L girder is the prefered choice for construction of the club layout. The advantages of "L" girder outweigh box/ open grid for such a large "permanant" layout.
Use of taller 1x stock allows greater span between legs if needed (some have even fabricated "I" beam like the engineered TJI joists) to support greater distances.
The support legs are set inboard from the facia. Better look and less tripping when walking around.
Allows ease of riser for elevation, riser placement especially if joist/ riser needs to be skewed.
Allows for drastic scenery elevation changes, deep valleys, rivers and gorges.
Allows for any flowing shape or radiused facia.
Can run joists easier on a radian to set risers more perpendicular to track on full end turns.
Disadvantages are greatly reduced clearance beneath layout.
Any disassembly can be very difficult unless serious thought was used in the initial construction technique (as described above)
Some pics of our rather sizable layout
Various elevation/ level changes and track orientation (skewed joists)
Bridge abutments (or sub abutments) easily done or reworked
