General Discussion
The place to discuss railroad industry trends, information about freight railroads, train watching, comments on recent trips, and other railroad topics. If you're new here, please read our forum policies.
Last post 07-03-2009 2:33 AM by Paul_D_North_Jr. 13 replies.
Rate:
Sort Posts:
Page 1 of 1 (14 items)
07-02-2009 7:00 PM
Offline igoldberg
Not Ranked
Joined on 06-06-2004
Gettysburg, PA
Posts 554
Limiting Tonnage behind Engines and Helpers on Grades
Why would a railroad limit the tonnage behind engines and helpers on grades?  Trains are supposed to have enough dynamic and air brakes to control a train going downgrade, plus with the helpers attached that would prevent bunching of the cars behind lead locomotives.
EXAMPLE:  In the SP Northern Region Timetable for the Cascade Subdivision
  Territory                                       Road Engine    Helper Engine
Chiloquin-Kirk  (E)                             10000               8500
Dougren-Minnow  (W)                       10000               8500
Oakridge-Cascade Summit  (W)        4500               4500
07-02-2009 7:11 PM In reply to
Offline henry6
Top 150 Contributor
Joined on 12-21-2001
Posts 2,351
Re: Limiting Tonnage behind Engines and Helpers on Grades
Tonnage rating are just that: how much a given horsepowered locomotive will haul on a given portion of railroad based on the overall gradient.  Specific increases in gradient will call for more horsepower.  In the examples above, the addition of a helper engine merely maintains the tonnage status quo.  Up grade it is the horsepower needed to lift, downgrade it is the braking power to keep the speed in check and the train undercontrol.
07-02-2009 7:15 PM In reply to
Offline corwinda
Not Ranked
Joined on 06-28-2001
US
Posts 344
Two things come immediately to mind. First; the strength of the couplers. Too much tonnage and a knuckle breaks or a drawbar pulls out. Second; the possibility of a stringline derailment on the curves. (Not to mention the added resistance of pulling a long train around multiple curves.)
I'm sure someone else will deliver a more detailed explanation.
 Also; this former SP line has timetable directions that do not correspond to the actual compass direction the train is going. (The line is a north-south line from Sacramento to Portland OR - I believe the restrictions shown are for the upgrade; not downgrade.)
07-02-2009 7:30 PM In reply to
Offline Railway Man
Top 150 Contributor
Joined on 11-25-2007
Posts 2,812
 Upgrade reasons:
  1. Drawbar strength
  2. L/R limits (string-lining on curves)
  3. Train dynamics issues
Downgrade reasons:
  1. Tons per operative brake
  2. L/R limits
  3. Air-brake recharge time
  4. Air-brake recharge time in cold weather
  5. Train line leakage rate
  6. Train dynamics issues
RWM
07-02-2009 7:42 PM In reply to
Offline zardoz
Top 75 Contributor
Joined on 01-31-2003
Kenosha, WI
Posts 4,331
Railway Man:
Upgrade reasons:
  1. Drawbar strength
1a. Most vulnerable just after the units crest the hill and begin descending, unless the engineer throttles back as soon as he tops the hill (the gravity pulling on the part of the train that has crested the hill adds to the pulling power of the locomotives, greatly increasing the stress on draft gear components).
07-02-2009 7:54 PM In reply to
Offline Railway Man
Top 150 Contributor
Posts 2,812
zardoz:
Railway Man:
Upgrade reasons:
  1. Drawbar strength
Yup.  We had a rash of break-in-twos on hogbacks right behind the head-end when we went to ACs.  Then when we went to DPUs, another rash.  We certainly proved how good ACs were at ripping trains in two!
RWM
07-02-2009 8:45 PM In reply to
Offline BaltACD
Top 150 Contributor
Joined on 05-02-2003
US
Posts 2,540
Signifigant changes in motive power characteristics mandate different train handling procedures over difficult territory....both upgrade and downgrade.  Unfortunately, these different procedures are learned by following the old procedures until they don't work.
Good Train handling comes from experience....Experience comes from failed train handling.
07-02-2009 8:47 PM In reply to
Offline igoldberg
Not Ranked
Gettysburg, PA
Posts 554
 Chiloquin - Kirk, up hill, max grade 0.8% 10 miles for then down hill max grade 0.2% for 3   miles.
 Dougren - Minnow, up hill, 9.5 mils max grade 0.8%
Oakridge - Cascade Summit, up hill, max grade 1.8% for 44.5 miles
These figures are based on the grade drawings in he timetable.
