Layouts and layout building
Benchwork, scenery, track, and more. If you're building a scale model train layout, this is where to go. If you're new here, please read our forum policies.
Last post 04-20-2009 5:38 PM by Doc in CT. 5 replies.
Rate:
Sort Posts:
Page 1 of 1 (6 items)
04-19-2009 8:15 AM
Offline Doc in CT
Not Ranked
Joined on 02-04-2009
Enfield, CT
Posts 271
Anyone familiar with Busch track stabilizing tape
 Came across a reference in the Busch-Gmbh online catalog to: "The Busch track stabilizing tape allows the realistic stabilization of all tracks containing ties. The double-sided tape has a foam rubber lining, providing sufficient sound insulation. The tape can be used as a temporary or permanent track-fastening agent."
Anyone familiar with the product?  Is this similar to topper tape (vinyl foam tape used to insulate pickup truck caps)?   See MR August 2003 "Quick and Easy Flex Track"
Thanks
04-19-2009 8:31 AM In reply to
Offline Sir Madog
Top 500 Contributor
Joined on 03-16-2009
Hamburg - South of the Arctic Circle
Posts 1,146
Re: Anyone familiar with Busch track stabilizing tape
 It´s been on the market for quite a while and I remeber using it ages ago. Whereas it works ok with sectional track, I cannot recommend it for flex track.
04-19-2009 8:42 AM In reply to
Online cacole
Top 25 Contributor
Joined on 07-23-2003
Sierra Vista, Arizona
Posts 8,601
 Double-sided white foam tape sold in rolls at practically every major retailer would probably be a very similar product and much cheaper.
04-19-2009 7:04 PM In reply to
Offline tomikawaTT
Top 25 Contributor
Joined on 02-13-2005
Southwest US
Posts 7,244
I tried that double-sided white tape on some temporary trackage (laid partially on cardboard!) during the early-construction phase of my (non-climate-controlled) Mojave desert garage-filler, to anchor flex, some of which was curved but not pre-formed.
Performance was, in a word, unsatisfactory.
It stuck well enough - too darned well, in fact - to the plastic ties - but not well to the plywood and hardly at all to the cardboard.  Side thrust caused the track geometry to change enough to warrant relaying with track nails to convince things to stay put.
That stretch of construction tramway lasted less than two months.  Two months later I was still trying to get the last of the white goop off the flex track.
Since that time, all of my permanent tracklaying has been done with pre-formed flex and latex caulk.  Some of it has been in place for three Mojave Desert summers without giving me any problems.
04-20-2009 8:17 AM In reply to
Offline Allegheny2-6-6-6
Top 500 Contributor
Joined on 03-24-2007
Posts 1,020
 Sounds like "Topper Tape" to me. There was a post a while back about using topper tape or the foam based double sided tape placed between a pick up truck bed and a cap or topper. I have also seen it used in one of Allen Keller's Great model Railroad series tapes. It seems lie a very cheap way of doing things but rememebr you get what you pay for. My hsistation would be that it's been my experince that the glue on that sort of tape tends to dry out after a while and having it lift after a period of time would be nothing short of disasterous. They guy in the vidoe swore by it saying all you needed to do was press the tape down to the plywood, press the track into the tape and even just sprinkle the ballast onto the tape. No need for white glue or track nails etc. I would try it in maybe a hidden staging yard rather then an area thats ging to be sceniced .
04-20-2009 5:38 PM In reply to
Offline Doc in CT
Not Ranked
Enfield, CT
Posts 271
 Just curious.  My own planning calls for cork along with caulking.
Copyright © 2009 TRAINS.COM
Powered by Community Server (Commercial Edition), by Telligent Systems
E-mail Address:
Password:
Remember me
Get Newsletter
My Profile
Screenname: (get your screenname)
Search Community
in
