Toy train operating and collecting
Interested in O gauge, S gauge, and Standard gauge toy trains? Are you a fan of Lionel, MTH, American Flyer, and other brands of toy trains made today and in the past? If so, the Classic Toy Trains Toy train operating and collecting forum is just for you. If you're new here, please read our forum policies.
Last post 07-06-2009 7:37 PM by DennisB-1. 6 replies.
Rate:
Sort Posts:
Page 1 of 1 (7 items)
07-02-2009 3:05 PM
Offline strogey
Not Ranked
Joined on 04-18-2009
Wilsonville, Oregon
Posts 98
More help from Encyclopedia CTT needed....
So, I have this plastic flat bed semi trailer that I want to shorten. It is about 2 3/8 inches wide. I figure I can just use a miter box and a razor saw to cut out a middle section and then glue back to gether. No big deal right? Well I'll be danged if I can find a miter box wide enough. At least that will allow use of a razor saw. Yeah I can get one at Lowe's or Home Depot but they are made for a miter saw which I am afraid to use. Not sure I can get a super clean cut in the plastic and if I try and use a razor saw in it, I am afaraid there will be too much "sloop" and I will wind up with a bad cut. I have tried 2 or 3 hobby stores. I even tried our loacal wood crafters store! I do not have access to a scroll saw or any other power tool that would have a fence or square so that I can get a square and true cut.
Can any body help me out here with a suggestion or someplace I can go and have it cut?
As usual, Thanks guys for all the help!
Ken
07-02-2009 4:54 PM In reply to
Offline lionelsoni
Top 25 Contributor
Joined on 12-27-2001
Austin, TX
Posts 6,363
Re: More help from Encyclopedia CTT needed....
Are you familiar with this trick?  Cut it as well as you can, perhaps with the big miter box.  Then butt the two pieces together and clamp them to a board.  (I am assuming that the trailer bed is flat enough for you to do this.)  Then cut the butt joint apart again with your razer saw.  Loosen the clamps and close up the resulting kerf again.  Keep cutting at the joint and reclamping until any irregularities left by the first saw are gone.  Then glue it together, of course.
07-02-2009 6:04 PM In reply to
Offline EIS2
Not Ranked
Joined on 08-28-2004
Posts 501
 Why don't you just make your own miter box.  It is simple to do.
Earl
07-02-2009 6:54 PM In reply to
Offline strogey
Not Ranked
Wilsonville, Oregon
Posts 98
EIS2:
Earl
Earl...I live in an apartment so things that are "simple to do" are not so simple! Thanks!
Ken
07-04-2009 10:16 AM In reply to
Offline DennisB-1
Not Ranked
Joined on 07-12-2006
Posts 159
Use a square to mark your cuts and carefully cut along your lines.
07-05-2009 3:34 PM In reply to
Offline strogey
Not Ranked
Wilsonville, Oregon
Posts 98
DennisB-1:
This is basicaly what I did. I took it one step further and used C-clamps to clamp a square piece of Plastistruc along the line to help keep the saw square. Worked realy great! Only needed a minor amount of sanding to true it up.
Thanks everyone!
07-06-2009 7:37 PM In reply to
Offline DennisB-1
Not Ranked
Posts 159
I'm glad that worked out for you, Strogey.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
Subscriber and Member Login
E-mail Address:
Password:
Remember me
Free Newsletter
Get our free monthly newsletter delivered to your inbox
My Profile
Screenname: (get your screenname)
Search Community
in
