The Great Dream Layout Quest
I’m ready to build my “Dream Layout”. This layout has been in planning for years and supplies have been stockpiled in anticipation of construction. Given my age, this will probably be the last layout I build for myself, so I want to include as many of the things I have dreamed about for years. By definition, a dream layout includes everything you’ve ever wanted to have in a layout.
Unfortunately, in spite of all my efforts, I have been unable to come up with a trackplan that satisfies me. I know, I know, model railroading is a series of compromises. I understand that. This being my final layout, though, I want as few compromises as possible.
Now, I’m NOT asking anyone here to design a layout FOR me. Each layout is individual to the modeler. What someone else designs may not be what I’m looking for, even if ALL of my givens & druthers are included.
What I’m looking for is more brain power. And fresh eyes! People who can offer criticism of and advice on my efforts.
Here are the givens:
Room size: roughly 10x12’; one angled doorway and a closet on one wall, two walls with windows. The windows don’t need to be accessible, the closet does (it’s my supply storage and workbench area!)
Scale: N scale
Prototype: Santa Fe & Union Pacific
Timeframe: Transition era, prior to 1955
Equipment: Large and small steam; first generation diesels
Track: Atlas Code 80 flex, Atlas & Peco turnouts, cork roadbed
Here are the druthers:
Double-tracked mainline operation (continuous running for passenger & through freights)
Passenger terminal (not huge, but decent sized)
Light switching
Staging (can be hidden or open)
Large roundhouse
Classification yard
One or more towns
Large bridge or multiple bridges
The Vision: An around the wall layout that allows multiple train operation; continuous running on the main, switching on sidings. Reasonable adherence to the prototypes, but not strict adherence. (There aren’t too many locations in the USA where SF & UP were close to each other!) Single-operator. DC to start, DCC conversion planned. Avoid reverse loops (difficult DC wiring, expensive reversers in DCC). Avoid the use of a helix (uses too much room.). Single or multi-level with mainline grades of 1% to 1.5% (or at least under 2%).
Construction type or style: Will consider any style, box-frame, L-girder, foam or any combination. A combination will most likely yield the best results.
Let’s get to it!
First, I built a scale 1”=1’ model of my room using foam core board. The first picture shows the room with the major furnishings as currently arranged and shows where my existing layout is located within the room. The entry door is in the lower left. The closet is along the lower wall. The large rectangle on the left is a desk with my computer on top. The smaller rectangles are shelf units (3 on the upper wall, 2 on the right side wall). The desk/computer set-up mandates a MINIMUM height of 45” to the BOTTOM of the lower level. Track on the top of the upper level shouldn’t exceed 55” in height. Scenery can be higher as long as it doesn’t block the upper level tracks.
The second picture shows an alternate location for the furnishings. The desk has been moved to below the window (upper wall) and 3 of the shelf units have been re-arranged to the right wall.
Using Atlas’ Right Track software, I drew this 2-level plan:
Upper level:
Lower level:
There are glaring flaws in this plan. There is little switching opportunity. The roundhouse area may not be big enough as drawn to accommodate a 23-stall roundhouse. There isn’t enough room for the proper engine service facilities that would be indicated by such a large roundhouse.
There is no place to locate a passenger terminal, even a small one. Finally, the grade to the lower level doesn’t provide enough clearance. (I measured about 170” from the upper to lower level. At 1.5%, that gives a clearance of only 2.5” RAILHEAD TO RAILHEAD. In other words, not enough clearance! 2% gives only 3.5”, which would be enough to run trains under, but not enough room to reach any derailments in staging. I have fat hands! LOL)
A lift-out or swing gate would be located on the bottom of the layout for access. It is not shown on the plan. Its actual location would be determined during construction.
I printed out the RTS plan (surprisingly, it printed out at 1”=1’!!). I cut up the prints and glued them to foam core board. This next picture shows the new layout in the existing room:
There is a little more room below the roundhouse area. I’m not sure what the best use of that area could be. Part of the closet opening can be obstructed (about 12-18”). The upper and lower levels are shown in the picture only to give an idea of how they fit in the room.
As you can tell, I’ve put some thought into this. I’m old and I want my Dream Layout this time around!
I intend to post this on several forums. Many of you belong to different forums, so be prepared to run into this several times. I don’t expect anyone to post a response to every forum and I will try to copy and post anyone’s comments into the threads on different forums so everybody can see what comments have been made, regardless of where they were made. (I hope that’s clear!) In the meantime, I’m going to try designing some layout design elements to fit on dominoes. That may be a good way to get the features I want.
So, anyone care to take a stab at this?
Darrell, quiet…for now