07-02-2009 8:57 PM In reply to
Offline Paul_D_North_Jr
Top 100 Contributor
Joined on 10-11-2006
Allentown, PA
Posts 3,404
See also Al Krug's "Railroad Facts and Figures" webpage, "How Much Force can a Coupler Withstand ?" at:
http://www.alkrug.vcn.com/rrfacts/drawbar.htm
His "Second" reason at the bottom of the page echoes what zardoz and RWM said above about coming over the top of a grade.
- PDN.
07-02-2009 9:16 PM In reply to
Offline Deggesty
Top 200 Contributor
Joined on 08-22-2005
Near the Crossroads of the West
Posts 1,937
Yes. To the SP, you went east when you were going away from San Francisco, and west when you were going towards San Francisco--the actual compass direction did not matter. If you look at a very old Amtrak timetable for the Coast Starlight, you will see that the LA-Seattle train was numbered 13-14, and the Seattle train was numbered 11-12; the direction changed at Oakland. I have not examined closely a timetable for central California, but I am sure that you would find interesting timetable directions as opposed to actual compass directions.
Also, I know of at least one instance in which the UP has changed the mileposts--between Sacramento and Stockton.
Johnny
07-02-2009 9:47 PM In reply to
Offline igoldberg
Not Ranked
Gettysburg, PA
Posts 554
I am very familiar with the SP directions, having lived near San Franisco for years and ran in the locomotives of various types as far as Watsonville to Oalkand to Roseville.                                      I now fully understand why tonnage was limited over certain grades.                                                   Can anyone tell me if I am correct that you add 0.4% to make it a compensated grade?  I beleive that is the figure.  I do not believe that the curves over Donner Pass, which I know intimately were superelevated, which would help prevent stringlining.
07-02-2009 10:24 PM In reply to
Offline timz
Top 500 Contributor
Joined on 02-17-2005
Posts 868
Re: Donner etc
The usual compensation formula is 0.04% per degree of curve sharpness.
Passenger speed limit on Donner is still 30 or more, isn't it? That wouldn't be legal on 10-degree curves with no superelevation.
07-03-2009 2:02 AM In reply to
Top 100 Contributor
Allentown, PA
Posts 3,404
See also Al Krug's "Railroad Facts and Figures" explanation of "Dynamic Braking Force vs Locomotive Speed", at the bottom of his webpage on "Amps vs Tractive Effort", at:
 http://www.alkrug.vcn.com/rrfacts/amps_te.htm
07-03-2009 2:33 AM In reply to
Top 100 Contributor
Allentown, PA
Posts 3,404
Re: Donner etc
ConRail's Industrial Sidetrack specs required grade compensation of between 0.04 and 0.05 % per degree of curvature - I always used the latter figure.  Thus, a nominal 1.50 % maximum allowed grade on tangents would - in a maximum allowed 12-Degree, 30-Minute curve, be reduced by 12.5 x 0.05 = 0.625 % - so that the actual grade would be 0.875 % (1.500 - 0.625).
Conversely, if a curved track is built on a grade without such an easing of the actual grade as compensation for the curvature, then - for going upgrade - the appropriate compensation figure should be added to the actual grade % to obtain its equivalent grade % for train resistance calculation purposes.
Going downgrade, the compensation figure would be subtracted from the actual grade to assess its effect on train resistance.  Thus, in my example above, going downgrade through that same 12-Degree, 30-Minute curve on an actual 0.875 % grade  would feel to that rolling stock in the curve as being a 0.250 % downgrade (0.875 - 0.625).
All of this is just an attempt to make allowances for the real-world physics effects - it reflects practical experience, compromises, and adjustments, and is by no means perfect or completel consistent.  Here, reducing the uphill grade to compensate for curvature so that an ascending train is always '"feeling" a consistent grade through both tangents and curves is thought to be preferable to doing that for a downgrade train - thus a downgrade train encounters much different braking requirements as it enters and leaves each curve and tangent.
A 10-Degree mainline curve without at least some superelevation is pretty much unheard of.  Without consulting a chart, I'd estimate that about 1-1/2 inches would be required for 30 MPH.  But on a steep grade, the "optical illusion" created by the track curving as it rises or falls may make it appear as if the track doesn't have any superelevation - the track grade appears to cancel and negate the SE - and in some cases, makes it look on casual viewing as if the track haas adverse or negative SE (outer rail is lower than the inner rail).  [This effect can often be seen on highways - though in some cases, the highway engineers or maintenance people actually have let the ouside of the curve get lower than the inside.    ]  For example, 1.5" SE = 0.125 ft. across approx. 5.0 ft. between the centesr of the rail heads = a slope of 0.025 = about 2.5 % across the track, as compared to around 2.2 % on the Donner Pass and other steep grades in the western U.S.
- Paul North.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
Subscriber and Member Login
E-mail Address:
Password:
Remember me
My Profile
Screenname: (get your screenname)
Search Community
in
