Toy train operating and collecting
Interested in O gauge, S gauge, and Standard gauge toy trains? Are you a fan of Lionel, MTH, American Flyer, and other brands of toy trains made today and in the past? If so, the Classic Toy Trains Toy train operating and collecting forum is just for you. If you're new here, please read our forum policies.
Last post 08-16-2009 1:59 PM by lionelsoni. 5 replies.
Rate:
Sort Posts:
Page 1 of 1 (6 items)
08-15-2009 10:34 PM
Offline Fred Bear
Not Ranked
Joined on 01-09-2006
Foothills of Wva
Posts 681
Atlas Wye Switch Spark
My Atlas wye switch is thrown automatically within a double loop, tossing the train to the outside loop, then next pass to the inside loop, etc. It gets it's electric from a series of capacitors, resistors, etc, Bob N helped me with.  It works great. But...it sparks when going from inside to outside, but not outside to inside. It sparks enough that is easy to see and causes a momentary little " glitch " in the electrical system. What would cause this and how could one correct that problem?  Thanks to all responders, Jake
PS. Post War ZW powers the whole show, only one transfomer involved on this layout.
08-16-2009 10:36 AM In reply to
Offline lionelsoni
Top 25 Contributor
Joined on 12-27-2001
Austin, TX
Posts 6,890
Re: Atlas Wye Switch Spark
Where is it that you are seeing the sparks, Jake?
08-16-2009 11:26 AM In reply to
Offline Fred Bear
Not Ranked
Foothills of Wva
Posts 681
The sparks are down near the trucks by the pickups, Pretty fair sparks. Jake
08-16-2009 11:36 AM In reply to
Offline lionelsoni
Top 25 Contributor
Austin, TX
Posts 6,890
If the pickups are sparking, that's a clue that the problem is in the track power, not the switch-motor electrics.  But, just to be sure, with the train not there, try touching a wire between each insulated control rail and a regular outside rail, to see whether the points move properly, without (more than a very little) sparking.  You could also push a car across the trackwork by hand if you like; but it might be a little harder to see any sparks.
If that's okay, then describe for me how you have the track powered.  Is there a change from one transformer output to another as you change loops?  For example, is one loop powered from the A output and the other from the D output of the ZW?
08-16-2009 12:55 PM In reply to
Offline Fred Bear
Not Ranked
Foothills of Wva
Posts 681
No spark with just a car or a wire from insulated rail to outside rail. Both loops are powered by only one output on the ZW. I have droppers at various points, but they are all standard connections and I've check them all. Has to be something within the Atlas switch I'm guessing. Jake
08-16-2009 1:59 PM In reply to
Offline lionelsoni
Top 25 Contributor
Austin, TX
Posts 6,890
Try putting the locomotive in neutral and then pushing it slowly by hand through the trackwork with the voltage on.  You might be able to see where the event is happening that way.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
Subscriber and Member Login
E-mail Address:
Password:
Remember me
Free Newsletter
Get our free monthly newsletter delivered to your inbox
My Profile
Screenname: (get your screenname)
Search Community
in
