General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Last post 08-02-2009 11:33 PM by Guilford Guy. 120 replies.
Rate:
Sort Posts:
Page 1 of 9 (121 items) 1 2 3 4 5 Next > ... Last »
07-01-2009 10:56 AM
Offline WCfan
Top 150 Contributor
Joined on 03-05-2007
Wausau, Wisconsin
Posts 2,298
Teen Model Railroader Place July 2009
Time for a new one...
07-01-2009 11:20 AM In reply to
Offline Packers#1
Top 150 Contributor
Joined on 02-06-2008
Aiken, South Carolina.
Posts 2,918
Re: Teen Model Railroader Place July 2009
 How about a link to the old one also?
 http://cs.trains.com/trccs/forums/t/154415.aspx
Well guys, I'm once again changing the plan of my layout. This time it's because the amount of switches drove the price of the track WAYYY to high, so now I'm going to jsut focus on the Mullins area, but redesign it to maximize industrial switching while keeping it to about 10 or 11 switches. there will be two legs for scenery, and then a liftout staging area in between that will one day have switches added to it for two stub-end tracks facing each way.
07-01-2009 11:27 PM In reply to
Offline ns3010
Top 500 Contributor
Joined on 11-04-2008
Jersey
Posts 787
Sawyer: Could you maybe post the new plan (that is, assuming you made a few changes)?
Well, I guess I'll post the first photo of the month. A Tri-State Railway bay window caboose rolls through Watchinson on a TSRy test train:
07-02-2009 1:20 PM In reply to
Offline Packer
Top 500 Contributor
Joined on 01-15-2008
Shalimar. Florida
Posts 1,144
The only thing I've been doing recently is getting the list of parts together to complete that Bicenntenial SD40-2, and listing some stuff (unused engines, buildings, etc.) on ebay.
07-02-2009 1:26 PM In reply to
Offline Packers#1
Top 150 Contributor
Posts 2,918
 Joe, sure thing. Also, how about a few pics I took a couple weeks ago outside:
here's the new plan:
also, the first version of that plan:
07-02-2009 3:09 PM In reply to
Offline TrainManTy
Top 100 Contributor
Joined on 12-11-2006
Central Massachusetts
Posts 3,439
That's one heck of a long lift bridge, Sawyer! Stability is really going to suffer, and you're going to need a really good system for anchoring it at the ends. But since, knowing you, you're probably going to come up with a couple hundred different plans before you actually start building, we can tackle that if / when you get to it!
I made significant progress on my staging yard and lift bridge this week. I laid track in the staging yard and added a safety fence to shield the trains against the long drop as well as stray elbows.
The staging yard can hold 4 full-length trains.
In addition, I added the safety stop that cuts off power to the staging yard, bridge, and both approach tracks when the bridge is up. After two failed attempts using metal contacts (getting them to touch was a hit-or-miss scenerio) and momentary switches (reversed functions; bridge is up train goes, bridge is down train stops!) I finally hit on the solution using a default-off button. Now I have good contact, the switch triggers easily, and the train stops when the bridge goes up!
Photo lights are really useful when taking photos under the benchwork!  The tiny little pin is the button itself, with the wiring visible below. It's actually a complete mess down there, with a lot of remnants of old wiring from the two failed attempts before that. I ended up only isolating the inside rail, since with no ground, trains won't move. So I have a lot of redundant wires down there. The large dowels are my method of keeping the bridge in alignment.
Switches are coming tonight by UPS (a modeler's best friend!) and then I'll lay track over the bridge. Then I need to invite Greg over to cut the rails over the gaps with his Dremel. Xurons leave too big of a gap...
07-02-2009 4:47 PM In reply to
Offline ns3010
Top 500 Contributor
Jersey
Posts 787
Tyler- Nice work on the staging tracks.
Sawyer- The new plan is MUCH better! Although when I was looking at the plan again, I also realized (even before I saw Tyler's comment) that the lift/drop bridge is waaaaaaayyy too long.  No need to redo the plan just for that, but keep that in mind when you build the layout. I'd reccomend going no more than three feet long, but even shorter if possible.
07-02-2009 5:55 PM In reply to
Offline Guilford Guy
Top 500 Contributor
Joined on 07-12-2006
Posts 1,293
This was my first ever paint and decalling, about 3 or 4 years ago.
07-02-2009 7:20 PM In reply to
Offline Packers#1
Top 150 Contributor
Posts 2,918
My plan was to have a 2x4 be the main support, running down the middle, with two side curtains on the side etc. I'll probably shorten it to 3 feet and have soem more swamp.
Well, I learned several elssons custom painting today; numero uno being to order paint from Walthers through my LHS, not buy it off my LHS's shelves.
07-02-2009 9:32 PM In reply to
Offline ns3010
Top 500 Contributor
Jersey
Posts 787
GG- That's pretty good! My first decaling job was the Bakery. 4100 will probably be my first paint/decal job.
Sawyer- Or you could just order the paint direct from Walthers... That's what I always do. Whenever I go to the LHS, its for something I need right away/just don't want to wait (like when I needed something for a History project) or if I'm not looking for anything in particular (I want something, but not sure exactly what).
07-04-2009 3:21 PM In reply to
Offline Packers#1
Top 150 Contributor
Posts 2,918
TrainManTy:
Joe-I order it through my LHS to avoid shipping charges. Costs me the same, jsut no shipping. and hey, money goes into local business, etc., etc.
Well Tyler, I can't just sit idle on a plan now, can I? I bent the mainline and changed the industries up, so now it looks WAY more interesting. However, it still uses 8 turnouts. Also, shrunk the lift-out to about two and a half feet or so.
with just the track:
with captions:
07-05-2009 12:27 AM In reply to
Offline ns3010
Top 500 Contributor
Jersey
Posts 787
Happy (belated) 4th!
Sawyer- The new plan is much better. Gets enough going on, without overcrowding (DON'T CHANGE IT AGAIN!!!!!)
Made $40 tonight, so that's 40 closer to an iPod. Once that's taken care of, maybe I can go back to buying stuff so that I can maybe finish the layout (or more importantly, get some cars to pull on said layout...)
07-05-2009 12:35 AM In reply to
Top 500 Contributor
Posts 1,293
Unless girlfriends or food gets in the way, I'll have enough money to order track by the end of August. The Benchwork has unwarped, and is now able to be built upon. Maybe later this week I'll install legs and the foam. I need to bring the bag of excess pink foam down from Boston, and eventually get some hardboard, however I'll wait until I get a couple expressnets and the car forwarding system (after X-mas) before I do that. That will come last. My schedule is track by the end of August, September-December buildings and scenery, X-Mas DCC/Electrical, and then 2010 I can collect rolling stock/locos, and possibly save some money up for a car or get a job.
07-05-2009 3:51 PM In reply to
Offline TrainManTy
Top 100 Contributor
Posts 3,439
Alex... I have a big trash bag of excess pink foam that you're welcome to if you can find a way to fit it on the train ("omg!! it's a bomb!!!" ) or somehow get it home...
I won't be able to bring it to Boston for you, since while I'm getting a ride to Lexington, I still have to take the bus, Red Line, and Green Line to get to the Museum of Science, and it would look sort of odd carrying a massive trash bag full of pink insulation foam up to the Volunteer Services Office where I store my bag while on duty...
07-05-2009 4:31 PM In reply to
Top 500 Contributor
Posts 1,293
Which bus? 62? 76? on Thursday I can ride into Boston with you!
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
