Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
Advanced Consisting Lighting
  • Member since
    August 2008
  • 1,329 posts
Posted by wholeman on Friday, June 12, 2009 10:15 PM
Someone please help.  I just received my first DCC system the other.  It is an NCE Power Cab system.  The decoders are TCS T4X.  They are installed in Athearn RTR engines.  I was wondering if their is a certain CV that allows only the first loco in the consist to have the foward headlight on in the forward direction and have the last loco have its light on when traveling in reverse.
Thanks in advance.
Will
  • Member since
    July 2006
  • 3,312 posts
Posted by locoi1sa on Saturday, June 13, 2009 5:41 AM
 Will
 CV22 is consist light control. Entering a 1 will only let the headlight work. Entering a 2 will only let the rear light work. CV22 = 3 no head or tail light.
 CV21 controls the other lights if any.
  Here is a good decoder read.
 http://www.tcsdcc.com/Customer_Content/Technical_Info/Tech_Manuals/Plain%20English%20Guide%20r3.pdf
    Pete
 I pray every day I break even, Cause I can really use the money!
 I started with nothing and still have most of it left!
  • Member since
    December 2001
  • 1,063 posts
Posted by jalajoie on Saturday, June 13, 2009 8:46 AM
locoi1sa
 Will
    Pete
Here are the NMRA standards for CV21 and CV22.
Configuration Variable 21                Consist Address Active for F1-F8
Defines for functions F1-F8 whether the function is controlled by the consist address. For each Bit a value of "1" indicates that the function will respond to instructions addressed to the consist address.  A value of "0" indicates that the function will only respond to instructions addressed to the locomotive address.  F1 is indicated by bit 0.  F8 by bit 7.
Configuration Variable 22                Consist Address Active for FL and F9-F12
Defines for function FL whether the function is controlled by the consist address.  For each Bit a value of "1" indicates that the function will respond to instructions addressed to the consist address.  A value of "0" indicates that the function will only respond to instructions addressed to the locomotive address.  FL in the forward direction is indicated by bit 0, FL in the reverse direction is controlled by bit 1.  Bit 2 corresponds to F9, while Bit 5 corresponds to F12.
However for some obscure reasons this don't seem to work for me.
Jack W.
  • Member since
    December 2001
  • 1,063 posts
Posted by jalajoie on Saturday, June 13, 2009 9:11 AM
wholeman
Thanks in advance.
There are two ways to achieve your goals.
First use the double ended consist feature of NCE, here is how to do it:
With the Power Cab make an advance consist with both locos operating back to back. Make sure the stack contains two consists bearing the cab # of each loco. If what you want is only the leading loco with headlight On and the trailing completely dark program a value of CV22=0.
With the Power Cab to change end of the consist : First shut the light on the former leading loco, next recall the now new leading loco, put the lights On and go. (3 keystrokes)
This is done on the fly, very easy.
A second method is programming the TCS T4X for completely independent lights control.
F0 will control front light On/Off
F1 will control rear light On/Off
Set CV34 to 4 default value is 2
Set CV35 to 16 default value is 4
Set CV49 to 40 default value is 0
Put the front light On and the rear light Off on both engines before making the consist. Make the consist in the usual manner with the Power Cab. No matter what direction the consist is traveling only the front light of the leader will be On and the trailing will always be dark.
Jack W.
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
