General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 07-04-2009 1:57 PM by trainman6446. 13 replies.
Rate:
Sort Posts:
Page 1 of 1 (14 items)
07-03-2009 5:35 PM
Offline tatans
Top 100 Contributor
Joined on 05-07-2004
Posts 3,082
"Show-off track"
Just saw an article on large locomotives that don't fit HO curves, much discussion pro & con re: these locos, then someone wrote they could only be run on the track above the layout and he used some term like "show-off" track, I'm sure that's NOT the term, does anyone know the actual term and have any information on this type construction, is it connected to the layout???  Would like to see a photo of the track.
07-03-2009 5:43 PM In reply to
Offline tatans
Top 100 Contributor
Posts 3,082
Re: "Show-off track"
HEY ! ! I found the article" he refers to the track around the outside walls as a DISPLAY - LOOP anyone heard of this ??? if so can you explain or have a photo, thanks.
07-03-2009 5:50 PM In reply to
Offline blownout cylinder
Top 100 Contributor
Joined on 11-11-2008
London ON
Posts 3,318
Some time in the 1990's someone came up with a shelf system that had---in this case G scale track that was basically an around the walls layout---except that it was at a 7'-8' height. There were even adverts for this system.
It was just a basic 8-10" wide shelf supported by 'L' brackets---or fancier wooden brackets to do the same thing---the thing was that the brackets had to be installed wherever the studs would be. The tracks would be installed after the support system would be up. In the original it was already there---but was a nfgunhn to join together---
 There was one fellow I knew back then who had it going virtually through the whole house---being a ranch style that was great but-----I'm trying to picture that in a 2 floor house---
07-03-2009 7:18 PM In reply to
Offline analog kid
Not Ranked
Joined on 06-30-2009
Jenison, MI
Posts 72
I've seen these display loops in several resteraunts. There basically used just to show one's locomotives and rolling stock off.
07-03-2009 7:30 PM In reply to
Offline rustycoupler
Not Ranked
Joined on 02-11-2007
Posts 124
you would need that for the g gauge mth triplex .
07-03-2009 7:35 PM In reply to
Offline wjstix
Top 50 Contributor
Joined on 02-14-2002
Mpls/St.Paul
Posts 5,684
 Do you have a link to the article??
tatans:
07-03-2009 9:40 PM In reply to
Offline trainfan1221
Top 150 Contributor
Joined on 07-24-2003
Elmwood Park, NJ
Posts 2,352
analog kid:
Yeah, I've seen these to.  The ones I've seen are all G scale, some are used to advertise local businesses, and for the most part the trains they have are pretty boring.  Might be a neat thing to have in one's house though, and an interesting way to display things.
07-03-2009 10:51 PM In reply to
Top 100 Contributor
London ON
Posts 3,318
rustycoupler:
Watch the curves on that track as well. MTH triplexes had issues with those---
07-03-2009 11:00 PM In reply to
Offline Sir Madog
Top 500 Contributor
Joined on 03-16-2009
Hamburg - South of the Arctic Circle
Posts 1,146
... now I have found the justification for all those MTH and BLI locos that require a 48" min. radius to run properly - we all built these display-layouts above our real leayouts and have them locos choo-chooing around the loop, at max speed and max volume!
07-04-2009 8:22 AM In reply to
Offline pastorbob
Not Ranked
Joined on 12-03-2002
Posts 696
Sir Madog:
No Thanks!!!  having a three deck railroad now for operations, etc. I can't begin to imagine trying to install a "display" layout around the wall above the layout.  Ceiling clearances would be an issue.  However, I do run a large scale layout in the backyard also, and it has lots of room for curves.
Bob
07-04-2009 8:42 AM In reply to
Top 100 Contributor
London ON
Posts 3,318
pastorbob:
Sir Madog:
Bob
The scary thing about the G scale shelving system was precisely the curvature needed and the issue of ceiling clearance. I remember one so called display layout that was only about 16" from the ceiling---in this case an 11' ceiling---we're talking about 9' up.
We worry about a 48" fall to the floor here
G scale is perfect for the garden----near a ceiling? Not so much
07-04-2009 10:23 AM In reply to
Offline trainman6446
Not Ranked
Joined on 02-21-2002
Quad Cities Iowa
Posts 122
I just made up the term "display loop".  I am trying to figure out how to intigrate it into my layout. Maybe an elevated main line on a fill. Balasted differently so it looks like a different RR. One section might be seniced to look abandoned (overgrown weeds in the track, trees next to the line, rusted rail ) only it would be able to operate. This idea came about when Walthers started running there passenger trains.
The loop could be hidden in some places. It could interchange with the existing railroad.
07-04-2009 1:49 PM In reply to
Offline tatans
Top 100 Contributor
Posts 3,082
AHAA! ! So your the guy,, it seems others are interpreting something different (like a G scale track around the top of the room)  A concept of a smaller layout with many curves( like a logging layout) and a spur running of around back to an elevated track and up to a track around the room for large locomotives and going fast (or at least not as slow as is common) this method may integrated into my logging layout, thanks for the idea. And you didn't take out a patent on your idea lol.
trainman6446:
07-04-2009 1:57 PM In reply to
Not Ranked
Quad Cities Iowa
Posts 122
I haven't done anything with it yet- just an idea i had while driving. My inspiration was the Soo Line RR layout several months ago that had a double track main on an embankment with the local tracks below. I figured you could take the main all the way around the room on a narrow shelf.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
