Layouts and layout building
Benchwork, scenery, track, and more. If you're building a scale model train layout, this is where to go. If you're new here, please read our forum policies.
Last post 06-11-2009 12:25 PM by Sir Madog. 9 replies.
Rate:
Sort Posts:
Page 1 of 1 (10 items)
06-08-2009 11:39 AM
Offline Been Nothing Since Frisco (BNSF)
Not Ranked
Joined on 07-13-2008
missouri
Posts 415
Which to use?
 I haven't been on here in a while and now I have a question that I haven't found an awnser to on frisco.org (were I've been since Jan.)
 I have a plan to build a new layout maybe this year. It is a 2 layer layout. I'm trying to figure out, would it be more practical to use foam or a custom made wood suport type deal? The reason I dont think foam is a good choise for this is because the upper layer must go over a bunch of inter sections with the lower lever. And I also plan to fill in one end of it.
What is your thought?
06-08-2009 12:42 PM In reply to
Offline dehusman
Top 50 Contributor
Joined on 09-20-2003
Omaha, NE
Posts 5,416
Re: Which to use?
This is not a slam and this is not being said to be mean.  This answer is entirely serious.
I think you need to do a LOT more studying on benchwork construction before you take on a double deck railroad.  It is not a trivial project in size, engineering and funding.  If you REALLY want two decks, take the time to research how to do it.  If it takes you 6 months to research and plan it, it will be worth the wait in the results and reduced pain and suffering during construction.
06-08-2009 2:48 PM In reply to
Offline dgwinup
Top 500 Contributor
Joined on 05-05-2005
Posts 1,123
Re: Which to use?
I agree with Dave.
I'm in the middle of designing a trackplan for a new layout (see my "Great Dream Layout Quest" thread elsewhere).  While I am taking my time designing a trackplan, I have not forgotten about the support layer underneath it all.  Part of my layout will be below another section, so choice of construction materials will be critical to allow as much room as possible between the layers.  I've made no firm decisions yet, but I suspect the design of the benchwork will be as intense and time consuming as the trackplan itself.
Darrell, quiet...for now
06-08-2009 6:45 PM In reply to
Offline blownout cylinder
Top 50 Contributor
Joined on 11-10-2008
London ON
Posts 4,534
Re: Which to use?
I'm in agreement here.
Think about how you will support the layout first. The benchwork question is, to my mind, even more important than the layout at this point. How are you going to build it, how to budget for all the lumber you'll need, wiring, --- OY. Take your time on it and it'll work out rather nicely
06-08-2009 8:13 PM In reply to
Offline tgindy
Top 500 Contributor
Joined on 05-20-2005
Westcentral Pennsylvania (Johnstown)
Posts 798
Re: Which to use?
Here are a hodge-podge of additional ideas...
[1] See a fairly current thread, "distance between levels" (http://cs.trains.com/trccs/forums/t/154558.aspx) for a lot of common sense considerations.
[2] Kalmbach's "Designing and Building Multi-Deck Railroads" (http://kalmbachcatalog.stores.yahoo.net/12434.html) @ $19.95.
[3] PDF Download "Guide to helix and staging design" (http://kalmbachcatalog.stores.yahoo.net/mrpdf032.html) @ $8.95.
[4] PDF Download "Guide to helix and staging design vol. 2" (http://kalmbachcatalog.stores.yahoo.net/mrpdf049.html) @ $8.95.
[5] Will benchwork be "free-standing" or attached to the walls?
[6] Will you have a helix or a nolix?
[7] Is your room large enough to employ a peninsula? ...that may even be a location for a helix?  See the July 2009 Model Railroader, pages 54-57, for the First Prize, Track Plan Contest, and John Koukol's Maine Central rendering of "A double-deck N scale track plan."
My hunch is you will find, not much can replace the strength of wood/plywood benchwork as a base, and; especially so for a helix.  Foam can be placed on top of a solid core of benchwork for its scenery & trackage base plus carving characteristics.
There are many possibilities, but you must first take your good 'ole time with research and planning.
06-09-2009 7:14 AM In reply to
Offline tangerine-jack
Top 200 Contributor
Joined on 08-04-2004
Virginia Beach
Posts 2,060
Re: Which to use?
I agree, there are lots of ways to skin that cat and a double deck is no small task.  It will involve a lot of time, effort and finances so you will want to be sure what you are doing is correct and will meet your individual need.  In addition to the above advice, I suggest contacting the local mrr club and seeing if any of the members have a double decker that you can look and and pick that persons brain.  I also agree that you may find that, in the end, good old fashioned wood is the best choice still.
06-09-2009 11:02 AM In reply to
Offline cuyama
Top 500 Contributor
Joined on 12-27-2001
Northern CA Bay Area
Posts 1,241
Re: Which to use?
The original poster may not be talking about multi-deck, just multi-levels on one deck. Unfortunately, the original post was too vague to know.
06-09-2009 7:50 PM In reply to
Not Ranked
missouri
Posts 415
Re: Which to use?
Sorry about the vagueness. It's not a multi-deck. This would be easier to explain if I could get the track plan on here, but I don't know how to, it's on RTS. Basically the bottom part is a loop around with a small yard and a few sidings. While the part I want to elevate is a loop with a small passing siding. Because of size constraints it will be on a 4x8. Also with this in mind should I put down foam on the plywood before I add the elevation of which ever type it is? Also the 22R turns (elevated track) would over lap the 18R (bottom track) a lot.
06-10-2009 5:36 PM In reply to
Not Ranked
missouri
Posts 415
Re: Which to use?
Ok, going through my track plans, I have figured out a good idea. I created this one a while back when I first saw the beer line. I figured I could build it now, then later I could add the 22R up top.
06-11-2009 12:25 PM In reply to
Offline Sir Madog
Top 500 Contributor
Joined on 03-16-2009
South of the Arctic Circle
Posts 1,644
Re: Which to use?
 You can save track plans drawn in RTS as jpeg-files, then upload them to a platform like photobucket and then integrate them into your post here.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
