Layouts and layout building
Benchwork, scenery, track, and more. If you're building a scale model train layout, this is where to go. If you're new here, please read our forum policies.
Last post 07-06-2009 10:58 AM by West Coast S. 21 replies.
Rate:
Sort Posts:
Page 2 of 2 (22 items) < Previous 1 2
07-02-2009 5:59 PM In reply to
Offline duckdogger
Not Ranked
Joined on 09-14-2006
NE Phoenix AZ
Posts 239
Re: Sensory overload-what to do with 100 X 60 room
You could model the state of RI in HO in that much space.  Or California in N scale.  Heck, you could do the entire midwest in Z scale.  Track and turnout needs should allow you to negotiate truck load pricing from Walthers.
07-02-2009 10:16 PM In reply to
Offline tradupj
Not Ranked
Joined on 07-25-2006
Minneapolis, MN
Posts 29
Anything you want !!!
07-03-2009 11:57 AM In reply to
Online IRONROOSTER
Top 50 Contributor
Joined on 06-08-2003
Northern Viriginia
Posts 4,726
I would suggest lots of distance between towns, say 30 feet or more.  To keep the scenery under control the parts between towns could be on narrower benchwork, say 12 inches.  I'd also put in some kind of loop with staging tracks for the mainline connection.
Enjoy
Paul
07-03-2009 5:39 PM In reply to
Offline odave
Not Ranked
Joined on 04-19-2007
Fenton, MI
Posts 141
I've always like what the Rails on Wheels guys did on their Operations Roadshow Wabash layout, though it's "only" 51' x 22.5' .  It zig-zags through the room, with a backdrop divider in the middle of the tables to double the mainline run.  One of their requirements is being able to transport it to various shows, so it is modular.  I'm guessing yours would be permanent, but the same general shape could be used to fill a space fairly well.
07-03-2009 7:13 PM In reply to
Offline kcole4001
Not Ranked
Joined on 07-26-2008
Amherst, N.S.
Posts 249
Nice problem to have!
As already mentioned, forming your own club could prove a viable option if there are enough friends who are also modelers nearby. You're going to need some help, after all!
I'd stick with the same scale you already have equipment for if it were me, that'll save some time and money, which will be better put to use anywhere in a space that large.
07-04-2009 7:56 AM In reply to
Offline stebbycentral
Not Ranked
Joined on 12-21-2006
Posts 424
As a minimalist, I would suggest a single oval of track with 29 foot radius curves, in any scale you desire.
07-06-2009 10:58 AM In reply to
Offline West Coast S
Top 500 Contributor
Joined on 02-23-2005
Los Angeles
Posts 1,056
I did some doodling this weekend, keep it simple indeed, I came up with a point-to-point along the walls design that uses return loops for stagging. Curves are quite generous, in the 15-20 foot range,  There will be interchange yards at each end connected with the aformentioned return loops, one will represent the SP connection the second with the Santa Fe, Actual trackage will be kept to the bare minium in these yards, no more the 4 tracks per and extend to perhaps 30 feet in length, being a branchline one can also dispose of the elaborate steam servicing facalities and go minium.
The option of connecting these loops remains open, this would provide a continous run feature, but would require some form of duck under or swing gate design, something i'm not interested in at this time.
Aside from the interchanges no further yard trackage in the traditional sense is required. Towns will be divided into switching disctricts, which will require the usual passing siding(s) and house tracks in addition to specific industry trackage, which will also be kept simple. So far i've not exceeded 50 turnouts in my preliminary designs, no doubt number eights and larger. My design does provide a generous run between towns with an emphisis on simple scenery by use of narrow benchwork. Track will be a combination of handlaid turnouts with flex used everywhere else, in S scale code 100 is close to 110lb rail. There is also the case to be made for code 83 in certain applications.
The intent is to build the dominos (aka. switching distircts) and all benchwork from welded steel channels as I am comfortable and familar with this medium,  actual material for subroad bed construction remains to be explored.
That sums up where I am currently in the design process, appreciate any and all critiques of my ideas.
Dave
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
