Layouts and layout building
Benchwork, scenery, track, and more. If you're building a scale model train layout, this is where to go. If you're new here, please read our forum policies.
Last post 06-26-2009 11:17 AM by johncolley. 21 replies.
Rate:
Sort Posts:
JBR46
Joined on
06-16-2009
I have seen several articles in MMR about using caulk as adhesive for laying track. The only article that mentioned a brand was 5 or 6 years old. It suggested Red Devil General Purpose caulk which is no longer available.
What brand do you use? Is silicone caulk necessary?
Thanks.
dknelson
Joined on
03-20-2002
Milwaukee WI (Fox Point)
Re: Track laying adhesive:
I use Polyseamseal All Purpose Adhesive Caulk. I like the kind that comes out white, and dries clear. This used to be an OSI product but now comes under the Henkel brand. I buy mine at Ace Hardware. Water clean up. It is not a silicon product -- the silicon sealant caulks are slippery to the feel. Some other folks use caulk that dries gray. An older article in MR advised using a DAP All Purpose Adhesive Caulk that is no longer made. There may be other DAP products that work fine so long as they are water cleanup and are not silicon sealants.
I run a line of caulk down the centerline of the cork roadbed then smooth it out to the edges using one of those annoying "Your Name Here" phony credit cards that come in the junk mail (or used to!). I then press the flex track in place. Also I spread some ballast onto the wet caulk between the ties and beyond the tie ends and tamp it down with an old piece of cork roadbed. This gives me a good start to final ballasting.
Dave Nelson
gandydancer19
Joined on
01-12-2007
Eastern Shore Virginia
I am using DAP clear caulk. It sticks better than their colored caulk. I have used the DAP Cedar Tan caulk. If you think you might take up the track later, use the colored DAP. You will be able to get it off the bottom of the track with a knife and follow up with a wire brush. Run a bead down the cnterline and spread it out with a pallet knife. Put the track down and put some weights on it over night. Same for the roadbed.
Seamonster
Joined on
11-29-2002
Winnipeg, Manitoba
I just get the cheapest clear latex caulk I can find. Some like to use coloured caulk to match the ballast, but the clear caulk is almost invisible and can't be seen once the ballast is on. I have heard that silicone caulk is much harder to remove if you need to remove track later. I have had no trouble removing caulked track from cork roadbed by sliding a putty knife under it. I also use it to attach the cork to the foam base. If you use caulk to attach the track directly to foam, it will take the top layer of foam with it if you try to remove the track later. Same thing if you try to remove cork glued to foam. The trick, as gandydancer19 pointer out, is to spread the caulk very, very thin with a putty knife then put weights on the track overnight.
Medina1128
Joined on
04-12-2003
Clinton, MO, US
Seamonster:I just get the cheapest clear latex caulk I can find. Some like to use coloured caulk to match the ballast, but the clear caulk is almost invisible and can't be seen once the ballast is on. I have heard that silicone caulk is much harder to remove if you need to remove track later. I have had no trouble removing caulked track from cork roadbed by sliding a putty knife under it. I also use it to attach the cork to the foam base. If you use caulk to attach the track directly to foam, it will take the top layer of foam with it if you try to remove the track later. Same thing if you try to remove cork glued to foam. The trick, as gandydancer19 pointer out, is to spread the caulk very, very thin with a putty knife then put weights on the track overnight.
I'm with Seamonster about using the cheapest I can find. I found a brand at Wal-Mart of acrylic latex caulk (can't remember the name) that came in a 4-pack for $3.99. It works great. Just follow the directions for using that other posters have left. And just in case you haven't seen them, here's how I do it.
- Lay a bead about 1/4" wide (not too thick).
- Spread with a 1 or 2 inch putty knife so that the layer is very thin. When you press the track into it, it should NOT ooze up between the ties.
- Pin in place. Since I'm using cork roadbed, push pins work very well.
- Ballast track when caulk is dried (I usually wait about 24 hours)
The advantages of caulk are that it holds the track very firmly, but the track can still be taken up with a putty knife without destroying the track in the process.
wsdimenna
Joined on
04-29-2008
western ny
You may want to consider looking at this thread. Nice thing about this is if you ever need to take up track, all you need is water. The section of flex track was done in about 5-10 min.
