed that the idler cars are loaded grain hoppers.  Why in havens name would they do that?  The temperature around those cars is terrific so you would not want a car loaded with grain next to one. Empty gondolas or hoppers are used as idler cars to spread the weight of the train not loaded cars.  Wonder what "GENIUS" came up with this brght idea.
09-10-2009 7:57 PM In reply to
Offline cp456
Not Ranked
Posts 17
The bottle cars will be empty.  And they probably weigh close to 350,000 lbs empty.  Idlers are needed to spread the weight over several bridges, etc.  A Rail America Trainman told me that last year when they did a similar move, they used loaded scarp gondolas for idlers but this time apparently there are none readily available, hence the use of loaded grain hoppers.
Tags:
09-20-2009 10:47 AM In reply to
Offline cp456
Not Ranked
Posts 17
 After recently talking with a Rail America (SORR) employee, apparently this special move has already been completed.  The train consisted of two Rail America road units, followed  2 former Stelco SW switchers dead in tow.  Loaded grain cars were used as idlers which  separated each of the 2 empty bottle cars. ( 2 Stelco engines + 5 loaded grain + empty bottle + 5 loaded grain + empty bottle + 5 loaded grain).
The train traveled from US Steel's Lake Erie Works in Nanticoke, Ontario to  US Steel's Hamilton Works in Hamilton, Ontario.  The empty bottle cars and Stelco locomotives will be put in service at Hamilton Works as the plant is apparently quite busy right now.
Last year when they did a similar move, there were several pictures posted on RP.net documenting this move.  I am little shocked that no one from that site posted any pictures of this recent move, when considering it was done in daylight.
09-20-2009 1:34 PM In reply to
Offline cptrainman
Not Ranked
Joined on 02-05-2009
Edmonton AB
Posts 30
5 loaded grain for spacers. Strange.
About two weeks ago I had to marshal 2 320,000 lbs generators. The DimNotice stated spacing the loads out by 1 car < 268,000 lbs. Since most loads are at least 268k, I put empties in as spacers (CYA).
The reason for the special marshaling was for bridges. The combined weight of the cars together, both sitting on/moving over a bridge at the same time, might be too much for some bridges to support.
09-20-2009 3:23 PM In reply to
Offline cp456
Not Ranked
Posts 17
 Since the trip would have to use the CN mainline (Dundas Sub) to reach Hamilton Works, CN stated they wanted 5 loads in between each bottle car.  Since Rail America (SORR) was putting the train together, I was told the only loads readily available were loaded grain cars.  Loaded scrap gondola's were not yet available at US Steel, because at that time they were just preparing to resume production again.
10-11-2009 5:47 PM In reply to
Offline cp456
Not Ranked
Posts 17
 Took a month, but I finally found a picture on the Internet documenting this special move.
http://www.railpictures.net/viewphoto.php?id=296600&nseq=8
 US Steel locomotives dead in tow a next to the road power and the bottle cars are farther back in the train separated by idlers (empty grain cars).
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
Subscriber and Member Login
E-mail Address:
Password:
Remember me
My Profile
Screenname: (get your screenname)
Search Community
in
