Layouts and layout building
Benchwork, scenery, track, and more. If you're building a scale model train layout, this is where to go. If you're new here, please read our forum policies.
Last post 08-03-2009 10:42 AM by MILW-RODR. 12 replies.
Rate:
Sort Posts:
Page 1 of 1 (13 items)
07-30-2009 11:19 PM
Offline 1911 guy
Not Ranked
Joined on 03-08-2009
Posts 9
Code 100 FlexTrack, novice layout. Best switches?
Hello, all.  My son and I (mostly me, he's five) are building a 5 X 10 foot layout in our basement.  We've got a table built and the track plan trammeled out onto hardboard that's going to be the foundation for our cork roadbed.  Trying to stay several steps ahead of where we're at, I need to begin looking for switches.  I'll probably wind up going with either DCC or DCS from MTH, since I like the MTH K-4 and have one ordered.
Since I'll probably go with some sort of digital control, I need some expert (or more informed than me, anyway) advice on where to look for switches and switch machines that will be suitable for what I want to build.
The track plan is a figure eight / oval combination from a Kalmbach book, pretty simple.  I need two left and one right hand and want to be able to throw them from a control panel.  I just don;t want to buy something and find out it won;t work with digital or has to be reworked in a way that's beyond my skill level.  Almost forgot, 22' radius curves all around.  No variance, even into the small yard (one dead end siding)
Thanks.
07-30-2009 11:36 PM In reply to
Offline Sir Madog
Top 500 Contributor
Joined on 03-16-2009
South of the Arctic Circle
Posts 1,659
Re: Code 100 FlexTrack, novice layout. Best switches?
to the forum!
Is there a specific reason, why you have chosen code 100 track? IMHO, code 83 track looks much better and takes just as much care in laying the track than code 100.
In any case, code 100 or code 83 switches are available from Atlas, or Peco or Walthers. I find Peco the most reliable brand, but they are a bit pricier than the other brands.
A word of caution:  MTH´s DCS is not fully compatible with DCC, as your are going to operate not only locos from MTH, DCC, IMHO s the better choice!
07-31-2009 12:52 AM In reply to
Offline 1911 guy
Not Ranked
Posts 9
I chose code 100 based simply on availability.  My local hobby shop always has it on the shelf.  I got a 10% discount for buying the whole box (75 feet) at one time.  If I need more I can get it with a ten minute drive.
Thanks for the brand names on switches.  I read about Atlas switches here and they seemed to perform well for those that had and discussed them, I'll look into them and the Peco.
Another newbie question: How hard is it to install switch motors?  Is it worth buying them already installed?  Does such an option even exist?
Sorry for all the dumb questions, but I figured I'd ask here before I blew money and wasted effort in a losing strategy.
07-31-2009 7:40 AM In reply to
Offline mobilman44
Not Ranked
Joined on 09-17-2003
Southeast Texas
Posts 1,824
Hi!
Welcome to the Forum!   I'm in a hurry now so I'll make it short.  I've used Atlas code 100 stuff for literally decades.  For the money and availability, it can't be beat.  Use their Custom line turnouts (not snap switches) and their offering of switch machines.  The on top the layout machines hook into the turnouts in seconds, and are super reliable.  The under table machines take some time/precision to get them properly installed, but they do a great job.  Also consider the manual throws offered by Caboose Hobbies for turnouts close at hand.  If you do, get the "sprung" ones.
ENJOY,
Mobilman44
07-31-2009 9:35 AM In reply to
Offline MisterBeasley
Top 10 Contributor
Joined on 12-02-2004
Bedford, MA, USA
Posts 9,622
I, too, have used Atlas code 100 track and turnouts for a long time with good results.  Because of limited space, I use a lot of the short-radius "snap switches."  I run short diesels and short (40-foot) freight cars, mostly, and they have no problems with my tight turns.
The snap switches are equivalent to an 18-inch radius curve, so they may not fit your oveall curvature.  On the other hand, the Custom Lines, like most other "prototypical" turnouts, have a very different profile.  When you design your track plan, you need to know which turnouts you will be using.
I've also got a few Peco turnouts.  I started using them because they were the only small-radius curved turnouts available.  I discovered, however, that I really like the turnouts.  They are more solidly built than Atlas.  Also, the switch machine designed for the Peco mounts on the underside of the turnout, so it doesn't appear on top of your layout at all.  After I had most of my Atlas turnouts down, I realized that I hated those switch machines.  I've been making "scenic covers" for most of them, but lately I've switched to all-Peco.
Since you have very few turnouts, and you're reasonably new at this, I would go with Pecos.  They are more expensive, by quite a bit actually, but if you get the Peco turnouts and the switch machines that go with them, you'll have what you need for very reliable remote operation.
Peco switch machines, by the way, need more  of a "kick" from your power supply than others.  I installed a capacitive discharge (CD) circuit to drive them.
Hopefully, someone else will comment on Tortoise "slow motion" switch machines.  These are the most prototypical.  They, too, are pricey, but those who use them love them.  I don't have them, myself, so I really can't comment any more about them.
