General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 07-09-2009 2:14 AM by WSOR 3801. 14 replies.
Rate:
Sort Posts:
Page 1 of 1 (15 items)
07-04-2009 7:48 AM
Offline rclanger
Not Ranked
Joined on 06-20-2008
Suffolk, Virginia
Posts 201
Freight car weight location and adhesive
When picking up my rolling stock to photograph I noticed a considerable difference in weight from one car to another.  I think I remember the formula suggested by NMRA: one oz. + 1/2 oz. for each inch of real length.
My questions:
1. Where should the additional weight be located?  In the middle, over the trucks, both?
2. I have read that pennies are good weights, yes/no?
3. I would like to use Goo as the adhesive.  Goo is flexible and will allow me to move the weight around...
Thanks
07-04-2009 8:54 AM In reply to
Offline Silver Pilot
Not Ranked
Joined on 05-15-2009
Posts 112
Re: Freight car weight location and adhesive
My preference is to add the weight, evenly split, over the trucks whenever possible.  Since the additional weight is to help it track better, putting it over the trucks provides the best benefit.
I prefer either self adhesive tire weights or buckshot, pound for pound my guess is cheaper than pennies and easier to make fine adjustments to weight.
I would avoid Goo if in an enclosed car.  Goo is solvent based and the fumes have been reported to cause cars to soft and deform.  Use silicone or adhesive caulk.
07-04-2009 10:27 AM In reply to
Offline trainman6446
Not Ranked
Joined on 02-21-2002
Quad Cities Iowa
Posts 117
I've had good luck with the self adhesave weights. I place them over the trucks. Only 1 layer though. The car will be top-heavy and wobble and derail.
07-04-2009 10:35 AM In reply to
Offline rclanger
Not Ranked
Suffolk, Virginia
Posts 201
trainman6446:
Where did you buy them?  Lowes?  Or are they made for the modeling crowd?
07-04-2009 10:47 AM In reply to
Offline dehusman
Top 50 Contributor
Joined on 09-20-2003
Omaha, NE
Posts 5,016
rclanger:
Doesn't really matter as long as it is balanced between the ends.  You can put it over the ends, you can put it in the middle you can do both.
They are handy, they are reasonably uniform in size and they cost pennies to use.
Down side you need to use caulk or something with body to hold them, they are kinda bulky, they are round and even though they cost pennies they can be more expensive in the long run than some of the weights.
I use latex caulk.  Will not harm plastic.  Goo has solvents that can over time damage some plastics.  Silicone caulk will also work but you have to be very, very neat.
07-04-2009 11:09 AM In reply to
Offline Mr. SP
Not Ranked
Joined on 12-15-2007
Oregon
Posts 512
The formula I use for car weight is a modification of the NMRA practice. I use one ounce per ten scale feet of car length. A 50 foot car would weigh 5 ounces. This dose make the cars slightly heavier than NMRA practice  though.
For weights I go to our local tire centre and get the used tape weights for mag wheels. They are either 1/4 or 1/2 ounce sections. I soak the weights in lacquer thinner for a few minutes to remove the tape.       Walthers Goo or contact cement is used to fasten the weights as low in the car as possible and over the trucks at each end of the car balanced evenly.
07-04-2009 11:13 AM In reply to
Offline dstarr
Top 500 Contributor
Joined on 08-10-2006
Franconia, NH
Posts 808
rclanger:
My questions:
Doesn't matter.  Just balance the weight to get the same amount of weight on both trucks.  And the same amount of weight from side to side too.
rclanger:
Pennies work and the price is pretty low.  For house cars with lots of room, I use just any old bit of metal I have lying around the shop.  For max weight in min volume you can't beat lead.  I get sheet lead used for flashing at the hardware store.  I am going to try to sweet talk used lead wheel weights out of my friendly local garage.
rclanger:
Goo is bad for plastics.  Makes them warp after a while.  I use silicone bathtub caulk.  It bonds well to darn near anything. even dirty things.
