General Discussion (Model Railroader)
Advice, tips, questions and general information on the hobby of model railroading. If you're new here, please read our forum policies.
Rate:
Sort Posts:
Looshi
Joined on
02-24-2007
Lebanon, Ohio
I'm putting together one of Walthers "Classic Kits". It already has the logos and such painted on the side. The underframe is molded in the same color as the body. My question is should the underframe and brake reservoirs be painted black or should I leave them the same color as the body? I've tried doing some quick Google searches but it's harder to find shots of the bottom of boxcars then it seems. I'm inclined to leave it but I figured someone here would know for sure.
chatanuga
Joined on
01-02-2002
Hilliard, Ohio
A few years ago, I got some custom-painted Walthers autoracks off Ebay. The seller had painted the undersides a grimy black color. To be honest, when mixed in with my other autoracks, it isn't that noticable. Granted the undersides of cars should get some weathering since they'd be collecting all kinds of gunk kicked up by the wheels.
Kevin
hornblower
Joined on
10-02-2007
Fullerton, California
Looshi:I've tried doing some quick Google searches but it's harder to find shots of the bottom of boxcars then it seems.
I've always wondered why so many modelers and current manufacturers spend so much time and effort detailing the underside of their rolling stock. I rarely, if ever, try to look at the underside of a car while it is sitting on the rails. I guess people who photograph prototype trains don't either. I would think the only reason to detail the underside of a train car or loco would be to model a train wreck with overturned cars.
Medina1128
Joined on
04-12-2003
Clinton, MO, US
Maybe they want the train to look more prototypical when they have a derailment.
markpierce
Joined on
04-04-2003
Union-Garratt Loco (Mark in Martinez, CA)
hornblower:
Perhaps you don't look at your rolling stock at eye-level and don't have any tank cars or high-car-body gondolas where underbody detail (or its lack) really stands out. For models without break gear, the simple addition of tie rods perks up the appearance of cars in my eyes.
Mark
dehusman
Joined on
09-20-2003
Omaha, NE
Looshi: My question is should the underframe and brake reservoirs be painted black or should I leave them the same color as the body? I've tried doing some quick Google searches but it's harder to find shots of the bottom of boxcars then it seems. I'm inclined to leave it but I figured someone here would know for sure.
The answer is, it depends!
Some railroads painted the undersides a different color (just as some painted the ends a different color).The vast majority of cars I've seen have the underside painted the same color as the car.
If you really want to go nuts, are the trucks painted the same color as the car?
At least you are one step ahead of us in the early rail group, we argue whether the undersides are even painted, then we worry about the color!
nbrodar
Joined on
06-20-2005
Phoenixville, PA
For the most part, particularly in modern times, the underframe, is the same color as the body. However, as the underframe is exposed to far more grime, it may look black. Nick
Looshi
Joined on
02-24-2007
Lebanon, Ohio
Thanks for the responses.I think I'm going to leave it the body color but then keep things in mind when I weather it. There was something about a bright yellow underframe that bothered me, but I think doing some serious weathering will take care of it.
lesterperry
Joined on
02-09-2001
US
I know everyone has their own little thing in this hobby, that's what makes it so great. I run my trains. and when it goes by at scale 30 M.P.H. I cant even see the bottom and before you get on me to roughly, That's my so now I have everyone hating me.I am not a rivet counter.
DavidGSmith
Joined on
01-13-2003
CA
I paint all of my under frames grimy black with a rust wash over them. You cant always see them but I know its there and thats what is important to me. Dave
trainfan1221
Joined on
07-24-2003
Elmwood Park, NJ
I model in N and my layout is well below eye level. I don't bother with much as you can't really tell anyway.
carknocker1
Joined on
01-05-2007
Northern Ill.
As someone who spends alot of time under a car most are painted the same color as the car , the ones I 've seen that are not the same color are usually a primer color .
galaxy
Joined on
07-29-2006
upstate NY
Painting the underside black may help to make it "disappear" when looked at -IF it were seen.
There are two things to consider: 1} what would the prototype do and 2} what do you prefer?
Then there is that nasty little thing about detailing modelworks: 1} DO you detail everything-even when no one will hardly ever see it; and 2} Do you NOT detail the things that are most likely not going to be noticed.
If it were me, I'd vote for black in theory. And not worry about the details no one may see.
In reality, I vote with my own boxcars to leave the undersides of my boxcars as they came, some came black, and some came the same color as the car.
dstarr
Joined on
08-10-2006
Franconia, NH
I mask off the topsides and couplers of cars, remove the trucks, and give the bottom sides a coat of gray auto primer with a rattle can. Sometimes dark gray (which is close to black) and sometime light gray. It kills the plastic gloss on unpainted undercarriages, and makes the visible weights (like Athearn) less visible. It helps the overall appearance of the cars, even though I don't pick them up and examine the underside.
If, after the overall coat of primer, one wanted to go farther, one could paint the air tank either black or boxcar red, and pick out some other details in a contrasting color. While I am at it, I always spray paint the trucks in red auto primer to cover the black glossy plastic, and paint the wheel faces grimey black.
rrinker
Joined on
02-14-2002
Reading, PA
Medina1128:
Then you need to leave the truck screws out
--Randy
