Toy train operating and collecting
Interested in O gauge, S gauge, and Standard gauge toy trains? Are you a fan of Lionel, MTH, American Flyer, and other brands of toy trains made today and in the past? If so, the Classic Toy Trains Toy train operating and collecting forum is just for you. If you're new here, please read our forum policies.
Last post 07-19-2009 8:55 PM by asch. 20 replies.
Rate:
Sort Posts:
Page 1 of 2 (21 items) 1 2 Next >
07-02-2009 8:56 PM
Offline lionel2
Top 500 Contributor
Joined on 01-26-2007
Posts 780
How many switches do you have on your layout??
I am just wondering how many of you guys have lots of switches?  I currently have 17 switches.  All of them are 022 postwar switches.  Do you have yours wired up for fixed voltage? You use controllers?  Thanks.
07-02-2009 10:08 PM In reply to
Offline DADA1043 BRIDGEBOSS
Not Ranked
Joined on 05-07-2009
Posts 8
Re: How many switches do you have on your layout??
Hi.  I have a total of 31 switches on my layout comprized of all lionel 022 and 711 switches dating from early post war to mid 50's.
tks.
 jim r
07-03-2009 9:46 AM In reply to
Offline dsmith
Not Ranked
Joined on 01-18-2006
Posts 287
My layout is postwar 027 and I have SIX 1122 Remote Switches and FOUR 1022 Manual Switches.
The 1122's have been modified for fixed voltage and I use capacitive discharge circuits for power and are switched with 3 dual 1122 controllers.
On 2 of the 1022 manual switches I have added a simple way of remotely switching them using a very simple small motor and electrical circuit.  There is how-to information here:
http://cs.trains.com/trccs/forums/p/154301/1705484.aspx#1705484
07-03-2009 10:18 AM In reply to
Offline cnw1995
Top 50 Contributor
Joined on 07-21-2003
Crystal Lake, IL
Posts 5,581
 I'm redoing the layout to have all seven switches within arms length - they are manual 027 Lionel switches and a few powered-ones but used only manually.
07-03-2009 10:26 AM In reply to
Offline jmkk
Not Ranked
Joined on 01-22-2007
Berea, OH
Posts 293
I have 38 postwar switches. Twenty o-22 and eighteen 0-72. All switches are supplied with 18 volts to the coil through the fixed voltage plug. The lights on the switch machines have been modified and are supplied with 6 volts.
07-03-2009 11:10 AM In reply to
Offline lionelsoni
Top 25 Contributor
Joined on 12-27-2001
Austin, TX
Posts 6,362
30.  Capacitive discharge.  21 controllers, with lots of diode logic.
07-03-2009 8:24 PM In reply to
Offline jwse30
Not Ranked
Joined on 12-21-2004
Hobart, In
Posts 300
I've got 6 o27 K-Line switches and 3 o42 K-Line switches on my layout. All of them are remote control and all of them need to be wired still.
J White
07-03-2009 9:00 PM In reply to
Offline Civil War
Not Ranked
Joined on 01-05-2009
Posts 138
 I have 12  027  1122 remote controlled switches. I'm not done building yet. I will have maybe another 4.
07-08-2009 7:26 PM In reply to
Offline Serows1
Not Ranked
Joined on 01-06-2008
Posts 61
My layout is 027 tubular and I have 11 switches, all wired for fixed voltage and 4 of them are 042 curves and I use all post war double switch controllers.
Paul
07-08-2009 8:18 PM In reply to
Offline lionel2
Top 500 Contributor
Posts 780
Lots of 027 uses here.  Why 027? Just curious.  I prefer O scale because I run the bigger postwar locos and they seem to run better on O gauge track.  I know its a little more expensive.  Thanks.
07-08-2009 8:45 PM In reply to
Offline lionelsoni
Top 25 Contributor
Austin, TX
Posts 6,362
While still outsized, O27 is not as outsized as O31.  It's also easy to cut and available in lots of different radii.
07-08-2009 11:20 PM In reply to
Offline perry1060
Not Ranked
Joined on 07-12-2006
Apache Junction, Arizona It's a dry heat!
Posts 378
12 switches on fixed voltage.
07-09-2009 12:19 PM In reply to
Offline tcox009
Not Ranked
Joined on 11-30-2006
Posts 25
Right now the layout is nothing but a 4x8 with a single loop of Lionel Fast Track.  By this weekend it will be 4x10 and I have enough Super O for an inner loop with two switches for spurs to place operating accessories.  Now I also have plenty of O and 10 switches, but don't plan to go that way.  Any comments on whether I should use the O.
Tom Cox
07-09-2009 8:48 PM In reply to
Offline Boxcar Bill
Not Ranked
Joined on 09-02-2003
Posts 126
I have 15 Gargraves switches, 9 # 100's and 6 072's with Dz2500's switch machine's. We will be adding another 12 switches in a month or so.
Bill
07-18-2009 12:52 PM In reply to
Offline runtime
Not Ranked
Joined on 02-06-2008
Posts 361
8 - 022, fixed voltage, std controllers;
2 - 072, + 6 - 022, waiting for next phase of layout.
Everything should be rewired when there's time - ha!
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
Subscriber and Member Login
E-mail Address:
Password:
Remember me
Free Newsletter
Get our free monthly newsletter delivered to your inbox
My Profile
Screenname: (get your screenname)
Search Community
in