Fibedecor for scenery base. Bill D
CSXDixieLine
Joined on
04-24-2007
Lilburn, GA
The brand I use is DAP ALEX painters caulk. It is available just about everywhere (Wal-Mart, HD, Lowes, Ace, etc). I run a bead down the centerline, spread it thin with a putty knife and press the track in. You want to make sure that the layer of caulk is not too thick or else it will squeeze up between the ties. Even a very thin layer has a LOT of grab--I did not need any clamps or pins when I laid my flex track (although I used a few early on in my tracklaying, such as in the photos below). I use the gray color for laying track because it simulates the look of ballast until I get the real ballast down. Jamie
ATLANTIC CENTRAL
Joined on
01-26-2009
Maryland
I prefer the clear polyseamseal. It has better adheasve properties than regular caulk. I also use it in one of my professions - construction. it is vastly superior to other similar products.
Sheldon
CTValleyRR
Joined on
05-24-2007
East Haddam, CT
I use gray DAP adhesive caulk. Similar to the poster above, I put a bead down, then use a putty knife to smooth it before pressing the track down. I use a couple of track nails to hold flex track in position if it has a significant bend in it, then I lay scrap lumber and heavy books on the track for about 3 hours until the adhesive sets a bit. I don't worry too much if some caulk oozes up between the ties, because the gray color blends with the ballast and it doesn't show. You just don't want big gobs sticking up above your ties.
I have tried several other adhesives -- carpenters glue, white glue, track nails and ballast, and hot glue. I find that none of these work as well, being both too hard to reposition or rip up, too rigid, or insufficiently strong.
Adhesive caulk can't be beat.
RF&Prr
Joined on
05-05-2009
CSXDixieline.....How did you make your helix? Splines or something else?
RF&Prr
tstage
Joined on
06-11-2003
Northeast OH
JBR,
Like CSXDixieLine, I use DAP Acrylic Plus Latex caulk to lay track, as well as cork road bed:
It only costs $2 at Home Depot, comes in may colors and holds VERY well. And, even though it does do a great job of holding down track, if you ever need to do some track repair, a thin putty knife and steady pressure can peel it back up.
And
CSX's tips are spot on. Use a putty knife to spread out a thin layer
of the caulk. (Otherwise, it will ooze up through the ties.) In 40 minutes the caulk begins to take hold. I just let it dry
over night. The one thing that I do differently than CSX is to tack down the track or
cork road bed with pins or lay bricks on top to keep it flat until it drys. Tom
CSXDixieLine
Joined on
04-24-2007
Lilburn, GA
RF&Prr:
RF&Prr
So far I only have the helix base in place. The track that you see in the photos does use spline roadbed, but that is just a temporary coil of track used as a staging yard until I actually start building the helix. I plan on using 1/8" Masonite laminated together to form 1/4" thick roadbed when I do get around to the helix. Jamie
dknelson
Joined on
03-20-2002
By the way once you have the tubes of latex adhesive caulk on hand, I think you'll find there are numerous other uses for the product on the layout -- laying plastic street sections such as Walthers', attaching building flats to a backdrop, and a host of other uses.
Dave Nelson
train_frk-0079
Joined on
01-31-2009
Peotone, IL
I just use the latex silicone caulk from DAP. Dap is easy to get from a lowes or Home Depot, and it's inexpensive. It's simple to pry the track up, just use a utility knife. If you do use the knife, you may be throwing out the peice of track, or roadbed.
Peace
alanprocter
Joined on
11-04-2005
West Vancouver, Canada
I seem to be an oddball here since I have always used white glue or Woodland Scenics foam glue and always on Woodland Scenics foam-type roadbed. I like this because when I want to pull up the track [this has been on several occasions to install switches or change direction], I just spray mist with water, leave for about 30 minutes, then pry up with a thin scraper. You also need something with strong grab to hold any flex track in place until curing is complete. If latex caulk come away just as easy with water, I will try this next time.
Alan
