General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 07-04-2009 11:45 AM by MisterBeasley. 3 replies.
Rate:
Sort Posts:
Page 1 of 1 (4 items)
07-03-2009 6:15 PM
Offline rustycoupler
Not Ranked
Joined on 02-11-2007
Posts 124
foamboard buildings
 this seems like good stuff to work with, but how do you square up the window openings ? it seems the more i file and sand the worse it gets. i figured out how to do the corners ,but the windows have me stumped.
07-03-2009 8:26 PM In reply to
Offline igoldberg
Not Ranked
Joined on 06-06-2004
Gettysburg, PA
Posts 498
Re: foamboard buildings
Mark your window with a sharpie pen.  I use a NEW #11 Xacto blade and have a steel ruler on the outside of the mark of my window, so when I cut I cut only on the line.  Use a few cuts, DO NOT try to cut all the way through on one cut.  Mark your cut with the first stroke and slowly go deeper until you are completely through.  Do this for all 4 sides and you get a clean straight window.
07-04-2009 11:22 AM In reply to
Offline dstarr
Top 500 Contributor
Joined on 08-10-2006
Franconia, NH
Posts 822
 I don't beleive files or sandpaper do anything good to foamboard.
   I cut the stuff with an Xacto knife and a metal straight edge.  With great care and some spoiled pieces I can get fairly good results.  I did one scratch built building using foam board rafters to obtain a gracefully curved pitched roof.  I probably will stick to cardstock, basswood, and styrene for future projects.
07-04-2009 11:45 AM In reply to
Offline MisterBeasley
Top 10 Contributor
Joined on 12-02-2004
Bedford, MA, USA
Posts 9,132
I use Tichy windows for my scratchbuilds.  As long as your frames are relatively close to square, the frames will cover up the small discrepancies.  In fact, this kind of matches what "prototype" builders do - the frame is a "rough opening" and the window and framing is used to cover up the small stuff.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