Finally, I second the suggestion that you go with DCC.  The MTH HO scale engines will run on either DCS or DCC, but any DCC engines you might pick up will not run on DCS.  DCS is a proprietary protocol, so other manufacturers can't use it.  DCC, on the other hand, is an open protocol that anyone can use.  The standards are defined by the NMRA.
07-31-2009 5:21 PM In reply to
Offline locoi1sa
Top 500 Contributor
Joined on 07-13-2006
Posts 1,227
 Code 100 and Peco turnouts are a module club standard that we can not deviate from. Peco turnouts are almost bullet proof. Out of hundreds on our modular layout there has only been 1 turnout failure and that was due to an accident. Pecos do not really need a switch machine to operate. They have a built in over center spring that keeps the points tight against the stock rails. Their INSULFROG turnouts are drop in for DC or DCC with no need for insulated gaps. The ELECTROFROG turnouts need insulated joiners coming out of the frog rails. They are a British standard turnout. That means the flangways are real wide for those British pizza wheel flanges. There is a real easy fix for that. A .015 x .060 styrene strip glued to the guard rail fixes it real nice.
  If you go with DCS than you will be limited to locos from MTH only. With the help of the NMRA the DCC standards of compatibility between decoders and DCC systems has transformed the hobby into the digital age that just keeps getting better and cheaper for us. This is the start of you rail road empire and only you and your son can see it grow or stay the same.  It has been said more than once, No layout is ever finished. You might be happy with a small figure 8 now but a few months or years from now you may be planning a basement empire with a fleet of steam or diesels that MTH may not have.
  Good luck
     Pete
08-01-2009 10:57 PM In reply to
Offline TMarsh
Top 500 Contributor
Joined on 11-23-2008
Little town in ILL
Posts 1,465
Oh my no! Not DCS! I'm not knocking DCS it's probably very good, but for reasons stated already please, please, pulease, for your sake, don't box yourself in by choosing a system that you can use with only one brand of locomotive. Especially on your first layout. DCC I'm sure will make you the most happy and you can use any brand loco including MTH.
As far as turnouts go I second the Atlas. Very reliable for years and years. I have no experience with Peco but have no doubt they are very good also from all that I've heard for so long.
Switch machines, well the above ground switches from Atlas are also very reliable and practically bullet proof and last for what seems ever (36 years and counting) and are simple to install especially if you buy them as a unit. But as Mr B says, I don't like the looks anymore since my goals have changed. Just depends on what you want. I too would recomend Caboose ground throws for the close ones. Less wiring don't ya know, however that's up to you.
Good luck and welcome to the disease, er I mean Hobby!
08-01-2009 11:43 PM In reply to
Offline 1911 guy
Not Ranked
Posts 9
Thanks, everybody.  I'll go with the Atlas switches and above ground machines.  Reliable and simple, I like that.
I had a train set as a kid and have messed around with the idea of making a full fledged layout instead of the once a year around the Christmas tree, but my son is HUGE into trains.  It started with Thomas toys and has moved into anything and everything train related.
I've got all the sub-roadbed cut out and pieced together to make sure it's right, now I'll be making support for the elevation changes.  I left large areas of material (hardboard) uncut around places I'll need switches so I can install them.  I'm putting cork on top of that and the track on the cork.
Scenery is going to wait, because there will be a change of adress for my family next spring or summer.  I'll just get trains running now, make it look good later.
Thanks for the help, I'm sure I'll be asking more questions later.
08-02-2009 7:03 AM In reply to
Offline HHPATH56
Not Ranked
Joined on 03-04-2007
Posts 562
Welcome to the Forums,        You state that you have the 5'x10' table built. I hope that, (since you plan to move), you have divided up the 5'x10' into modular sections, that are bolted together.  A 5 year old is going to have trouble seeing and reaching any part of the layout. Have you provided a "lift" for him? Is the figure 8 constructed with a pass over, or cross-over at the center?   I have combined Code 100 and Code 83 tracks on my rather extensive layout. You can get "Transition joiners", to connect transitions between the two codes.For cutting track and the "sprues" on plastic stuctures kits, I highly recommend the use of a ''track cutter pliers",(rather than an Exacto knife) Use fine sandpaper, to smooth any ragged edges! The "track nipper" is much safer, especially for a 5 year old. With supervision, get him started in structure kit construction!.  As to "scenery", I would suggest that you plan the era and industries of your future layout, and start building structures. You will find "cheap-ready built structures" at Model Railroad Shows. I always pick up a half dozen structures and railroad freight cars, at Model Railroad Shows, very cheaply!   I am in the process of changing from DC to DCC Digitrax operation, so have "cleaned the decks for action" (installing under table switch motors, and wiring 6 reverse loops and wyes)  All my structures are stored in boxes), I have 96 electrically controlled switches, with 24 assigned to 4 separate Power Districts, and 10 manual switches (that are within easy reach of the operators)  I still hve some of the old electric Code100 Atlas table top switches, (motors covered with railroad work shacks).   Send us a drawing of your proposed layout.  I preplanned my around the room 24'x24' layout, and then constructed it in four stages, with dead switches installed, in anticipation of the later expansion.  Many modular railroads use manual switches, since the sections are bolted together at Model Railroad shows, and could not have Electrically controlled switches (Unless DCC operated).  If you need help with Hosting and Posting a diagram (or your individual AVATAR) on the Forum, let us know, so that we can help!   Bob Hahn
08-02-2009 9:09 AM In reply to
Offline Allegheny2-6-6-6
Top 500 Contributor
Joined on 03-24-2007
Posts 1,679
Well it used to be true that you simply had a lot more choices of turnout aka switches in code 83 then you had in code 100 so the choice was easy but now a days it seems you can get any turnout you want in code 100. I personally build in code 83 and code 70 that being said I have had the good fortune to visit many a bunch of world class layouts, some featured in Allen Kellers videos and I was surprised at the number of guys running code 100. As far as better running code 100 wins hands down as far as prototypical looks no question code 83 is the winner there. Paint up the code 100 and bury it in ballast it unless your an expert it's going to be very hard to tell the difference so there's nothing wrong with using code 100.
