General Discussion
The place to discuss railroad industry trends, information about freight railroads, train watching, comments on recent trips, and other railroad topics. If you're new here, please read our forum policies.
Last post 07-07-2009 4:56 AM by Paul_D_North_Jr. 23 replies.
Rate:
Sort Posts:
Page 1 of 2 (24 items) 1 2 Next >
07-03-2009 11:53 PM
Offline Boyd
Top 500 Contributor
Joined on 08-17-2004
St. Paul, Minnesota
Posts 1,097
Who has the BIGGEST trains?
As in, tallest, widest trains. I think Russia has a wider gauge than USA, so are their train engines and cars taller, wider and heavier than ours?
07-03-2009 11:59 PM In reply to
Offline Awesome!
Not Ranked
Joined on 03-09-2008
Austin, TX
Posts 672
Re: Who has the BIGGEST trains?
Does he mean in HP or Size?
07-04-2009 5:14 AM In reply to
Offline tree68
Top 25 Contributor
Joined on 12-25-2001
Northern New York
Posts 8,655
Track gauge isn't always a factor in the size of the equipment.  Remember Milwaukee's "Little Joe's"?  Built for Russia but didn't go, so they were regauged for US use and went on to a successful career in the Northwest (and in Chicago).
Erie started out broad gauge (6'), but I don't recall reading that their equipment was outsized.
Brazil still runs on 5' gauge, IIRC.  Yet you probably wouldn't know that to look at their locomotives, which come out of the same factories as what we see every day.
I believe the US uses some of the largest individual cars - consider those hi-cube monster boxcars built for the auto trade, not to mention auto racks.
That's rolling stock - which some folks also call trains.
For trains, I think the Aussies have the corner on big trains on a regular basis, but I don't have any numbers in front of me.
07-04-2009 6:08 AM In reply to
Offline Paul_D_North_Jr
Top 150 Contributor
Joined on 10-12-2006
Allentown, PA
Posts 2,626
Spain has large amounts of 5'-6" (or 5'-3" ?) gauge, but - like many European and Asian countries (India) - their "loading gauge" (= clearance diagram) is comparatively constricted, so they can't take advantage of the wide gauge to build proportionally wider and taller rolling stock.
It seems that what you're really asking is, "Who has the biggest Loading Gauge ?" - "taller, wider and heavier".  Now that many key U.S. routes are good for double-stack clearances, 315,000 lb. cars and 420,000 lb. 6-axle locomotives, it's still probably the U.S.  I don't think there are any overseas railroads that have as much equipment and routes that are good for "Plate E" clearances, for example.
Edit:  or Plate H for double-stacks.  See: http://en.wikipedia.org/wiki/Loading_gauge
and the pictorial comparison between the European and American loading gauges at:
http://www.emdx.org/rail/Gabarit/ComparaisonGabaritsEuropenEtAAR.pdf
- Paul North.
07-04-2009 6:27 AM In reply to
Offline Sir Madog
Top 500 Contributor
Joined on 03-16-2009
Hamburg - South of the Arctic Circle
Posts 1,146
 If I understand BIGGEST as longest trains or biggest loads in terms of train weight in total, I think nothing beats the US trains. Second would be the LKAB trains from Kiruna to Narvik, with an axle load of 30 tons.
07-04-2009 8:20 AM In reply to
Offline beaulieu
Top 200 Contributor
Joined on 12-29-2001
NW Wisconsin
Posts 2,115
Longest and heaviest by outright length and total train weight would be the Australian Iron Ore trains operating in the Pilbara region of NW Australia.  Second would be the Iron Ore trains operating in South Africa to Saldanha Bay operating on Cape Gauge (3' 6"). These are both dedicated lines.
07-04-2009 12:36 PM In reply to
Offline clarkfork
Not Ranked
Joined on 08-05-2008
Posts 36
Now I know why European rail cars have those rounded roofs.
07-04-2009 1:04 PM In reply to
Offline Railway Man
Top 150 Contributor
Joined on 11-25-2007
Posts 2,514
Adding to beaulieu's comments, afaik the Pilbara iron ore lines have the highest standard axle loadings in the world.
  1. 71,500 lbs:  standard maximum U.S. axle load (the "286K standard)
  2. 78,570 lbs:  highest typically permissable U.S. axle load (the "315K" standard)
  3. 82,500 lbs:  standard BHP iron ore lines axle load
RWM
07-04-2009 1:25 PM In reply to
Offline TH&B
Top 500 Contributor
Joined on 07-10-2003
Posts 959
Sweden might have the widest loading gauge. Some of their passenger trains are wide , maybe around 12' wide, on standard gauge. Some freights are loaded wide there too.
USA must be the tallest , unless somewhere in Australia equals the US loading gauge in height also.
Channel tunnel trains are extra wide.
07-04-2009 1:47 PM In reply to
Offline Railway Man
Top 150 Contributor
Posts 2,514
TH&B:
Saudi Railways has the same height capability.
Let's not forget that primary lines in Canada and Mexico have similar loading gauge and axle loadings to the U.S.
RWM
07-04-2009 4:03 PM In reply to
Offline beaulieu
Top 200 Contributor
NW Wisconsin
Posts 2,115
Sweden and Finland have a larger loading gauge than the rest of Western Europe.
07-05-2009 12:08 AM In reply to
Offline Boyd
Top 500 Contributor
St. Paul, Minnesota
Posts 1,097
 I meant tallest and widest. Not longest or heaviest
07-05-2009 1:48 PM In reply to
Offline TH&B
Top 500 Contributor
Posts 959
I can't think of any trains wider then the Chunnel shuttle trains, standard track gauge but wide coaches.
07-05-2009 3:05 PM In reply to
Offline bubbajustin
Top 500 Contributor
Joined on 01-28-2009
Down Yunder' by the Norfolk Southern
Posts 1,140
Sorry, maby a little here, but what is the heviest recorded load pulled by a US train? What railroad was it from?
07-05-2009 4:21 PM In reply to
Offline timz
Top 500 Contributor
Joined on 02-17-2005
Posts 764
Re: heaviest US train
AFAIK N&W still has the US record, from 1967 or so-- 500 coal loads, Iaeger to Williamson.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
Subscriber and Member Login
E-mail Address:
Password:
Remember me
My Profile
Screenname: (get your screenname)
Search Community
in
