Paul_D_North_Jr:The classic qualitative simple formula for concete is:
Concrete = Coarse aggregate (gravel or crushed stone) + fine aggregate (sand) + cement (powder) + water (liquid) [not necessarily in that order].
The quantitative aspects of concrete - the precise amounts and proportions of each constituent - vary according to the strength and other chemical and physical properties needed, and the costs and availabilty of each of these materials as well as any desired or necessary additives, etc. Although this is a well-established science, in essence, it can be an ongoing study for each new major project or source, etc.
Where is Chris/ CopCarSS now that we need him ? ? ?
The really weird thing (to me) is that once the basic proportions are established for a particular mix ("recipe"), the major strength of the concrete - in compression - is essentially governed by the shear strength of the coarse aggregate pieces. Which is why the concrete producers in our area of southeastern Pennsylvania love our local supplies of coarse aggregate derived from limestone, sandstone, and especially traprock (granite and other really hard rocks).
- Paul North.
Chris can probably explain more than I can. Hes been in the concrete business lots longer than I have.
The Recipe you speak of is referred to as a Mix Design. Some mixes may also include Fly Ash, a filler material that is sometimes used in the mix. It will generally darken the concrete a bit. Fly Ash is the ash left over from burning coal in power plants. Often the contractor likes to add in admixtures. They are chemicals that will alter the concrete to make it more workable or to give the concrete other desireable qualities. I myself have delt with admixtures that will retard the setting up of the concrete thus giving a longer working time. The sites I was on didn't like ot but we were forced to add it a couple times to prevent the concrete from hardening in the mixer and pump during an emergency blowdown. We regularly used Super Plasticizers in the summer to make the concrete more workable without adding water to the load. It is classified as a Water Recucer. And depending on the amount added will make a dry mix flow. We used this because I had a specific specification for the job that allowed me a specific Water to Cement ratio. The more water added the less strength the batch will have. Every time I wanted to add water to the load, I had to calculate my W/C ratio. Super Plasticizer helped me maintain strength while making the mud easy to work. The last really handy admixture is an accelerator. It is used in the winter to speed the setting up before it freezes. This doesnt mean that you dont have to cover it and keep it warm anyway. I have also seen it used in highway patches. You pour in copious amounts into the load, and the pour the mud where you need the patch. I have seen traffic driving on it in less that 5 hours.
Here is a mix design that is pretty standard:
Normal
0
false
false
false
EN-US
X-NONE
X-NONE
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-priority:99;
mso-style-qformat:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:11.0pt;
font-family:"Calibri","sans-serif";
mso-ascii-font-family:Calibri;
mso-ascii-theme-font:minor-latin;
mso-fareast-font-family:"Times New Roman";
mso-fareast-theme-font:minor-fareast;
mso-hansi-font-family:Calibri;
mso-hansi-theme-font:minor-latin;
mso-bidi-font-family:"Times New Roman";
mso-bidi-theme-font:minor-bidi;}
PORTLAND CEMENT
CONCRETE MIX VERIFICATION
(6 Bag Mix)
Normal
0
false
false
false
EN-US
X-NONE
X-NONE
st1\:*{behavior:url(#ieooui) }
font-size:11.0pt;
Requirements: 4,000 psi compressive strength at 28 days laboratory
cure, air entrainment, Type I/ II Cement.
Source of Aggregates: Fine Aggregate – Fear Pit
Coarse
Other Mix Components: Portland Cement Type I/II
Ash Grove Cement Co.
Air Entraining
Admixture Grace
AMEX 210
322N Water Reducer Grace
WRDA 64
Fly
Ash Bridger Fly
Ash, Class F
Non-Chloride
Accelerator Grace
Polarset
Hydration
Stabilizer Grace
Recover
Superplasticizer Grace
ADVA 140M
Water Potable
Mix Requirements: Compressive Strength, Min. at
28 days 4,000 psi
Compressive
Strength, Min. at 7 days 3,000 psi
Air
Content 5.5
percent +/- 1.5%
Slump 4.5
inch Nominal
Aggregate Properties:
Percent
Passing U.S. Standard Sieve Sizes
Sieve
Size Fine
Aggregate Coarse Aggregate
1" - 100.0
3/4" - 87.8
1/2" 100.0 49.8
3/8" 100.0 33.1
#4 98.0 6.8
#8 81.9 2.6
#16 62.0 2.1
#30 36.9 1.6
#50 14.7 1.3
#100 4.6 1.0
#200 1.5 0.7
F.M.: 3.03 -
S.G.(SSD): 2.64 2.61
Absorption(%) 0.93 1.3
Moisture
Content(%) 5.9 1.3
Sulfate Soundness(%)loss 0.77 2.48
La
Abrasion - 25.5
ACTUAL TRIAL BATCH MIX PROPORTIONS FOR ONE CUBIC YARD OF CONCRETE
(6 Bag Mix)
Computed S.S.D. Batch Computed Absolute Actual
Batch
Volume
(%) Weights (lbs) Volume
(ft^3) Weights
(lbs.)
Cement:Type I/II 8.52
452.0 2.30 451
Fly Ash Type F 2.89
112.0 0.78 113
Fine Aggregate: 28.89 1285.0 7.80 1330
Coarse Aggregate: 38.44 1690.0 10.38 1698
Water: 15.78 266.0
(32.0gal) 4.26 219 (26.25 gal)
Entrained Air: 5.5 - 1.49 -
TOTALS: 100.0 3814.0 27.01 3811.0
