Electronics and DCC
The place to discuss wiring for DC and DCC controlled model train layouts. If you're new here, please read our forum policies.
Last post 07-03-2009 9:46 AM by betamax. 6 replies.
Rate:
Sort Posts:
Page 1 of 1 (7 items)
07-02-2009 12:41 AM
Offline loathar
Top 10 Contributor
Joined on 08-05-2004
Amish country Tenn.
Posts 9,982
DPDT Track Polarity ?
Been a while since I did this. Putting in the switches/wire for my TT bridge track power. DPDT switch. (top on, bottom on)  X  solder 1-6 and 2-5, right? Buss power to 3 and 4. 1 and 2 to track, 5 and 6 to track. Right?             Flip switch, polarity reverses. Right? And I can  jump 1-5 and 2-6 and go to my track with just two wires, right??
(my brain's getting old...)
07-02-2009 10:45 AM In reply to
Online TomDiehl
Top 75 Contributor
Joined on 02-20-2001
Poconos, PA
Posts 3,656
Re: DPDT Track Polarity ?
loathar:
It sounds a bit confusing the way you said it, but you don't need two sets of wires to the track. (1 and 2 to track, 5 and 6 to track). One set will do since you've put the "X" of wires from 1-6 and 2-5. But your last sentence seems to indicate you've figured this out.
07-02-2009 3:02 PM In reply to
Offline wjstix
Top 50 Contributor
Joined on 02-14-2002
Mpls/St.Paul
Posts 5,684
The wires from 3 and 4 go to the track. Power from the powerpack goes onto 1-2 or 5-6. Because of the X you added, the output from 3 and 4 will be reversed depending which way you throw the toggleswitch.
07-02-2009 5:51 PM In reply to
Offline loathar
Top 10 Contributor
Amish country Tenn.
Posts 9,982
wjstix:
Thanks! I knew something wasn't making sence the way I was looking at it.
07-02-2009 7:14 PM In reply to
Offline rrinker
Top 25 Contributor
Reading, PA
Posts 7,584
 As long as you have the X from 1-6 and 2-5, the following are all valid:
 1-2 to power, 3-4 to track
5-6 to power, 3-4 to track
3-4 to power, 1-2 to track
3-4 to power, 5-6 to track
My advice is to make all such controls the same so you don't confuse yourself later on. And tag the wires, because a year from now you'll never remember which two go to power and which two go to the track.
                                 --Randy
07-03-2009 2:01 AM In reply to
Offline locoworks
Not Ranked
Joined on 01-15-2007
Posts 222
as randy points out, it can be done either way, either the X as the feed in, or the feed out, it doesn't matter at all.
07-03-2009 9:46 AM In reply to
Offline betamax
Not Ranked
Joined on 10-06-2005
Posts 326
Easiest way is to look at the terminals as if it were a 6 cylinder engine.
So you have 1-3-5 on the left, and 2-4-6 on the right.
Power comes in one 1 and 2. (They are contacts, as are 5 and 6.)
A wire is used to connect 1 and 6, and another for 2 and 5, forming an "X".
Power is routed out on 3 and 4. Which are the blades of the switch.
You can use the 1-2, 3-4 and 5-6 pairs interchangeably for in/out. The real secret to wiring is that it should be neat and consistent, which makes troubleshooting and repair easier. (Not that I really follow that rule all the time.)
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
