Locomotives
The power that moves the nation’s freight and passenger trains every day. Find out about new locomotives, the fate of old favorites, and ask experts about locomotive performance. If you're new here, please read our forum policies.
Last post 07-07-2009 7:12 AM by PNWRMNM. 13 replies.
Rate:
Sort Posts:
Page 1 of 1 (14 items)
06-28-2009 3:07 PM
Offline Murphy Siding
Top 25 Contributor
Joined on 05-12-2005
S.E. South Dakota
Posts 7,190
Steamers and weather
    I'm reading Unfinished Business by Muary Klein.  In one chapter about diesels replacing steam, he says that diesels are less sensitive to adverse weather than steam locomotives.  How does adverse weather affect a steam locomotive?
06-28-2009 3:26 PM In reply to
Offline bubbajustin
Top 500 Contributor
Joined on 01-28-2009
Down Yunder' by the Norfolk Southern
Posts 1,140
Re: Steamers and weather
Does the outside boiler get super hot when on operation? If so, maby when it rains hard, it may cause stress on the outside boiler of the locomotive???   Just like when you get done mowing for a long time you don't spit, or pour ice cold water on the muffler. But a muffler, and a boiler are 2 very diffrent things...
06-28-2009 3:35 PM In reply to
Offline selector
Top 10 Contributor
Joined on 02-06-2005
Vancouver Island, BC
Posts 14,888
Justin, the boilers are covered with lagging and boiler jackets, so they are essentially covered and somewhat insulated on their surfaces exposed to rain and snow.
I am not an expert in this subject, but steamers have to spread their weight over several non-driven axles in many cases, so their adhesion on the rails where the tractive effort is being applied is less than it would be on a diesel where all wheels bearing weight are also driven.  In wet conditions steamers will tend to slip more than diesels because the rails are wet and the drivers become wet in short order once the engine moves.  So with the diesels, but they have more weight on the wheels doing the work.
Other than that, I can't think why either engine would be affected more than the other with varying weather.
-Crandell
06-28-2009 7:57 PM In reply to
Offline jrbernier
Top 100 Contributor
Joined on 01-08-2001
Rochester, MN
Posts 3,147
  Thermal losses in steam engines is quite large in cold weather.  The loss of heat from the firebox to the cylinders can be extreme.  IIRC, the ACE 3000 project used ex-C&O 614 to run tests and saw the measured thermal efficiency drop from 12-14% - down to 6%.  A diesel-electric runs about about 25-35%, and usually does not lose too much in extreme cold weather.
Jim
06-28-2009 9:18 PM In reply to
Offline joseph2
Top 500 Contributor
Joined on 01-22-2003
indiana
Posts 793
I have tonnage charts for Erie steam locomotives. Yes,when the temperature goes below freezing the tonnage it could haul dropped proportionatly. Also back then most car axle bearings were the friction type,not modern roller bearings.   joe
06-28-2009 9:50 PM In reply to
Offline selector
Top 10 Contributor
Posts 14,888
My education continueth.  Thanks, fellas.
-Crandell
06-29-2009 3:14 PM In reply to
Offline Kootenay Central
Not Ranked
Joined on 08-20-2005
Posts 229
Great data, Thank You!
06-29-2009 5:01 PM In reply to
Offline BigJim
Not Ranked
Joined on 04-24-2001
Roanoke, VA
Posts 730
selector:
Well, that sounds pretty good, but don't you believe it!
In fact, diesels are just as slippery as anything thing else. A simple frost or light dew can really cause a lot of headaches and especially in dynamic brake. A light frost will bring a diesel to its knees. Not only will the slipping effect traction, it also creates havoc with the speedometer, making it bounce all over the place as traction is lost and then regained. Just try keeping on the speed limit with that kind of BS going on! Oddly, a good heavy downpour is much better for traction than a light rain as it will tend to knock some of the grease off of the rail.
Have you thought about the fact that a steamer has all of its drivers connected ( articulateds excepted ) and adhesion will have to deteriorate enough to have all slip at once, whereas a diesels drivers are independent of each other and when just one driver slips the wheel slip system reduces power to all motors in order to recover from the slip.
06-29-2009 5:10 PM In reply to
Offline BigJim
Not Ranked
Roanoke, VA
Posts 730
joseph2:
The same goes for diesels, however, it is not because of the type of bearings. Instead, it is because of the effect the cold air has on the braking system. The colder the air, the harder it is to pump the system up to the required brake pipe pressure.
The fact is, that after a certain speed is attained ( it may be as low as 7mph ) there is no difference in the rolling friction between roller & friction bearings.
06-29-2009 8:39 PM In reply to
Offline timz
Top 500 Contributor
Joined on 02-17-2005
Posts 764
Re: Steam efficiency
jrbernier:
What was the speed and drawbar pull when 614 was getting 12-14%?
07-01-2009 8:57 PM In reply to
Offline GP40-2
Not Ranked
Joined on 07-11-2004
Posts 494
The C&O 614 might of had a maximum of 6% efficiency if restored to original condition and operating in hot weather. The 614 was pretty beat up from Ross running the heck out of it during the Chessie excursion years. During the ACE tests, the temperature was -20F in the Allegheny Mountains, and the 614 was down to 3% efficiency. This would be pretty typical of any steamer in those conditions. However, the 614 sure was impressive to watch pulling 100 car trains back to the mines. The one thing I can say about Ross was he was never afraid to push the big 614 to the limit.
07-04-2009 11:52 AM In reply to
Offline tpatrick
Not Ranked
Joined on 03-21-2002
Lakewood NY
Posts 464
selector:
Not always true. A GE AC60 weighs in at about 430,000 pounds when ballasted to the max. Compare that to a N&W A 2-6-6-4, which carried 432,350 pounds on its six driving axles. Granted, the lead and trailing trucks carried an additional 140,000 pounds, but the tractive weight equalled the biggest diesel. Sticking with N&W, look at the Y-6 2-8-8-2. Here you have 522,850 pounds on the drivers. Neither of these examples were the largest one could cite.
When you look at smaller two cylinder modern steam power (e.g.: NKP Berkshire) you find rough equivalence with four axle diesels, comparing weight on drivers. If the diesel is superior it is because of advanced traction control, which allows a more favorable factor of adhesion and thus, more pull per pound.
07-04-2009 4:46 PM In reply to
Offline Wdlgln005
Top 500 Contributor
Joined on 04-24-2002
Nashville TN
Posts 1,243
IIRC most steamers had an open cab, with no back wall. So the crew was exposed to the weather.
No AC in the summer, some heat in the winter, have a coat handy to stay dry if raining,etc.The good news may have been frequent stops to drink lots of water & take care of needs.
By contrast, a diesel has facilities inside. Not sure how well the heater & AC units work. Older units may be as leaky & noisy as a steamer.
07-07-2009 7:12 AM In reply to
Offline PNWRMNM
Not Ranked
Joined on 05-18-2003
US
Posts 606
Setting aside the causes, some of which apply to the locomotive and some to the cars, the effect of cold on steam tonnage ratings was significant.  From Great Northern Marcus Division ETT #5 of March 1911 the tonnage ratings on the 2.5% climb up Moslon Hill, which was in eastern Washington very near the Canadian border, for the various class G 4-8-0s, the heaviest locos rated on the territory were as follows:
Temperature               Tons
over 25 deg F              425
25 to 5                        400
5 to -10                       375
below -10                    350
Mac
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
Subscriber and Member Login
E-mail Address:
Password:
Remember me
My Profile
Screenname: (get your screenname)
Search Community
in
