To expand on the subject of tracklaying with grey latex caulk:
Mark your track location on your roadbed. Marking a line for the outer ends of the ties on a curve will make locating the track easier.
Carefully pre-bend your flex track to the desired curvature, so it will fit your geometry without any fastenings at all.
Put a small bevel in the top inside corner of each railhead, both ends of every track section.
Spread the caulk thin and make sure you can see your track locating lines.
Hold the track in place by driving fasteners between the ties, gripping the base of the rail on both sides.
Load the track with canned goods, cordless tool batteries or similar weights until the caulk sets up.
Once the caulk has set, remove the temporary fasteners. You are now ready to ballast the track.
I have been using these methods for laying track, including Atlas concrete-tie Code 83, for several years now, and am very pleased with the results.
Chuck (Modeling Central Japan in September, 1964 - with Atlas flex and handlaid specialwork)
