General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 07-12-2009 5:20 PM by G5&H10Guy. 12 replies.
Rate:
Sort Posts:
Page 1 of 1 (13 items)
07-09-2009 5:03 PM
Offline Darth Santa Fe
Top 150 Contributor
Joined on 06-21-2005
Posts 2,510
HO steam handrail stanchions?
At some point, I'll need to order some handrail stanchions so I can give my quite customized Tyco Chattanooga Choo-Choo a proper set of handrails and coupler lift bars. The problem is, I can't seem to find any that are available. It looks like Bowser has stopped selling all of theirs, and the other major detail companies don't have any listed either. The only possibility I can find is Precision Scale Co., but there aren't any pictures of their products, so I can't tell if their listed stanchions are what I'm looking for.
Does anyone know who still makes any, or if PSC makes the ones I need?
07-09-2009 5:45 PM In reply to
Offline andrechapelon
Top 150 Contributor
Joined on 09-01-2002
California & Maine
Posts 2,682
Re: HO steam handrail stanchions?
Darth Santa Fe:
Darth,
PSC makes a number of stanchions. The ones you're probably interested in are in the 370 series part numbers (brass) or 370-1 (plastic). From base to centerline of core (where the wire goes through), they come in lengths of  1.5 mm (a shade over 5 scale inches in 1:87)  to 4.0 mm (almost 14" in 1:87) in 0.5mm (roughly 1.7 scale inch) increments.
Part numbers are 370 through 375 inclusive on the brass and 370.1 through 375.1 on the plastic ones. Brass ones are listed at $3.50/doz while the plastic ones list at $2.25/doz. OTOH, I've had this catalog for a number of years, so things might have changed. I don't think so, but you never know.
Sorry I can't post a picture. Catalog has a pic, but it wouldn't scan too well and in order to make it really visible, the image would have to be expanded.
Hope this helps.
Andre
07-09-2009 6:27 PM In reply to
Offline onequiknova
Not Ranked
Joined on 07-17-2003
Illinois
Posts 216
Here is a scan out of my PSC catolog.  I have used the 31311, 3302 ands 3303's and all are nice. They also make the ball headed stanchions and they are closer to scale than the oversized Bowsers of the same style.
 Walthers carries alot, but not all of the parts PSC makes, so you may need to order direct. Keep in mind they make their parts in batches, so not everything is available all the time.
 John.
07-09-2009 7:33 PM In reply to
Top 150 Contributor
Posts 2,510
Thanks for the help guys. It looks like the 372 is the one I want, and Walthers has them in stock for $3.75 a dozen (which means I can order them through my LHS ). Two dozen should be just enough to finish the handrails and liftbars. Thanks again!
07-10-2009 3:39 PM In reply to
Offline Robt. Livingston
Not Ranked
Joined on 07-10-2009
Posts 239
Hey, thanks for the tip.  I have recently re-entered the world of HO loco construction, and I was trying to find handrail stanchions.  One of those PSC units  looks like the old Kemtron parts from days gone by.  Current project is a Bowser T1 with the more detailed diecast boiler (as opposed to the lead thing it replaces, that looked like a used toothpaste tube).
07-10-2009 8:52 PM In reply to
Top 150 Contributor
Posts 2,510
Robt. Livingston:
Current project is a Bowser T1 with the more detailed diecast boiler (as opposed to the lead thing it repaces, that looked like a used toothpaste tube).
That Bowser T1 should turn out to be a very nice engine! I've built one myself, and although it was challenging, it turned out very good. One thing you might want to consider is replacing that rubber tube motor coupling with a Northwest Short Line universal. I did that with mine, and not only does it draw about 0.25 amps less, but it also runs smoother.
07-11-2009 8:01 AM In reply to
Not Ranked
Posts 239
Ah, very nice.  As I am sure you know, the Bowser boiler casting looks better then the  BLI version.
On the running gear, I long ago discarded the coupling between front and rear engines, and milled out a new one-piece cover plate for the underside, to rigidize the whole frame like the real ones.  I am fortunate to have a 36" minimum radius railroad, and the engine has been extensively road tested.  Works great.  But that old lead boiler had to go when I visited the main Bowser outlet (English's) in PA, and saw the "new" die cast boiler for sale.  It seems they have discontinued the Bowser locos (and parts), sad to say. A new day dawns, and Chinese plastic rules.
In any case, some of us still have fun building up metal locomotives, and the never ending quest for microscoipc parts contunues.  Get 'em while you can!
Thanks.
07-11-2009 8:50 AM In reply to
Offline Allegheny2-6-6-6
Top 500 Contributor
Joined on 03-24-2007
Posts 1,681
 I had thought of doing what you did but with a little twist, instead of leaving the tender hookd to the original engine hook it to a powered unit to give it the power of double heading but the look of a single unit. That thought went by the wayside, you'll see I sent you a PM. Why not make your won handrails using one of those wire bending jigs from Micromark?
07-11-2009 10:51 AM In reply to
Offline loathar
Top 10 Contributor
Joined on 08-05-2004
Amish country Tenn.
Posts 10,017
Yardbird sells stanchons and tender detail sets for the Mantua tender which is almost identical to the Chat version.
http://yardbirdtrains.com/TndrDtlKit.htm
I don't know if you can buy it seperate from the engine detail kit, but the whole kit is only about $15. I know he sells the hand rail posts seperate.
http://yardbirdtrains.com/YBDetailParts.htm
07-11-2009 2:36 PM In reply to
Offline topcopdoc
Not Ranked
Joined on 02-06-2003
New Jersey, US
Posts 322
Hey Darth Santa Fe,
Nice job on the T1, did you add a decoder and make it DCC?
I built a T1 also but have not picked out a decoder yet. If you have any info on making it DCC ready I would appreciate it.
Doc
07-11-2009 5:04 PM In reply to
Top 150 Contributor
Posts 2,510
topcopdoc:
Thanks. No, I haven't put DCC in yet (my layout's too small for it). I may if I get a bigger layout in the future, but for now, all my stuff is DC.
Do you have a newer T-1 with the isolated DC-71 motors (both brushes wired)? If you don't, you'll have to replace the motor brush plates with fully insulated ones. Isolating the motors from the frame would be a lot of work, especially with the T-1. Once that's done, you'll want to put in an O-sized decoder (maybe 4-amps incase both motors were to stall). The tender's got a lot of room in it, so the decoder can fit in there. I hope this helps!
07-11-2009 11:00 PM In reply to
Offline twhite
Top 25 Contributor
Joined on 07-07-2004
Carmichael, CA
Posts 6,671
Robt. Livingston:
Robert:
PSC has acquired practically the entire (if not the ENTIRE) Kemtron line, in addition to their own extremely well-detailed castings.  With Cal-Scale/Bowser unfortunately kinda/sorta bowing out of the detail line, I think that PSC might turn out to be the best bet for we brass detail customers.
I've dealt with PSC a lot, and their product, customer service and shipping is top-notch, and their detail castings are of a very good and reasonably priced quality.  They're not just an importer of top-quality brass steam locos, they have an extremely extensive catalogue of detail parts.   I like them.  A lot!
07-12-2009 5:20 PM In reply to
Offline G5&H10Guy
Not Ranked
Joined on 12-31-2008
Posts 11
Check the Bowser web page under price list for items in stock as I just got some. The part number is 6000 for HO.  They also have six kite for the PRR 060 swithcher and some H-9 kits available.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
