Electronics and DCC
The place to discuss wiring for DC and DCC controlled model train layouts. If you're new here, please read our forum policies.
Last post 07-08-2009 4:13 PM by traintown. 2 replies.
Rate:
Sort Posts:
Page 1 of 1 (3 items)
07-08-2009 3:24 PM
Offline traintown
Not Ranked
Joined on 03-17-2008
Posts 9
Connection question
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
I'm working on converting several brass steam locomotives to dcc.  I've converted one, but there are a couple issues that I have to address.  The question I have is does anybody have a good way to pick up power from the rails to the decoder?  I’ve tried putting a piece of copper to connect the two axels.  This distorted the trucks and the locomotive tender didn’t sit properly on the tracks.  Next I tried to use a piece of 30 gauge wire and wrap around the axels to get power.  The problem I had with that was when I connected the wire to the decoder, it limited the trucks turning.  Does anybody have any proven ways to connect the trucks to the decoder without them affecting anything?
07-08-2009 3:56 PM In reply to
Offline betamax
Not Ranked
Joined on 10-06-2005
Posts 326
Re: Connection question
It's not that hard.
First question: what happened to the orginal pickups? They should be fine. As to the tender, the trucks are a) polarized and b) connected to the body at the bearing point. Make sure the mounting point for the truck is clean on both surfaces. The drawbar completes the circuit with the locomotive.
With brass, the frame is hot on the locomotive, which connects to one motor terminal. The other terminal is isolated from the frame and connects to the drawbar to complete the circuit via the tender.
Rather than repeat myself, here is a conversion that I've already done:
http://www.dccwiki.com/VH_Royal_Hudson
It worked just fine after conversion.
Tags:
07-08-2009 4:13 PM In reply to
Offline traintown
Not Ranked
Posts 9
 Ok thanks.  The reason that I went with tender pickups is that the frame sometimes doesn't get power when it goes over a frog.  I figured that it would be easier to run them from the tender since the decoder its in there anyway.  I think ill try it like that though.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
