General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 07-31-2009 8:17 PM by RutlandRay. 7 replies.
Rate:
Sort Posts:
Page 1 of 1 (8 items)
07-26-2009 3:39 AM
Offline Marc_Magnus
Not Ranked
Joined on 12-20-2003
belgium
Posts 455
PLIOBOND glue but precisely which kind of it?
Hi from Belgium,
Well we have the chance to found PLIOBOND glue here in Belgium for the first time.
After a look at the catalog it seems there is some different type of this fantastic glue.
They have a label of n° 10  20  30....
So which is the right number to use for modeling purposes.
Thanks a lot.
Marc
07-26-2009 11:21 AM In reply to
Offline locoi1sa
Top 500 Contributor
Joined on 07-13-2006
Posts 1,227
Re: PLIOBOND glue but precisely which kind of it?
 What are you using the glue for? It is a contact adhesive and the different numbers on the label may be some sort of viscosity or thickness.
     Pete
07-26-2009 1:59 PM In reply to
Offline jsoderq
Top 500 Contributor
Joined on 09-06-2002
Saginaw River
Posts 943
In the US, Pliobond is by Goodyear Tire and Rubber and is rubber cement. The solvent content will attack plastic. I can show you cars with badly warped floors including Walthers factory passenger cars which they used it to attach weights.
07-30-2009 9:13 AM In reply to
Offline maxman
Top 500 Contributor
Joined on 02-14-2008
Posts 1,202
jsoderq:
I'm not sure that the Goodyear part is correct.  I think that Goodyear might have developed it but it appears that the stuff is now made by Ashland Speciality Chemical, http://www.ellsworth.com/ashland.html.  Just a minor technicality.
I agree with the plastic warping comment (although the technical data found at the link below suggests that Pliobond can be used for plastic and plastic film).
Concerning which flavor to use, it looks like the Fast Tracks turnout people are suggesting Pliobond 20 for track work if that is what you are using it for.  See http://www.handlaidtrack.com/pliobond.php
07-31-2009 12:19 AM In reply to
Offline kenkal
Not Ranked
Joined on 07-20-2004
Huntley, IL
Posts 158
I've used Pliobond on plastic over the years and never noticed a problem of any kind.  Perhaps it attacks styrene and not other plastics?
BTW, Walther's Goo has a surprisingly similar color, viscosity and smell to the Goodyear Pliobond I've used.  I wonder if they just repackage it? Ken
07-31-2009 1:44 AM In reply to
Offline Marc_Magnus
Not Ranked
belgium
Posts 455
Hi,
Thanks a lot for all your answers, they were very helpful.
Marc
07-31-2009 2:16 AM In reply to
Offline IRONROOSTER
Top 50 Contributor
Joined on 06-08-2003
Northern Viriginia
Posts 4,904
kenkal:
Years ago I used Walther's Goo to glue brass rail to wood ties which in turn were glued done with white glue to cork.  When I dismantled the layout I pulled up the rails with pliers and almost every tie came with it.
Enjoy
Paul
07-31-2009 8:17 PM In reply to
Offline RutlandRay
Not Ranked
Joined on 02-14-2003
US
Posts 27
I use Pliobond in a tube. I'm not sure how old this one is but we have been using at my club for years to bond the rail to the ties. The tube says Good Year.
We file a notch in the tube tip the width of the rail bottom. We apply a bead of the Pliobond to the bottom of the rail and let it dry. We then position the rail and heat it with a big soldering iron and follow it with a heat sink. Some of this track has been in place for about 30 years. One thing we learned early on is that you should pre bend the track for the curves as sometimes the rail would break loose. It is especially useful when laying light rail in sidings as you don't have spike heads to run afoul with the wheel flanges especially when a member brings in some old equipment with large flanges.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