07-04-2009 11:16 AM In reply to
Online tstage
Top 10 Contributor
Joined on 06-11-2003
Northeast OH
Posts 8,684
I, too, like the silicone caulk for fixing weights.  Very little or low residue odor and peels back up, if needed.
07-04-2009 12:10 PM In reply to
Offline LenS
Not Ranked
Joined on 07-01-2007
Posts 37
rclanger:
Over the trucks is best, especially if you want to open box car doors.
rclanger:
I use 3/8" or 5/16" washers purchased in bulk from Menards or Home Depot. They vary in weight from .15 oz to .30 oz, allowing more accurate weight. I also use ALine self adhesive weights for some applications.
rclanger:
I use DAP Kwik-Set bathroom adhesive for most applications and double sided tape for some narrow surfaces, such as hoppers. Works just fine and is easy to remove with an Xacto knife and water.
Hope this helps.
Len S.
07-04-2009 3:18 PM In reply to
Not Ranked
Quad Cities Iowa
Posts 117
trainman6446:
I picked mine up at the LHS. You can probably get them through Walthers also. Have not seen anything like them at lowes though.
07-04-2009 4:04 PM In reply to
Offline grizlump9
Not Ranked
Joined on 11-08-2008
Posts 552
 i cabbaged on to a bunch of old lead wheel weights.  they can be chopped to any length to get the weigt needed.  after filling the flat side smooth, i install them over the trucks with double stick foam mounting tape.  none have come loose in over ten years.  for hoppers, i make a triangle pattern out of styrene that will tuck up underneath between the hopper doors and the use the pattern to make a mold in aluminum foil in a box of sand.  then i can melt the wheel weights with a torch and cast my own weights.
grizlump
07-04-2009 6:48 PM In reply to
Offline IRONROOSTER
Top 50 Contributor
Joined on 06-08-2003
Northern Viriginia
Posts 4,707
 I use pennies.  At 11 cents per ounce I don't know of anything cheaper except free.  Personally, I use white glue, spread the pennies out evenly and pour enough white glue to cover them.  Of course, for boxcars, if the door is to be open you'll have to put them at the ends or disguise them. For hoppers, if they don't come already weighted I add a load and put the pennies loose in the bottom - the sloped bottoms keep them from shifting.
I have also used finishing nails that I got for free - leftover from my brother's basement  remodeling. But I find them a little harder to glue in place and arrange evenly from end to end.
Fortunately, most of my RTR cars are already weighted.
Enjoy
Paul
07-04-2009 8:53 PM In reply to
Offline reklein
Top 500 Contributor
Joined on 07-22-2004
Lewiston ID
Posts 1,600
I just bought a set of Tichy reefer kits and they supply 2, 5/8" nuts for the weights. The floors of the cars have hexagonal ridges to position the weights over the trucks. I'm looking forward to the build. BILL
07-05-2009 11:12 AM In reply to
Offline LenS
Not Ranked
Posts 37
Self adhesive weights are available at most LHS, through onlineproviders such as the A-Line, Micro Mark, 1st Place Hobbies, to mention a few and many other options.
07-09-2009 2:14 AM In reply to
Offline WSOR 3801
Top 500 Contributor
Joined on 12-06-2004
WSOR Northern Div.
Posts 1,092
 I like using double-sided foam tape to attach weights.  Works well, won't eat the plastic like Goo.
To add weight, I usually use the self adhesive wheel weights.  Buy these at an auto parts house, unless you like to spend a lot more to buy the A-line ones.
Make sure the cars roll well before adding weight.  Cars that don't roll well cause many problems, and the added weight makes things worse.
Usually adding the weight over the trucks is the way to go.  Sometimes there isn't room, so the weight goes towards the middle.  Try to keep things balanced.
You have listed the NMRA RP for HO car weighing.  I usually follow it, sometimes go a little heavier.  Free rolling wheels help a lot.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
