Trains.com
Subscriber & Member Login
Login, or register today to interact in our online community, comment on articles, receive our newsletter, manage your account online and more!
New Superliner Lighting Kits by Walthers/HO
  • Member since
    February 2007
  • 471 posts
Posted by ho modern modeler on Tuesday, April 21, 2009 8:59 PM
Anyone try installing these yet?
Nothing supporting the middle on Coach, Lounge, Etc. I had to tape them together in the middle because they kept coming apart.
Putting the car back together was just enough of a struggle that the contacts popped off on 3 of 4 cars and they don't light.
Took them all apart again and added plastic shims underneath to "tighten" the contacts. Had to remove them because there just isn't any more room heightwise to close the car tightly.
Now I'm trying to crazy-glue thin .020 styrene against the back of the hooks on the flat side and .060x.188 on the electronic side so they don't pop off when I squeeze the cars back together/re-install the couplers.
I'll post pictures if it works. No light in the lower level???
Mine doesn't move.......it's at the station!!!
  • Member since
    August 2008
  • 1,329 posts
Posted by wholeman on Tuesday, April 21, 2009 9:49 PM
ho modern modeler
There will be no light in the lower level (I wish this would happen too.  I had to glue the plastic "filters" too the light board also.  I came across some extremely thick plastic that has worked really well.
Another tip:  Use electrical tape to cover the metal prongs on the LEDs on top of the boards.  I noticed the inside of the body's metal plating will cause these to short out.  It carries enough ohms to temporarily short it.  Good luck.
Will
  • Member since
    February 2007
  • 471 posts
Posted by ho modern modeler on Wednesday, April 22, 2009 7:31 PM
Thanks, I'll take them all apart again!!!
Banged Head
Users Online
There are no community member online
Search the Community
ADVERTISEMENT
ADVERTISEMENT
ADVERTISEMENT
Model Railroader Newsletter See all
Sign up for our FREE e-newsletter and get model railroad news in your inbox!
