Toy train operating and collecting
Interested in O gauge, S gauge, and Standard gauge toy trains? Are you a fan of Lionel, MTH, American Flyer, and other brands of toy trains made today and in the past? If so, the Classic Toy Trains Toy train operating and collecting forum is just for you. If you're new here, please read our forum policies.
Last post 07-05-2009 2:30 PM by lonewoof. 6 replies.
Rate:
Sort Posts:
Page 1 of 1 (7 items)
06-26-2009 6:14 PM
Online EIS2
Not Ranked
Joined on 08-27-2004
Posts 555
Wheel Wobble Repair Question
I have a Lionel 2-4-2, #1654,with rear drive wheel wobble.  I have not determined if the cause of the wobble is a bent axle or a mis-drilled hole in the wheel.  The wobble is cosmetic only and the engine runs fine.  Has anyone had any experience in correcting wheel wobble?  Thank You...
Earl
06-27-2009 8:20 AM In reply to
Offline Buckeye Riveter
Top 50 Contributor
Joined on 03-08-2004
Roger's Corners, OHIO
Posts 5,858
Re: Wheel Wobble Repair Question
EIS2:
Earl
Earl.....I see a repairman in your future. Sorry I can't be of more help.
06-27-2009 12:51 PM In reply to
Offline cwburfle
Not Ranked
Joined on 07-10-2003
Posts 332
In my experience, wheel wobble is usually caused by a bent axle. Sometimes, but rarely, the wheel was put on crooked. If the wobble does not bother you, and the engine runs ok, forget about it. Otherwise, I'd replace the axle. I do that sort of work with a wheel puller, and an arbor press with the correct cups.
06-27-2009 2:56 PM In reply to
Offline jhz563
Not Ranked
Joined on 06-27-2009
Posts 1
Hi Earl, wish I could help, I am actually looking info about the same type of problem.  I have an inexpensive 2-axle switcher from the late '90's (it was under fifty bucks) that definitley has a hole drilled out of position and wobbles badly.  It is enough to make the operation erratic at best.  I was hoping to find out if anyone had taken the time to figure out a repair for these little guys, Its one of my little boy's favorites!
 John Z
06-27-2009 3:03 PM In reply to
Offline cwburfle
Not Ranked
Posts 332
jhz563:
Wheels (and axles) are available for most Lionel trains. Your loco probably takes one of the several varieties of diesel wheels.
07-03-2009 11:59 PM In reply to
Offline servoguy
Not Ranked
Joined on 07-03-2009
Posts 261
 I have a 0-4-0 switcher that had the same problem with the wheel wobbling.  I took a pair of channel locks and put them across from the bent wheel to the center of the wheel on the opposite side.  It was easy to bend the axle back straight.  The axels are quite soft and bend very easily.
07-05-2009 2:30 PM In reply to
Offline lonewoof
Not Ranked
Joined on 04-13-2004
SC
Posts 266
 I would be real careful, using the wheel to straighten a bent axle. The wheels are either die-cast or sintered (made using powdered metal) and are a bit brittle. I'd even be cautious using a wheel-puller that pulled on the rim. A broken wheel is even worse than a wobbly one!
/Lone
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
Subscriber and Member Login
E-mail Address:
Password:
Remember me
Free Newsletter
Get our free monthly newsletter delivered to your inbox
My Profile
Screenname: (get your screenname)
Search Community
in
