Electronics and DCC
The place to discuss wiring for DC and DCC controlled model train layouts. If you're new here, please read our forum policies.
Last post 07-01-2009 8:24 PM by rrinker. 3 replies.
Rate:
Sort Posts:
Page 1 of 1 (4 items)
06-28-2009 12:09 PM
Offline Truck
Not Ranked
Joined on 01-04-2008
Posts 28
Bachmann N scale 4-8-2 remotor
     Hello,   Has anyone remotored a 4-8-2  N scale. And if so what motor did you use.
this one is a dcc on board loco. I took out the bachmann decoderand wired in a Digitrax DZ143.
And a MRC sound decoder. IT finaly fried the Digitrax decoder. For some reason this motor runs
very HOT. I took it out of loco and ran it freely no load on 9volts with dc transformer and it got so hot
I could barley touch it. But it only drew about 1/16 of an amp. And when I did a full amp load pull
it barley got to 1/2 amp on meter at 12 volts. but it was hot. IT fried both motor wires and decoder.
Are they supposed to get that Hot?
        From, Truck
06-29-2009 12:28 PM In reply to
Offline davidmbedard
Top 50 Contributor
Joined on 03-26-2004
Calgary, Alberta, Canada
Posts 5,110
Re: Bachmann N scale 4-8-2 remotor
 Is it supposed to get that hot?  No.  That means that you have a bind in the drive somewhere.
Your best bet is to send it back to Bachmann.
David B
06-30-2009 9:48 PM In reply to
Offline Truck
Not Ranked
Posts 28
The motor was tested out of locomotive.  Thats when I noticed it was getting hot with no load on it.
07-01-2009 8:24 PM In reply to
Offline rrinker
Top 25 Contributor
Joined on 02-14-2002
Reading, PA
Posts 7,584
 Probably has a shorted winding then. Only option is to replace, it can't easily be fixed. It's sort of a runaway problem - the motor stalls due to some reason and one of the windings gets hot enough to melt off the insulation, causing a short (that winding electrically has far fewer turns than a 'normal' one, thus less resistence). The shorted winding consistently runs hotter than the others and draws excessive current - possibly what fried the decoder - and if it melts more insulation it can get even 'shorter' leading to MORE heat and MORE current until finally the thing melts enough to open circuit.
                                       --Randy
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