As far as whose turnouts/switches are best it all depends on how deep your pockets are. Some say Walthers/Shinohara are the finest switches made. I do tend to agree with that statement but I have half a dozen Micro Engineering turnouts that I feel are fantastic both looks wise as well as operational. How ever the bulk of my turnouts are Atlas custom line, why you ask after I stated what I feel are the best ones to use, simple money. I picked up a bunch at a train show for less then $12.00 ea. So that it it's self is at least half the price of Walthers/Shinohara a significant difference but I found a LHS that was getting rid of its model railroad inventory in favor of slot cars? Some people just have their priorities all screwed up........lol I purchased most of their inventory the most expensive Atlas #8 turnout was less then $6.00. So it was a no brainer. I get four or five turnouts for the price of one easy for me to decide.
Do they work just fine yes, do they look as good as the others, maybe not as prototypical but I fixed that by painting them of course and putting all my "better more expensive one" up front where you can plainly see them and the rest in other area's. So it all comes down to money, if it's no object to you then of course buy the best but if your building on some what of a realistic budget then do exactly what you did with your track go with the best deal.
08-02-2009 9:45 AM In reply to
Offline Robt. Livingston
Not Ranked
Joined on 07-10-2009
Posts 239
In the long term, you can use code 100 now and switch to more-scale code 70 and/or 83 later.  I have re-used most of my old code 100, from a prior layout, as staging track for my current code 83/70 railroad.  Nothing wasted.  Of course, the plastic frogs on the earlier Atlas no, 6 switches wore out, so I bought Atlas Customline (metal frogs) for the staging ladders.   Time will tell whether that was a good idea, but I learned plenty about tuning turnouts from the prior railroad, so I think I'll be OK.
08-02-2009 11:37 PM In reply to
Offline 1911 guy
Not Ranked
Posts 9
The layout is built modular, three sections of 5 foot by three foot four inches.  Each section is bolted to common support underneath using 3/16 machine screws and nuts.
I'm not too savvy at putting up pictures, but the track plan is #29 in Kalmbachs book "101 track plans".  There is a cross over at one end and a 90 degree intersection in the middle.  All sub-roadbed has been cut from masonite hardboard and can be dissassembled roughly near the joints of the 5' X 3' 4" platforms.  I expanded it from a 4' X8' original plan, but kept the same elevations, reducing the grades to 3.2 percent, versus 4 percent.
I'm ready to start cutting 2x4 to support the masonite on Tuesday or Wednesday.  I hope to be laying cork roadbed next week, track the week after.
Again, thanks for the advice and the warm welcome to the hobby.
08-03-2009 10:42 AM In reply to
Offline MILW-RODR
Top 500 Contributor
Joined on 01-15-2009
Title Town
Posts 907
All my test track right now is Atlas code 100 and a custom line #6 switch. It worked just fine running throught, as long as my engine didn't get to far on the unpowered spur The only think I really didn't like was the obnoxiously extremely ugly plastic frog section. Once everythings going enough for track I will do use all Atlas but once I get down more serious I will replace the turn outs with better looking ones. I will be using Tortious switch machines, but that's mostly based on the train store, they used them on their display shelf. As for appearance I wouldn't worry. One of the proprieters told me straight up once everythings painted, weathered, and ballasted it's the different rail looks very similar. There is only .017" different between code 100 and code 83. Just to give you an idea 1/64 of an inch is .0156". I think that's somewheres around the height of the lines on note book paper. I may still keep with my idea of having all handlaid track using Fast Tracks, and even then I think I will still use code 100. code 83 would be a prototypical 132# rail IIRC (I finally figured out what that acronym stood for today) so if you are being proto-anal it would be too big, but otherwise no worries.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
