Electronics and DCC
The place to discuss wiring for DC and DCC controlled model train layouts. If you're new here, please read our forum policies.
Last post 07-06-2009 12:21 AM by Wazzzy. 4 replies.
Rate:
Sort Posts:
Page 1 of 1 (5 items)
07-01-2009 3:29 PM
Offline wholeman
Not Ranked
Joined on 08-30-2008
Southeast Kansas
Posts 494
Electrical Plugs
I am looking for an electical plug for hooking a power pack to some track.  I remember MR did something with their Beer Line layout and used plugs made by Marklin I believe.  I don't have that particular issue because a friend borrowed and hasn't returned it.  Any help would be appreciated.
07-01-2009 11:43 PM In reply to
Offline larak
Top 500 Contributor
Joined on 10-03-2005
Ulster Co. NY
Posts 1,186
Re: Electrical Plugs
Does this have to be a particular style?
If not, then a standard 1/4" phono plug and jack works very well.
Karl
07-02-2009 9:57 AM In reply to
Offline maxman
Top 500 Contributor
Joined on 02-15-2008
Posts 866
wholeman:
The wiring was done in the February 2009 issue.  To connect the command station to the bus, and to connect the bus across the joint between the sections, they used a Marklin plug and socket connector, part # 71400.  The bus wire they used was #18 stranded.  I mention this because I don't know what the wire size capacity of the Marklin part is and don't know if the larger size wires will fit into the Marklin part.
If you are talking about the connections between the bus and the track, they used the red ScotchLok suitcase connectors.  These connectors are sized for the different wire sizes (the main bus wire and the connection wire to the track).  The article does not specify (at least during quick reading) what the track connection wire size was.  But it does state that the wire was Brawa stranded wire part numbers 3102 and 3108.
 Hope this is the information you needed.
07-02-2009 11:19 AM In reply to
Offline wholeman
Not Ranked
Southeast Kansas
Posts 494
Thank you for looking up that information.  That will definitely help.
07-06-2009 12:21 AM In reply to
Offline Wazzzy
Not Ranked
Joined on 03-13-2008
Posts 78
visit radio shack. you will find hundreds of electrical connectors and find a type that works for your situation.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
